Question about RCA P52937 52" Rear Projection Television
Scrolling When turned on, my television scrolls up through the channels one by one over and over and over, etc....... Remote and tv front panel have no affect at all in stopping this. Any idea??
  • 61 Answers
The buttons in the front control panel are bad,these switches part number are 268854
Posted on Mar 05, 2008
Why is menu scrolling uncontrollably when turning on?
Vizio L32 32 in. LCD HDTV Scroll stuck - Questions - Fixya
www.fixya.com > ... > Vizio > Vizio L32 32 in. LCD HDTV
Question about Gateway Flat Panel Televisions. 2 Answers · Menu stuck on andscrolling. menu stuck on and scrolling The TV remote control will not operate the TV, and now the ... Menu Scrolls Uncontrollably ... To turn off the TV, I have to .
Vizio LCD 37 Inch Turns Off Randomly - Fixya
www.fixya.com/support/t354860-vizio_lcd_37_inch_turns_off_randomly
Flat Panel Televisions question. ... I have a 2006 Vizio 37 inch LCD that has started to turn itself off randomly. ..... Why is menu scrolling uncontrollably when turning on? will stop randomly on one input, but will scroll uncontrollably when any ...
Vizio E470VL 47 in. HD-Ready LCD TV Scrolling menu ...
www.fixya.com > ... > Vizio > Vizio E470VL 47 in. HD-Ready LCD TV
Question about Gateway Flat Panel Televisions ... menu stuck on and scrolling TheTV remote control will not operate the TV, and now the menu is stuck ... How to activate the menu choices? try turning tv off and ... Menu Scrolls Uncontrollably.
Dec 25, 2015 | Vizio Televison & Video
At power up, tv scrolls uncontrolably through channels, power light flickers
1. Take remote control far away from tv - 3rd or fourth room. Then switch on tv. If uncontrollable scrolling stops , then cause may be remote button (Ch+ or Ch-) has got dirt inside and its shorting.
2. If taking remote far away doesn't stop scrolling then (Ch+ or Ch-) button on front pannel has shorted. Take a cutter plier and care fully remove button from its circuit board. ( If you know desoldering, it is far better than cutting). If scrolling stops then you can operate channel change with remote.
Jan 27, 2014 | Samsung LN46C600F3FXZA 46in Lcd Tv 1080p...
Won't stop scrolling through channels
This television is defective and either needs a software update or to be replaced.
Dec 02, 2013 | Emerson Lc320em1 TV
Toshiba tv 40rv525u has started to change channels
My TV 40RV525U changing channels, menus itself for few months ( I use antenna).
my son tried to stop the channel scrolling by enter weird number into the channel to stop it scrolling such as 555, 777..
later, it turn on off by itself and unable to hold on a channel
I call Toshiba customer service and they ask money $25 for troubleshooting but I denied since I do not want to waste money and time.
Now, I found how to fix it myself.
In my case, something was wrong with the signal comes from the button control on the left side of the TV.
What I did
unplug the power cord.
Remove back cover.
Look into the motherboard ( biggest green at the center).
First, I disconnect a connector on the motherboard come from the IR board that receive the wireless signal control ( meaning the remote is disable).
I turn on the TV, press on Menu button on the TV side. Menu is still scrolling.
I turn off TV, disconnect power cord and connect the IR connector back to the motherboard.
I then disconnect the nearby connector that comes from the side control buttons.
Turn on the TV by remote, press menu button on the remote to check. The menu stays.
DONE.
I use electric tape to seal off the connector and let it hanging there.
Close the TV back panel
I have been watching TV for 3 nights without menus/channels scrolling.
NO AVAILABLE red message when watching DVD is no longer existed.
Hope this help someone else.
Jan 20, 2012 | Toshiba 40RV525U 40 in. LCD TV
TV keeps scrolling through the channels and won't stop. I cannot use the remote. I have unplugged everything, and I took out the batteries in the remote--nothing worked. To turn off the TV, I have to...
I think one or two buttons on the TV is stuck in and that should be the channel button. Its pressed in that's hy it keeps scrolling.
Disassemble the TV, remove the TV board carefully to get to the channel button, free the stuck button and TV should be okay again.
Note that TV stores a lot of current, so wait a bit before opening the back cover to avoid electric shock.
Good luck.
Jan 01, 2011 | Televison & Video
Toshiba 40rv525r screen says NOT AVAILABLE
I've had the same issue! This is caused by the control panel telling the TV what to do - does it change channels on its own, too, or turn off or on on its own?
What you need to do (if you've not already done it) is lock the control panel out, which you can do under the LOCK menu.
What may help is running the factory reset on page 54.
Mar 22, 2010 | Toshiba 40RV525U 40 in. LCD TV
1.you have to hit the power button multiple times to turn off tv 2.when watching a channel the tv starts scrolling through the channel set up. It eventually stops but then you can't use the remote and have...
Sounds like a tact switch problem at the front of the set. The switches are just behind the front panel buttons. Don't replace just one. Replace them all. They are not expensive and will avoid trouble later. If one switch is getting stuck internally, nothing else will work including the remote.
Oct 15, 2009 | RCA Televison & Video
Mitsubishi WS-65611 tv channels cannot stop scrolling
Check to make sure the channel down button is not stuck. If it is not the button is probably defective. Mits has had a lot of problems with the buttons.
Jan 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Turn tv on, and it scrolls through the channels
Had the same problem, channels would not stop scrolling.
It was as though someone had there finger on the channel up button.
Disconnected the sixth wire, starting with the black wire on the wiring harness for the front buttons, on/off, ch. up/down, vol. up/down, etc.
It works fine, no more unwanted channel surfing!!
Aug 29, 2007 | GE 32GT740 32" TV
Repair
Disconnect the front control board and see if that stops the scrolling. If it does, check all of the small tact switches or the remote sensor. If that does not help, you might have a shorted microprocessor IC.
Jul 06, 2007 | GE 31GT740 31" TV
RCA P52937 52" Rear Projection Television Logo
41 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
