Question about Hoover U6630-900 WindTunnel Bagless Upright Vacuum
Hoover self-propelled u6630-900 reverse not working
I have a Hoover self-propelled model u6630-900 that the reverse doesn't work that good any more. Forward is ok. Reverse grabs a little but not strong enough to push the cleaner. Is there an adjustment to solve this problem?
Thanks
THe forward/reverse lever (made of plastic) possibly is broken. New part is about $10.00
Posted on Jan 10, 2008
I have the Hoover, self propelled vacuum. I have only used the self propel function a few times, but our babysitter used the feature and now the vacuum only works on the highest carpet setting. The middle...
Move the carpet height control switch to a higher position if the vacuum is difficult to push. If the setting is too low for the carpet being cleaned, the brushes press against the floor preventing the vacuum from moving easily.Set to a medium-high height setting then check.Slide the "Self-Propel" button to the "ON" position if the cleaner does not self-propel. -----------
The self-propel feature operates only when the cleaner switch and the self propel button are both ON. ---------- Try this settings and check.This should help.Thanks.Helpmech.
Jun 24, 2011 | Hoover Self-Propelled WindTunnel Bagless...
Self propulsion doesn't work on my upright. Vacuum works fine otherwise
You will need to look @ your owners manual to see where the self propell belt is located i am sure yours is broke and need to replace,- it will not be hard to replace-Lance
Oct 21, 2009 | Hoover Vacuums
Why wont the self propelled brush on the hoover wind tunnel work. large belt is ok. the small belt looks 0k.
no don't do that,have a little patience.check where the self propelled assembly is and see if anything got in there,something might be loose and the teeth are meeting each other.thats a good vavuum.i have 2 but their not self propelled.try taking the belt off the self propelled machanisn and try it again.if it works then something is keeping the propelled machanism from working.dig a little deeper,what do you have to lose?
Mar 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Can't get bottom plate off hoover model
Am a bit confused because I can't find the model number you give on the Hoover website, so am not sure exactly which machine we're dealing with. However, the procedure for removing the bottom plate is common to most self-propelled upright wind-tunnel models, and it's simply a matter of laying the machine flat, turning it over and removing the four recessed screws that hold it in place. It can then just be lifted off. If this doesn't work for you, perhaps you could confirm the model number and I'll try again. It will also help if you say what country you're in. Good luck!
Feb 26, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Self Propelled does not work
if you look below the headlamp of your vac you will find a cable that attach's to a piece called the actuator arm. either this piece is likely broke or the cable itself. always work the power drive smoothly or things will break. also could be that the smooth belt is stretched and will cause the same problem. belts should be replaced every 4 months. good news is all parts above should be under $5. dont let anyone tell you that you need a power drive assy, that usually isnt the case. good luck!!!
Sep 24, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
No suction on Windtunnel 6630-900. All belts work, brush turns, it just won't pick up anything.
Sep 07, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Self propell doesn't work. Motor spins and belt burns, brushes do not turn. model Hoover self propelled u6425-900
may be a stripped sprocket/cog or snapped shaft. check and replace as needed.
Sep 03, 2008 | Hoover Vacuums
How do you replace the forward / reverse cable?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40485&thid=661987 How do you replace the forward / reverse cable?
Posted by HANDYBILL on Jun 10, 2008
I don't know how the end fits back on the replacement cable.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover U6437-900 / U6439-900 Windtunnel Vacuum. There is a hook on the bottom of the vacuum and @ the top by the handle as well. You may what to get a schematic or owner’s manual to see how they hook up because of the newer and different Model #’s for Hoover. The Hoover Self-Propelled works on when the handle is lower to a comfortable position then the self-propelled drive may just need and adjustment. There is a self-propelled rod that controls the self-propelled feature and it either needs adjustment or replacement or the part that hold it may be broken but either one can be fixed. So feel free to contact your local vacuum cleaner dealer with questions. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 10, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
238 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
