Plumbing Logo
Posted on Sep 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Faucet losing water pressure
I have a price pfister marielle 26-4NSS for 2 years now and the water runs very low(getting worse) and I see in the chat room to clean out the deverter valve. I'm trying to get the manual or something to show me exactly where this valve is.
Fred Yearian
Level 3:
  • Master 5,603 Answers
  • Posted on Sep 15, 2009
Fred Yearian
Master
Level 3:
Answers
5603
Questions
Helped
2247423
Points
16162
The FIRST thing is to remove and flush the aereator strainer on the spout.
Check by unscrewing the strainer and run the water. If it is STILL slow, then divertor valve may be clogged.
The divertor is USUALLY in the tower that the spigot pivots in. They are sometimes a little pintle type valve on the side once you remove the pivoting spigot. Handle has to be removed and then a ring that holds the spigot on removed.
When re-assembling use a bit of plumber's grease on the O rings.
3helpful
The top fell off the faucet, doesn't this faucet have a life time warrenty
Price Pfister Marielle Kitchen Faucets Do come with a limited lifetime warranty from Price Pfister-to the original home owner. You can contact Price Pfister on line at www.pricepfister.com, call them toll free at 1-800-PFAUCET or Email. The faucets warranty can be downloaded at http://www.pricepfister.com/support/warranty.aspx.
Low water pressure coming out of faucet. good press at ang stop.
If you just installed it check to see if it has a water saving feature that in some homes and almost restrict all the water force
2answers
Low pressure to the main faucet, great pressure to the side spray
try un-screwing the screen on the end where the water comes out. Could be clogged
29helpful
3answers
I can't disconnect the quick connect sprayer hose Price Pfister
HI, parts can be found from amazon (entire assembly too), take a look here: Amazon com price pfister marielle kitchen faucet parts. Wish you best of luck. Cheers
Fix diverter valve sprayer No water pressure Can I soak in CLR? Where to buy Parts ?
CLR usually works great. Replacement parts are available at Lowes Home supply stores and perhaps Home Depot. I've had better luck getting parts at Lowes.
3helpful
2answers
Water runs slow
Three possible reasons for low pressure. 1. faucet cartridge has debris in valve body. 2. aerator has debris ,just unscrew and clean out. 3. Water valves under sink are not opened up. hope this helps
No water out of kitchen faucet or sprayer
sounds like the little device on end of spout is clogged remove and clean or replace
Top Plumbing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Plumbing Expert? Answer questions, earn points and help others
