Question about Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer
Error code I am receiving an error code cartridge error 1203. I have replaced the black ink cartridge with a new one and still the same error code.
  • 4 more comments
  • Anonymous Dec 29, 2007
    Lexmark x7170 All-In-One displays error: Cartridge Error, Error:1203. It continues to display the error after replacing the old black cartridge with a new one.
  • Anonymous Jan 07, 2008
    changed out cartiadge and still getting the same error code how do i fix it?
  • lcb28458 Mar 09, 2008
    Cartridge error 1203. Checked cartridges, all ok. powered off and back on. still get error message. won't print.
  • qyuckshort Mar 11, 2008
    I have replace the black cartridge
  • Anonymous Mar 14, 2014
    Code will not clear after replacing black ink cartridge and restarting printer several times.
  • Anonymous Mar 24, 2014
    replaced black ink cartridge and received above error message
    Problem Solver:
  • 4 Answers
Well I have had the same thing happen.on the left only use 31[photo]; 32; 34....on the right33; 35..left takes black or 31 photo....right color cartridge only
Posted on Dec 20, 2007
I have the Dell AIO 926 and i have an Error Message. Error 1203 Consult User's Guide I cannot print, what do i do?
error 1203's error name is print head short which indicates a short circuit in the print head has occurred. solution to this problem is to disconnect and then reconnect the printer power cable. Reinstall the ink cartridges.For more information, see Replacing Ink Cartridges.
  • Turn on your printer.
  • Lift the printer unit, and then position the scanner support between the tabs to hold it open.
  • The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  • Press down on the ink cartridge lever to raise each ink cartridge lid.
    Remove the old ink cartridges.
  • Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them properly.
  • If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
    NOTE: The following illustration shows a black cartridge and a color cartridge (used for normal printing). For photo printing, use a photo cartridge and a color cartridge.
    Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.
    Snap each lid closed.
    Hold the printer unit up, push the scanner support back to unlock it, and then lower the printer unit until it is completely closed.
  • Jun 05, 2011 | Office Equipment & Supplies
    Cartridge Error # 1203 when replacing black ink cartridge
    It sounds like the printer thinks it is not a genuine ink cartridge. Fit a Lexmark cartridge to cure it.
    Jul 16, 2010 | Lexmark X8350 InkJet Printer
    1203 error code
    Solution to get rid of error 1203 on printer 926 is
    Disconnect and Reconnect the Printer Power Supply
    1. Unplug the power cord from the wall socket.
    2. Disconnect the power supply from the back of the printer.
    3. Wait 15 seconds.
      Reconnect the power supply to the back of the printer.
    4. Plug the power cord back into the wall socket.
    Try a Known-Good Ink Cartridge in the Printer Replace each affected cartridge in the printer with a known-good cartridge and check to see if the problem is resolved.
    This error comes up because the copper contact of the cartridge is not able to communicate with sensor of the printer.
    Jun 08, 2009 | Dell 924 All-in-One InkJet Printer
    Displays Error Code 1203 - What is that? User Manual is lost.
    The error 1203 error message on the operator panel could indicate a problem with one of the ink cartridges. Please follow the steps given below:
    1. Please make sure the All-In-One is powered on.
    2. Pull the control panel towards you, and then open the cartridge access door. The print cartridge carrier moves and stops at the loading position.
    3. Pull the old cartridges towards you, and then lift them out.
    4. With the cartridges out of the printer, shut the access door and the control panel.
    5. Power the printer OFF and then back ON.
    6. Please check the operator panel to see if the same error has returned or if a new message has appeared.
    7. If the message displayed is 1203, there is something wrong with the printer hardware.
    If the message now displaying is Cartridge Missing, do the following:
    1. Reinstall the cartridges into the printer.
    2. Insert the color cartridge in the left carrier. Insert the black cartridge in the right carrier.
    3. Push back firmly on the cartridges until they snap securely into place.
    4. Close the cartridge access door, and then close the control panel.
    5. If the 1203 message is still present on the operator panel, you need to insert one cartridge at a time to determine which cartridge is producing the failure.
    6. With one cartridge in the carrier, close the access door and control panel.
    7. Please check the operator panel. If the 1203 error is displayed, this cartridge is the defective item. If the Cartridge Missing message is displayed, the second cartridge is producing the failure.
    8. Please replace the defective cartridge.
    May 05, 2009 | Lexmark X7170 All-In-One InkJet Printer
    Finding error messages
    Yes ok try and try.
    Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
    1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
    or
    2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
    Oct 08, 2008 | Dell 962 Photo All-In-One InkJet Printer
    Error message 1203
    This link should have the answer for you.
    http://www.dellcommunity.com/supportforums/board/message?board.id=A940&message.id=13761
    Jul 27, 2008 | Dell 924 All-in-One InkJet Printer
    Error code # 1203
    Error 1203 is basically a cartridge error. Try cleaning the contacts on the cart & in the cart carrier, reseat the carts & then power off the printer. while holdin down the stop clear button, rebrick the power chord.
    Jun 30, 2008 | Lexmark X4270 All-In-One InkJet Printer
    Dell 942 Error 1203
    Error 1203 occurs either when a cartridge is bad or the printer cartridge Slot is bad... I would suggest you to try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
    If that doesn't work just call up their support number and check for replacement..
    Apr 08, 2008 | Lexmark P315 InkJet Photo Printer
    Cartridge error
    How I solved this problem was, I took out the color cartridge (which seem to be the one giving the error message) and worked only with the black ink (and chose print black and white )
    My color ink cartridge had been refilled at Walgreens. The Black ink cartridge is an original Lexmark
    Oct 22, 2007 | Lexmark X3480 InkJet Printer
    Error #1203
    Normi, The 1203 error as you suspected deals with the ink cartridge. This is a common problem and Lexmark has a troubleshooting procedure posted on their web site. Here is the link for the web page. http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:439:0:0&emeaframe=&docid=ENUS21870 Hope this solves your problem and please don?t forget to rate this posting.
    Jan 20, 2007 | Lexmark X4270 All-In-One InkJet Printer
    Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer Logo
    447 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
