Question about Intel D101GGC Motherboard
Chaintech Motherboard NO SCREEN
Chaintech motherboard unknow model
AMD Athlon 64 socket 754
I've had this system up and running without a problem for over two years now. Today i was just restarting this system and i could get it to reboot. The fans and dvd drives will come on but it makes no beeps, has no signal to the screen, and doesn't seem to boot at all.
  • greggles_04 Dec 12, 2007
    I've try all the above but switching the video card
  • godgiri Dec 24, 2007
    my motherboard is a 845 GVM-RZ.when i installed a 1gb ram in one of the slots there is no display at all on the desktop and the board does not beep.the machine worked fine with a 128MB ram in one of the slots.i have checked the 1 GB ram on another machine,it worked fine...please help me,as per specifications 845 supports a maximum of 2GB ram
  • 36 Answers
Unplug the power. Then start with only the items you need to boot. Remove any cards that might be causing an issue, if you can't simply find the culprit of your boot lock issue. This sounds like a card or some RAM or something isn't quite plugged in. If your power supply still gives power to the system check to see if the fan on the power supply died. This could mean you need a new power supply if the old one overheated and cooked itself.
Sometimes you will get a card that is half plugged in and it will cause a short and the system will not fully power to avoid ruining the motherboard completely. After re-seating all the cards, try to boot it again. Check ALL connections and look for any USB connection that might be stopping the system from booting as well.
If you have a different video card you may want to try it next if you still can't get video.
Hope that helped out...
Posted on Dec 12, 2007
Motherboard need for ada3000aep4ax processor
Aug 04, 2011 | AMD Athlon 64 Processor 3000+* (2.0GHz)...
Can you tell me why when i put CPU in my computer he give error? CPU is AMD Athlon 64 3400+ 2.4GHz socket 754.My motherboard is socket 754 Gigabyte GA-K8NE-RH. Problem is my computer or CPU?I take CPU...
The motherboard will support this CPU, with the F1 bios.
I can only advise, that IF your motherboard was working ok before you put the new CPU in, it must be the new cpu you bought.
If this is the 1st CPU you have tried, there is a chance the board is damaged
Jun 13, 2011 | AMD Athlon 64 3400+, 2.4 GHz...
I am using ASUS K8VMX motherboard with AMD Athlon 64 2800+ motherboard. Now my motherboard has gone bad. I want to change it. Suggest which motherboard should i use (754 socket)
Whatever board that is in a microATX format and has a 754 socket will do - they all had the same general hardware characteristics and requirements - so get the cheapest you can find.
Apr 17, 2011 | AMD Athlon-64 2800 CPU and Mother Board...
Can i use AMD 64bit 3800+ in MS-7142 Ver 1.0 motherboard.
AMD 64bit 3800+ is Socket 939 and MS-7142 Ver 1.0 motherboard is socket 754
Nov 11, 2010 | AMD Athlon 64 X2 5200+, 2.6 GHz
I am using amd sempron LE-1100 i want to upgrade to a gaming pc so that i can play the sims3. so if i like to upgrade to amd athlon x2 how to know my socket type. please help
Your socket is AM2. You can put any AMD processor that has AM2. If the processor is AM3 just upgrade the bios of your motherboard and it should work. If you need further assistance, just leave a comment. Cheers
May 24, 2010 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Can I put a dual core processor on my Chaintech S1689 mother board--Athlon 64 FX w/ 939 socket? I don't think my CPU fan is working and I need to replace it.
Form Factor: ATX (305mm x 200mm)
CPU: Supports Socket-939 Athlon 64 / Athlon 64 FX and Dual-Core (X2) / Sempron with the new v6.0 BIOS and above. Processor interface via 2000MT/s HyperTransport bus.
Chipset: ULi M1689
Main Memory: Four 184-pin DDR DIMM up to 4GB Supports Dual Channel DDR266/333/400 memory.
Expansion Slots: X4/X8 AGP Slot and Five 32bit PCI Slots (v2.2 compliant)
Audio: Realtek ALC850 with 8 Channels
SATA: Supports 2 Serial ATA devices for the highest data transfer rates (1.5Gbps burst) with RAID 0 & RAID 1 solution.
UltraDMA IDE Ports: Supports 2 UltraDMA-66/100/133 IDE ports
FDD: One FDD connector supports up to 2.88MB
USB 2.0: Supports total 8 USB2.0 ports with High-Speed Devices at 480 Mb/s Transfer Rates
System monitoring: Two Temperature and Fan Sensors for CPU and System
Jun 01, 2009 | AMD Athlon 64 Socket 939 Chaintech S1689...
Cpu upgrade
According to the spec sheet on the MSI website, this motherboard will take up to a 3700+ Athlon. Check out the link:)
Further testing is being done on this board, but here is the UPDATED CPU compatibility chart:)
Dec 30, 2008 | MSI K8MM-ILSR (MS6741030) Motherboard
Biostar offers NF61S MICRO 754 Motherboard + AMD Mobile Athlon 3200+ (COMBO56), NF61S MICRO 754 Motherboard + AMD Mobile Sempron 3300+ (COMBO56A),NF61S MICRO
Motherboard Processor:
Socket 754
Supports AMD Athlon 64/Sempron Processor
Support AMD HyperTransport up to 1.6G
Supports AMD Cool'nQuiet Technology
• Chipset:
NVIDIA MCP61S(GeForce 6100/nForce 405)
they are the same motherboard .hope this helps pls appreciate by rating it as fixyaa
Oct 10, 2008 | Computers & Internet
Plz help me out...problem in assembling AMD Athlon 64 processor in KVM800M board
There is no fix for that. You need a board that is the same as the original because that is the size of the processor. If that is a socket 462 processor, it is only designed and will only run in a motherboard with socket 462 on it. You need to either replace the processor or replace the board with the correct one.
Jul 03, 2008 | Mercury KVM800M Motherboard
Intel D101GGC Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
