Question about Refrigerators
ICE MAKER NOT WORKING
Refrigerator Model # ESH25XGRE CC Serial MG248338
DOC # on Ice Maker 200D1181G011 WREoX10012
Ice Maker is not producing any ice the maker has a switch on it and I have shut it off and turned it back on after an hour of so.  Could the filter  have anything to do with it or could there be a frozen line? Please Help Noreen
  • Anonymous Feb 08, 2008
    The Ice maker is clicking but not cycling like it normally does when it is getting ready to dump the ice cubes. There is no water in the ice cube tray, the fan behind the ice maker is not running. The shutoff switch for the ice maker is in the on position, ie, the tray is near empty. I moved it from off to on, no joy! I unplugged the fridge and then plugged it back in, no joy. This fridge is 20 years old and is a side by side, ie, ice maker/freezer compartment and the water dispensor is in the L/H side of the fridge. No filter on the ice maker inlet water line that I am aware of. Even with the door open, the fan will not start. It is free to turn.
  • Anonymous Mar 21, 2014
    have 30cm model
    out complete
    have power at controller but not turning on anything
Filters are a main problem with any kind of ice makers big or small...if filter is plugged up. Water can not reach ice maker and this will be main problem especially if you live in a high mineral deposit area. Change it if its been awhile (live since you moved in).
Posted on Dec 13, 2007
It making a noise and the ice maker stop working
Thank you for your inquiry, Joann siefert!
I see that your Frigidaire refrigerator is making noises and no longer producing ice. Have you attempted to replace your water filter? If your filter is bad that could cause ice to stop producing. I would recommend changing your water filter to see if that would help correct your issue. The noise could be a normal operating noise. If you have your manual you can look inside for normal operating noises. If you need your manual could you please provide me with your model number? You can locate the serial tag (which lists your model number) on the inside wall of your refrigerator. With that information I can further assist you. -Matt
Jan 23, 2015 | Frigidaire Refrigerators
I need a replacement ice storage drawer for an ice maker DR# 200D1181G011, WR30X10012 Model CAN13
There is an appliance parts store in every town and give em that number and they can get it or match it up
Jun 23, 2011 | Refrigerators
Ice maker did not produce ice, then it started to
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Aug 24, 2010 | Amana ARB2557CW / ARB2557CB / ARB2557CC...
The ice maker on our GE refrigerator does not make ice
1 -Ice maker arm must be down(on position)2-Make sure the water supply line is connected to the fridge3Check if the ice maker is plugged in4The freezer must be working fine for the ice maker to produce ice. After the ice maker stars and calls for water and doesn't get any , the water valve is bad.And if everything above is ok the ice maker needs to be replaced.
Apr 26, 2009 | GE Refrigerators
Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Apr 14, 2009 | Kenmore Refrigerators
I changed the filter and ran some water thru the machine and still no ice , it sounds like it will work ,but no ice? what can I do? my email is jbgately@frontiernet.net, thank you joe gately I have a ,...
Hi
If the ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Mar 29, 2009 | Refrigerators
Ice maker not making ice refrig.model#gsc23kswc ss
Check the following suggestions from repairclinic:
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Oct 10, 2008 | GE Refrigerators
Hotpoint Ice Maker Stopped Making Ice
Friend,
ngfam1 At your service!
I came to your service on fixya.com some days ago!
And gave you some good advice!
But, I did not receive a rating from you yet!
Can you please give me a rating at our fixya.com site!
Bless, You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Jul 04, 2008 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
619 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
