Question about Mitsubishi VS-60703 60" Rear Projection Television
No power on
I do not have any power on the TV, no light comes on. This was bought in 1998. Wonder what is the average life of this TV. I have checked the power point, it is connected to a power strip, everything else on the strip is working....need help!
I have a 1998 VS-60703, picture and sound went out, and do not come back on either through remote or tv button.
    Scholar:
  • 54 Answers
Hey cmdolfan,
Seems like the picture tube on the TV decided to go on you.
But it seems like the power itself is shot.
Try doing a hard rest on the TV (a lot of models have it where you unplug it for 4 hours), and then even try just pluggin it straight into the wall rather then the strip just to make sure.
If this doesn't work, then there really doesn't seem to be a lot more you could possibly do since it isn't getting power what so ever.
I would suggest contacting a local repair service.
Posted on Dec 12, 2007
Tv will not power up although power light comes on then turns red
Does the light blink or is solid red? If not I would first remove the lamp and examine it to see it is not shattered or damaged inside.
Lamp can look ok and be bad--about only sign is sometimes just before it fails the picture will take longer to come up or is darker.
Lamp life averages 2000 hours or 2 years---less if a generic or NON Sony lamp is used.
When was lamp last replaced and generic or?
Dec 11, 2012 | Sony KDF-E42A10 42 in. LCD Television
Lamp light is flashing...tv will not come on
Bad lamp or ballast which powers it or you name it in these sets, The lamp and ballast are the places to look first.
Lamp on average has two thousand hour life span which is about two years.
Apr 04, 2012 | Mitsubishi WD-62825 62" Rear Projection...
Resetting lamp life
was the button sequence given (set off) display,5, volume up, then power?
Mar 21, 2012 | Sony Grand WEGA KDF-55XS955 55" Rear...
My Mitsubshi DLP TV has a very weak lamp that comes on but does not stay on. Is the lamp the problem?
it is very possible the lamp is the problem but the only way to know is replace it.
Average life span is about 2000 hours which for average viewer is two years.
Mar 13, 2012 | Televison & Video
Tv on my samsung p4663w/hl does not turn on. lamp light flashes on front of tv picture does not work. no sound , bulb has no marks on it to show that it is bad
Tv projection lamp have a life span like any other bulbs light sources.Tipically life spans of these tvs projection lamps are around 20,000 hrs of useages.That average out like about 1 1/2 or 2 years and around 4 or 5 hours of the tv is on and watching it everyday.Now the front tv bazel frame of the tv.The word "LAMP" LED light indication is on or flashing are indication of the tv projection lamp life span are over and the tv must have it projection lamp to be replacement to another tv projection lamp.Projection Lamp fillerments tipically dies out when it reaches it life span.Mark or burns on the projection Lamp,will not show or be there,if the tv projection lamp run it natural life span cycles.
Aug 03, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
Bought Samsung dlp h-l 5667w new in 2005. Replaced lamp, fan, and color wheel in 2008. Now lamp lights up and lamp indicator on front lights up, fans turn on, but tv picture will not show. After a few...
It time to replaced the tv projection lamp again,the tv projection lamp life span have ended.The tv projection lamp life span only last 2000 hrs.Average out like 1 1/2 or 2 years max for tv on watches 4 or 5 hrs of tv every days.
Jul 07, 2011 | Samsung HLR5667W 56" Rear Projection HDTV
When i power up the tv, it immediately shuts off
How old is the tv? Sounds like the bulb. Is there any kind of lamp light indicator blinking or on? Averager life of a bulb is a few years, but could very well be shortened. Also check any surge protectors you might have. Maybe you recently had a surge and it needs to be reset. Last but not least try recycling the power on the tv. Unplug for 10 seconds then plug back in. happens a lot with cable boxes, recievers, and tv's from time to time.
Mar 17, 2009 | Mitsubishi WS-65807 65" Rear Projection...
TV Turns self off- 4 blinks on standby light
Yes, the blinks are error codes. I would not bother trying to figure out what they mean, I can tell you right now. Expensive repair. Average repair costs are 1/4 to 1/2 of the TV's current worth. Most likely a bad transistor. The average expected life span of a TV set is 3-5 years. After that, stuff starts wearing out fast. Time to move on.
Nov 14, 2008 | Sony KV-28FX60 28" TV
Sony KDF-46E2000 - Screen Goes Blank
You definitely have a bad lamp. Sony rates the lamp life at between 4000 and 8000 hours. There are 3 things that effect the lamp life, listed in order of importance:
1) number of times the lamp is turned on and off. Every time the lamp is first fired, it takes life off the lamp. Customers I see that turn the TV on in the morning, leave it on all day and then turn it off on the evening can get up to 12000 lamp hours
2) ventilation. Be sure you have at least 6 inches of open space all the way around the set and that the vents are clear of dust and debris.
3) power. If the power is interrupted when the set is on, there cannot be a proper cool down cycle. The fans will run after you turn the set off to properly cool it down, if the power is lost this cannot happen. If your power is unreliable, buy a small UPS to let the set finish a cool down cycle
Occasionally a lamp will faill before the average lamp time due to being defective. from your purchase date it sounds like you got about average lamp time. Be sure to purchase AN ORIGINAL SONY LAMP as a replacement, becuase the aftermarket lamps are bad news, Be sure to rate this solution. Thanks!
Oct 13, 2008 | Sony KDF46E2000 46" Projection HDTV
No power on
Do you hear a click when you press the power button?
Nov 17, 2007 | Mitsubishi VS-60703 60" Rear Projection...
Televison & Video Logo
83 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
