Question about GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket
NOTICE A PROBLEM HAS BEEN DETECTED WITH THIS UNIT- GE HAR WASHER
I did a test and it said "the motor is not rotating properly" check or replace motor.
Do I really need a new motor? What should I check?
Thanks!
  • 1 more comment
  • CHICALY Jan 20, 2008
    UNPLUG THE WASHER
  • JUNIORPG Jun 15, 2008
    MY WASHER STATES TO CHECK THE MOTOR FOR ROTATION OR REPLACE SHOULD I REPLACE MOTOR
  • francis rivero May 11, 2010
    does it indicate any kind of error codes rather than that comment?
  • 725 Answers
There are 5 solutions for this problem
1) house voltage (voltage to low)
2) Inverter
3) Motor (if motor only turns in one direction)
4) wire connection to the low voltage
5) Hall sensor at rotor (only turns a 20% of speed)
let me know if I can help you more...
Posted on Sep 13, 2008
I have a GE washer model WHRE5550K2WW. we had a power surger which stopped the wash completely. I replaced the curcuit board behind the control switch witch the allowed the machine to fill,but would not...
Built into the wire harness from the machine control to the inverter board for the motor is a fuse..saddly the only way to replace the fuse is replace the wire harness
GENE
Sep 08, 2011 | GE WHRE5550K Top Load Washer
I get an F11 error. Washer will not start in any mode.
GHW9150P Tech sheet:
FH: If after 30 seconds the control does not detect water entering
machine, the valves will be turned off and the error code will be
displayed. OR If the control has turned the water valves on and after
8 minutes the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
-Make sure that both valves at the water source(s) are turned
on all the way.
-Check for plugged or kinked inlet hoses or plugged screens in
the inlet valves.
-Verify inlet valve operation.
If there is water in the unit:
-Verify drain pump operation.
-Verify that the pressure switch hose is in good condition and
properly connected to tub and pressure switch.
1. Verify there is not a siphon problem.
2. Unplug washer or disconnect power.
3. Verify wire harness connections to inlet valves,
pressure switch, drain pump, flow meter, and
Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and
measuring the resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle.
F-2 Long Drain
If the drain time exceeds eight minutes, the water valves are turned off
and "F/02" is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the "Sud" error will be displayed, then four
minutes later the "F/02" error code will be displayed.
1. Check the drain hose and make sure it is not plugged
or kinked.
3. Check the electrical connections at the pump and
make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
F-5 Water temp sensor failure
If during the water heating step in the wash cycle, the water
temperature sensor (NTC) value is out of range, the "F/05" error code
will be displayed. Possible cause/proceedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Refer to the
"Water Temperature Sensor" section. Check
connections to the water temperature sensor.
3. Check resistance of heating element, if present on this
model. (abnormal = infinity)
F-06 Drive motor Tachometer error
Possible causes/procedure:
1. Verify the shipping system including shipping bolts, spacers
and cables are removed.
3. Check wire harness connections between the drive motor and
the Motor Control Unit (MCU), and between the MCU and the
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations.
F-07 Motor control unit error
Possible causes/proceedure:
2. Check wire harness connections between the drive motor and
3. Plug in washer or reconnect power.
4. Check the MCU by looking for operations of the drive motor.
5. Check the drive motor for powered rotations.
F-09 Overflow Condition
or kinked.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Check for drain pump failure.
6. Check the inlet valve for proper shut off.
7. the pressure switch for proper operation.
F10 Motor control unit heat sink thermal trip
1. Check for proper installation, verify the unit is not located
near a source of heat and has proper ventilation.
3. Check wire harness connections to the MCU, the motor,
4. Check the drive system for any worn or failed components.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
F11 Serial communication error
Communication between the Central Control Unit (CCU) and the
Motor Control Unit (MCU) cannot be sent correctly.
2. Check wire harness connections to the MCU, the motor, and
3. Check the drive system for any worn or failed components.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors.
F13 Dispenser circuit error
2. Check mechanical linkage from dispenser motor to the top of
the dispenser.
3. Check wire harness connections to the dispenser motor and
4. Check dispenser motor for powered rotations.
F14 The dreaded EEPROM error
The Central Control Unit (CCU) receives its data from an EEPROM
onboard the CCU. If there is an error reading this data it will cause this
error. Possible causes/proceedure:
¦ A power glitch may cause this error.
1. Unplug washer or disconnect power for two minutes.
2. Verify CCU operation by running a Diagnostic test or any
cycle.
F15 Motor control unit error
If the MCU detects multiple resets or errors during a wash cycle it will
go into this error mode. Possible causes/proceedure:
3. Check drive belt.
F21 F 22 CCU /touchpad/LED assembly unable to transmit/receive data to/from the CCU central control unit
1. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
touch-pad/LED assembly and Central Control Unit (CCU).
F du Door unlock error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to
unlock the door 6 times before displaying the error code.
¦ Door lock mechanism is broken.
¦ Door switch/lock unit failure.
1. Check door switch/lock unit for foreign objects.
3. Check wire harness connections to the door switch/lock
unit and Central Control Unit (CCU).
NOTE: The door switch/lock unit can be manually unlocked. See
"Manually Unlocking The Door Lock System".
F dl Door lock error
A Door Lock Error occurs if the door cannot be locked. It will try to lock
it six times before displaying the error code.
¦ Door lock mechanism is broken or removed from door.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door
switch/lock unit and Central Control Unit (CCU).
Sud: Suds lock (overdose of detergent detected during wash cycle)
The motor control unit senses a suds lock condition by analyzing the
current draw on the drive motor. If "Sud" is displayed a potential Suds
Lock is detected. This may signify a bad pump, an extra heavy load,
excessive detergent, or excessive suds.
¦ If too much detergent was used:
-Run the unit through a Rinse/Spin cycle.
-Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
or kinked.
6. Check drain pump.
7. Check the pressure switch.
cycle.
Tech sheet link:
https://servicematters.com/secured/docs/wiring/Tech%20Sheet%20-%208182277.pdf
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
07f error code... duet washer W9150
Tech sheet on this model:
on all the way.
the inlet valves.
F-2 Long Drain
display.
or kinked.
or kinked.
cycle.
MCU connectors.
the dispenser.
cycle.
or kinked.
cycle.
Tech sheet link:
Jan 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
This is the second time this problem has occurred. The machine simply won't fill. The door locks and then nothing. Last time it resolved itself after about 4 hours. This time it's been overnight and...
You could check your inlet hoses for kinks You inlet screens on the valves for clogs.themobilian_473.jpgthemobilian_474.jpgall this stuff you can do a filter clean out as shown HERE
Your tech sheet info:
on all the way.
the inlet valves.
F-2 Long Drain
display.
or kinked.
or kinked.
cycle.
MCU connectors.
the dispenser.
cycle.
or kinked.
cycle.
Tech sheet link:
Dec 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My duet front loading washer has a code 06. When I turn off and unplugged for 1 min. then tried to start it again, it started filling with water then stopped and started beeping the code again. I did this...
This is a Drive Motor Tachometer Error. The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
Make sure the wash load is not too heavy and do not move the washer when it is powered on.
If the error persists then the normal process is to check the following:
  1. Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
  2. Check the Drive Motor.
  3. Check the MCU
  4. Check the Wire Harness
Nov 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Code flashing F 06 wont spin
The code F06:Drive motor tachometer error happens when the control unit is unable to properly detect motor speed.
If you are planning on doing this yourself then in order to troubleshoot this you will need to remove the back panel to gain access to the motor and wiring harness.
Check the motor by turning the pulley. If the motor does not turn smoothly then it's most likely a bad motor. If this seems ok inspect the wiring harness for any broken or loose connections. It's a good idea to unplug and then reinsert all the connections between the board and motor. This helps clean any corrosion that may have built up on them.
If your still having problems then the MCU (motor control board) may need to be replaced.
I hope this helps.
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
What does the F6 code mean
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after three minutes.
Possible Causes / Procedure
1. Verify the shipping system including shipping bolts, spacers and cables are removed.
3. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
Replace failed component.
Oct 07, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
When it gets to wash cycle f06 comes up and it won't continue to wash
Hi. This is a Drive motor tachometer error
Oct 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Receiving error message F06. The cycle stops. The only way to restart is to power off and on?
Replace failed component.(Motor Control Unit)-(MCU)
Sep 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer drum won't rotate, can't rotate manually
How are ya? This is kind of technical information that i'm about to give you, so if you're not that technical then you should call a service technician to diagnose. Good luck and thanks for the inquiry :)
F25
DRIVE MOTOR TACHOMETER ERROR
If the control is unable to properly detect motor speed, the machine shuts down.
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
Possible Causes/Procedure
1. Verify the shipping system including shipping bolts, spacers and the power cord are removed.
3. Check drive motor tachometer resistance. It should be approx. 115 ohms.
4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
Aug 08, 2009 | Whirlpool WFW9200S Front Load Washer
GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket Logo
490 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
