Question about Mitsubishi WS-48613 48" Rear Projection Television
Mitsubishi VS-50705 TV has error code 23, Horizontal Deflection won't turn on.
Ctf1800 told me to check the error code & it is 23=Horizontal deflection failure. What should I do now? Can I fix this myself easily? I don't want to spend hundreds of dollars on a technician. The Tv's only worth like $200 now. Please let me know if there's anything i can do!
Thank you!
  • Anonymous Mar 16, 2014
    Tv turns off randomly. I checked the error codes and got a 23. How do I fix this?
  • 87 Answers
Unfortunately, problems in the deflection circuit can involve expensive parts. This type of repair is not for the do it yourselfers. It requires proper test equipment and diagnostic experience. Look to spend at least $350 and up. Maybe Santa will bring you a new plasma for Christmas. Good luck
Posted on Dec 13, 2007
I have a mitsubishi hd 1080 65315 model and the code is 23 what is the problem.
Mitsubishi TV Shutdown Troubleshooting - Stereo & Video ...
For example, the sequence: blink-blink, pause, blink-blink-blink, indicates an error codeof 23. This sequence repeats 5 times, so you can figure out if you are ...
Mitsubishi VS 50705 error code 23 - Service manual, repair and ...
Oct 24, 2010 - 10 posts - ‎4 authors Tv is old about 10 years. Shows error code 2-3 horizontal deflection failure. A few years back had a leaking crt, replaced the caps recomended ...
Oct 19, 2015 | Mitsubishi Televison & Video
I own a Mitsubishi HD 1080 series HD TV; MODEL#VS-50111. Recently the TV shut itself off after a few minutes of operation. I unplugged it and after a few hours, plugged it in and it came on for about 5...
I believe it is going to be a major repair and I would hesitate to invest much money into it. I think the age of this set is older than 5 years. The VS model series were manufactures before the WS model series and they have been around for 8 years or so. Never the less, parts availability is getting tougher. If your pain thresh hold is 300.00 or 400.00
go for it. If not, check out new sets.
Hope this helps,
Sky Assoc
Oct 22, 2009 | Mitsubishi VS-50111 50" Rear Projection...
Ws-6580 error code 23
12 / No error has occured
21 / X-Ray Protect Shutdown
22 / Short Protect Shutdown
23 / Horizontal Deflection failure
24 / Vertical Deflection failure
Aug 06, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi 50111
Run the diagnostics.
With the TV power cord plugged in, press the 'INPUT and 'MENU' buttons at the same time -- use the buttons on the front of the TV, NOT the buttons on the remote; a diagnostic Error Code Operational Check will begin, utilizing the 'POWER ON' LED (the green 'POWER ON' indicator light).
There will be a pattern of two sets of flashes, with a pause in bewteen flashes; this sequence of flashes will be repeated a total of five times.
The Error Code designations are listed below:
Error Code Description
12 No eror has occurred.
21 X-Ray Protect circuit.
22 Short Protect circuit.
23 Horizontal Deflection failure.
24 Vertical Deflection failure.
I hope this information helps.
Jun 17, 2009 | Mitsubishi VS-50111 50" Rear Projection...
Vs-50607 turns off by itself it might come on after about 8hrs
if you hold menu and input on the front panel it will blink a code to tell you
where the error likely is. hold the buttons for 5 seconds and you'll get a 2
digit error, like 1 2 = no error..
“12” ... indicates no error has occured.
“21” ... X-Ray Protect circuit.
“22” ... Short Protect circuit.
“23” ... Horizontal Deflection failure.
“24” ... Vertical Deflection failure.
let me know what you find.. it will determine area of failure
Jan 08, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Tv turns on then off
hold the menu and input buttons simultaneously for 5 seconds. the tv will blink an error code
Error Code Probable Cause
12 Normal Operation - No Error Detected
21 X-Ray Protect
22 Short Protect - likely convergence IC failure
23 Loss of Horizontal Deflection
24 Loss of Vertical Deflection
Fast Blink for 70 sec. After AC is applied = Normal - DM μPC is booting up
Fast Blink (doesn't stop) After AC is applied = TV μPC is running, but DM failed to boot up
Slow Blink Set is Off = Normal - Timer is set for Automatic Turn ON
Dec 05, 2008 | Mitsubishi WS-55511 55" Rear Projection...
I have a mitsubishi ws 65807, i get trouble code 23
The problem is most likely convergence integrated circuit failure. I recommend finding a local Mitsubishi repair center.
Dec 05, 2008 | Mitsubishi WS-65908 TV
No Power
Good Day, PCMcGee; To start try these: This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB. Good Luck, big IRISH.
Jun 21, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi 50605
Code 23 means horizontal deflection failure. Check your horizontal output transistor. Or the horizontal drive transformer solder joints as well as the horizontal yoke pin connections for bad sloder.Hope this helps. if I can be of further assistance let me know
Jan 12, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50705, 50 inch Rear projection TV won't turn on!
most of the time the convergance ic go bad:
but try this:
The 3 flashes of the led when you plug the unit in is the
microprocessor initializing.
This unit has an error code diagnostics.
On the front panel of the unit press and hold the INPUT and MENU
buttons at the same time and hold them down for about 5 or 6 seconds.
The unit should activate it's error code mode.
The led will flash count the number of flashes. It will then pause for
1/2 or 1 second. The led will flash again count the number of flashes.
The unit will repeate this for about 5 or 6 times.
You now have the two digit error code. The first time the led flashed
is the first number of the error code, the next time the led flashed is
the last number of the error code.
12 ----------- indicates no error
21 ------------- X-Ray Protect circuit
22 ------------ Short Protect circuit
23 ------------- Horizontal Deflection failure
24 ------------- Vertical Deflection failure
Most units give a error code "22" short protect circuit. If so check:
If Q5A00 check bad there are other parts that have to be checked or
If you are able to do above call a tech to service the unit
Dec 11, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Mitsubishi WS-48613 48" Rear Projection Television Logo
1,199 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
