Question about LG WM-1832C Front Load Washer
Lg wm0532hw front load washer
I need to replace the gasket. where can I get a service manual?
  • Anonymous Mar 31, 2008
    I have no power. I think that there is a blown fuse somewhere.
  • Anonymous Mar 23, 2014
    installation of plenum gasket on maytag front load washer
LG wm0532hw, can not turn on washer, it's not the plug, i try to reset it by unplug for 2min then plug it back. help
Posted on Jan 08, 2008
Could it be the switch?
Posted on Jan 09, 2008
Lg Tromm front loading washing machine. Model # WM0532HW.I keep getting the UE and IE codes. Also makes alot of noise in the spin cycle....warranty is done....should I not bother & get another
IE: Water level (246) was not reached in 8 minutes
UE: Imbalance: Load too small, too large objects between tubs
OE: Drain problem took longer than 10 minutes to drain
FE: Overflow issue drain pump running to comp
PE: pressure sensor (sensor out)
dE: door error. open door. switch is out
LE (with a a slash in the
middle of L. Upside down F) Thermistor out
CE: Over amping Too much soap wrong soap
LE: hall sensor shorted/destroyed from sudslock
bE: Ball sensor loose connection/out of order
EE: eeprom out test mode only
PF: power failure momentary interruption of shocktricity
Service notes and manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 23, 2011 | LG WM-2277HW Front Load Washer
Need to remove old Door Boot/Gasket & replace new one. How do I proceed?
Hi
Please check this service manual for your LG WM2487 washer if you want to do this yourself. Hope this helps...please post back for further assistance.
Daniel
Jul 21, 2011 | LG WM2487H Front Load Washer
Hi, we have a lg wm0532hw tromm front loader washer, the latch on the door seems to be broken, it slides all the way back into the door frame and washer will not lock. Can this be fixed? thank...
I'm sure it can but you will need to call a local service engineer to do it. Sorry we cannot call one for you.
John C
Mar 10, 2011 | LG WM-0532HW Front Load Washer
Needing a part# for the door gasket on my lg wm2016cw front load washer. we bought it used and the seller didn't have the manual.
I have this washer, and the owner's manual. There are no part numbers listed anywhere. I need to replace my door gasket as well :(
Feb 07, 2011 | LG WM-2277HW Front Load Washer
Lg tromm front loader washer wm0532hw shows oe error
that's draining error. check the filter cleanout behind lower left panel on front of machine; of course drain 1st via small drain hose. if thats o.k the drain pump itself may be jammed with debris or the drain hose could be clogged.
Jun 24, 2010 | LG WM-2277HW Front Load Washer
Drum on LG front load washer does not turn.
something is caught in between the two tubs.and that is no fun! call the tech.ps there is no belt on most lgs.
Aug 07, 2009 | LG Washing Machines
"le" on the LG WM0532hw front load washer errror
try unpluging for 45 seconds than hold in the selector knob for 10 sec. & plug back in
Feb 02, 2009 | LG WM-0532HW Front Load Washer
LG front load washing machine will not spin
I am having the same problem with my washer. Go to this web site below it has a free troubleshooting guide. I narrowed my washer machine down to two parts. Stator assy or Main PWB assy.
http://136.166.4.200/contents/Laundry/WM2042/WM2042xx_Service_Manual.pdf
Oct 10, 2008 | LG WM-1832C Front Load Washer
Fron t Load washer will not unlock
Usually, the door will not unlock because there is water still inside the unit.  You will need to get the water out of the tub to get the door to open.  On the bottom left corner, there is a small door.  Inside the door is a small rubber drain hose.  This will empty out the water inside.  After awhile, the machine will unlock the door.
Jul 06, 2008 | LG WM-1832C Front Load Washer
LG WM-1832C Front Load Washer Logo
1,101 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
