Washer does not spin
I have a GE WDSR2080D 5WW washer. It seems it does not spin. I tried to put the option to heavy load, it seems a little better with big noise, but the cloth is still not dry
  • DFuge Mar 12, 2009
    I have the same problem with my GE WDSR2080D 5WW. It will not completely spin dry. When the problem occurs we have to let it sit for an extended period of time and then retry the spin. Sometimes it works and sometimes it doesn't.
I have a GE WSSH300G0WW washer and it is doing the same thing except I can not go to any other cycle to get it to spin. The water is just sitting in the machine right now.
Posted on Dec 23, 2007
GE Washer will not agitate but it will spin
Put old coupler back on transmission shaft. Can you now turn coupler? You should not be able to. If you can, grooves in coupler are stripped out. Replace coupler. Part # WH49X10042
Sep 13, 2017 | GE WDSR2080D Top Load Washer
My GE washer #WDSR2080DEWW washer won't spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | GE WDSR2080D Top Load Washer
My wdsr2080d will not drain
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 02, 2010 | GE WDSR2080D Top Load Washer
Washer not agitating
Check the little things called dog trigger
Sep 14, 2009 | GE WDSR2080D Top Load Washer
My GE WDSR2080D washer won't spin or drain.
The crappy designed mexicanical lid switch device has faile, jump it out. Remove the front panel and then you can get the top off to access this problematic lid switch.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 14, 2009 | GE WDSR2080D Top Load Washer
Washer filles with water can hear timmer then drains never spins
you have transmission problems. When your washer is empty and off you should be able to turnthe agitator by hand if you can't then the transmission is bad.
Apr 03, 2009 | GE WDSR2080D Top Load Washer
GE washer
SOUNDS LIKE A POWER ISSUE IF YOU HAVE A TEST METER OR BORROW ONE PUT INTO OUTLET AND SHOULD READ ABOUT 120 VOLTS THEN PUT THE WASHER ON SPIN AND SEE IF THE METER GOES DOWN AND HOW MUCH AND WHAT LEVEL IT STAYS AT WHILE THE WASHER IS SPINNING LET ME KNOW
Oct 27, 2008 | GE WDSR2080D Top Load Washer
GE heavy duty washer
make sure clothing is properly distributed in drum. Try this but need more info as to weather it spins and bump or weather or not it stays in one place and bump.
Mar 29, 2008 | GE WDSR2080D Top Load Washer
Will agitate, but will not spin
hover gemini. mod.A6516-010 will agitate but will not spin.thanks .henry
Jan 01, 2008 | GE WDSR2080D Top Load Washer
Washing Machines Logo
211 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
