I've changed the bulb (lamp) but it still does the same.
SOURCE: changing high mounted stop light bulb
HMS Lamp will be mounted in roof or in rear parcel tray.
You have to locate the screws which will be closed/covered by a dummy cap. Remove the cap and unscrew the assembly, you will be able to replace the bulbs
SOURCE: Oil light blinking
there is always the possibility that you really have low oil pressure when you get this light, at idle the engines oil pump produces the least pressure and if there are problems then that is when it shows up, so have the oil pressure tested by a shop with a mechanical test gage, if the oil pressure is within spec then replace the oil pressure light sending unit on the engine, I don't recommend you drive this until u are sure of the pressure, u can SEVERELY damage the engine is the pressure is really low.
Testimonial: "Ok..Thank you very much!!"
SOURCE: Right rear tran signal lamp does not work. changed
Please check the cables lead to your rear turn lamp for loose connection. Both turning lamps ( rear and front) should work to keep turning lights back to normal blink.
Regards
I suspect that it may be an engine or tranny fault report light As it is coloured I suggest you have the fault codes read befor the fault becomes critical Check in the owners manual for what it means
Please dont forget to vote this answer was helpful
Many thanks
