Question about Canon PowerShot SD550 / IXUS 750 Digital Camera
The Slide Lock Release Switch
My switch broke I ordered the parts from Canon now need instructions on how to do the replacing. My email is ppmntpati1@aol.com I would appreciate any help . Thank You.....
  • 4 Answers
Not sure if this covers it as I didn't register: http://www.nodevice.com/manual/newmans/canon_s_750zip/get9839.html
Posted on Aug 05, 2008
How do you release the scanner lock switch on the MP990
Open the document cover of the scanner decision, you should be able to slide the release lock switch towards the hinge side of the document cover. There is a padlock symbol on each side of the switch; the side closer to the hinge is an unlocked padlock. The other side has a locked padlock symbol. If the all-in-one was on, turn it off and wait 5 seconds before turning it back on after unlocking the unit.
If the switch is in the unlocked position and turning the printer off and then on again doesn't resolve the error, the unit needs service. Contact Canon if it is under warranty. (Otherwise, decide if the printer is worth the service call.)
I hope this helps.
Oct 30, 2012 | Canon Office Equipment & Supplies
I just installed my new Canon LiDE 110 scanner. I slid the lock button to the unlock position. When I try to scan, I get the following error: "Release the lock switch, detach USB cable and...
mbrindle is great!!!! Many thanks - I was just about to take it back as I thought the scanner was defective. Would never have thought i had to do that. Thanks!!!
Aug 15, 2011 | Canon CanoScan LiDE100 Flatbed Scanner
Instructions how to step by step replace ignition lock cylindor for an 1999 oldsmobile intrigue
1999 Oldsmobile Intrigue
IGNITION SWITCH AND LOCK CYLINDER REPLACEMENT
1. Disconnect battery
2. Disable Supplemental Restraint System (Airbags)
3. Remove traction control switch from rear of center console plate
4. Open console lid and remove screws at front of console
5. Pull console plate up to release clips and slide over shifter
6. Pull rearward to release clips retaining instrument panel accessory trim plate to instrument panel
7. Remove screws attaching radio to instrument panel
8. Disconnect electrical connectors and remove radio
9. Take down instrument panel hush panels and disconnect courtesy lights. Remove hush panels
10. Remove knee bolster and knee bolster bracket from driver's side below steering column
11. Remove screws from IPC trim plate
12. Pull out instrument panel cluster trim plate to release from retainers
13. Remove trip odometer and reset switch from IPC trim plate
14. Remove IPC trim plate
15. Remove screws from IPC and pull IPC out
16. Disconnect electrical connectors from IPC and remove IPC from the instrument panel
17. Disconnect ignition switch connectors
18. Turn ignition switch to the ACC position and remove park lock cable from ignition switch
19. Turn ignition switch to ON position
20. Depress and hold locking tab on right side of ignition switch with a small, flat-bladed screwdriver and pull ignition lock cylinder from ignition switch
21. Remove ignition switch bezel from ignition lock cylinder
22. Remove screws attaching ignition switch to bracket
23. Remove ignition switch through the IPC opening
24. To install, reverse procedure
Apr 04, 2011 | 1999 Oldsmobile Intrigue
Release the lock switch, detach the I/F cable
try this
1. at the back of the scanner there is lock try to release that one (slide to unlock)
2. uninsall the system and re-install again
3. check the usb port of your computer
thanks
Feb 18, 2011 | Canon CanoScan LiDE 25 Flatbed Scanner
I am having a problem with my printer. When I turn it on the copy light is on and the feed switch light and the alarm light and it says in the screen release the scanner lock switch and turn the power off...
Issue: ERROR LCD: Release the scanner lock switch and turn the power off and back on.
Solution: Unlock the scanner lock switch
The scanner must be unlocked before turning the unit on.
Turn off the power.
Lift the document cover.
The scanner lock switch is on the left hand side of the underside of the document cover.
Slide the scanner lock switch to the release mark (an open padlock icon).
Lock the switch before transporting.
Close the document cover.
Turn the machine on.
If machine still is not working repeat the power off / on cycle waiting 5 seconds in between.
Jan 25, 2011 | Canon MP830 All-In-One Printer
The battery on my laptop will not come out. The release tab is stuck and no matter what I try it will not budge. Any suggestions?
Run the computer on battery until the battery is dead. Spray the battery bay and release tab with a _LIGHT_ coat of WD-40 and try again. A small screwdriver may help to pry the release out of the way. Too much pressure can break the release. If the battery is working well, you could just live with it in place until replacement time.
Sep 01, 2009 | IBM ThinkPad T40 2373 Notebook
I am setting up a new Canon Pixma MP980. I lifted the scanner unit until it locked open to remove red packing tape and to have a look inside. Now I find I can't close the cover. How do I release the lock...
Over on the left there is a small two-position slide switch with pictures of an open lock and a closed one. Slide the switch to the rear (Open lock) and close the cover.
Nov 14, 2008 | Canon Office Equipment & Supplies
Top trigger
!. check with Canon or parts availability -some modeles are considered 'disposable' and no parts are available
or they may offer to repair it for you.
Oct 16, 2007 | Canon PowerShot A610 Digital Camera
Canon PowerShot SD550 / IXUS 750 Digital Camera Logo
29 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
