Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
Samsung DLP Problems
The Tv turns on and off after viewing for about 30 minutes then repeats on and off in another 20-30 minutes. I then turned it off. the next day it made a sound and the screen went black. must of blew a light.
  • 1 more comment
  • Anonymous Jan 10, 2008
    My experience with this TV was very good for the first year and half. However, the TV now turns itself off at randome with no warning.
  • jeaker Jan 13, 2008
    When I turn the TY on, it powers off after one or two minutes. This continues as I attempt to power on for the next 10 to fifteen minutes. The set finally turns on and stays on. The picture is normal and so is the sound.
    The set is tthree years old. The TV has operated flawlessly until one month ago.
    Do I need a new Projection lamp?
  • mlee9999999 May 07, 2008
    My samsung is DLp4663 DLP, replaced a new lamb, did not turn on after one week, exchanged the lamp with the seller, and he did testing, and found out that the lamp is ok, the problem is my TV, he said probably the power supply problem
    don't know how to fix it
  • 4 Answers
Possibly thermal sensor,ballast,or the lamp or all of the above,or the main pcb could be the culprit
Posted on Apr 26, 2008
Why does my DLP TV turn itself off
Try replacing that lamp door switch, this has been known to cause issues in some Samsung DLPs
Contact Samsung at 1-800-627-4368 for proper part#
Oct 21, 2014 | Samsung HLP5063WX/XAA
Samsung HLP466W goes off after turning it on for about 20 seconds, why does it do that?
The power supply tries to start for about 20 seconds, then fails. It will repeat this routine until eventually it fails competely.
Jul 15, 2014 | Samsung HLP4663W 46-Inch Widescreen DLP...
My Samsung 61" DLP shutsoff repeatedly...after about 30 minutes, and then every 5 minutes. Picture is fine
MIGHT BE OVERHEATING OR POWER SUPPLY BOARD PROBLEM. LOCATE A HONEST TV TECH. VERY GOOD QUALITY UNIT
Nov 15, 2013 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP turns on and off - cycle repeats
make sure put the lamp door back before trying to turn it on because they have switches on them that allow the tv to turn on. If that is ok you probably have a bad ballast.
Call a local tv repair shop to further diagnose the problem.
Dec 10, 2009 | Samsung DLP HL-P5663W 56" TV
I have a 42" Samsung DLP that makes noise that sounds like it's coming from the fan. The sound starts after the TV has been on for 20-30 minutes; it's a winding type sound and continues until after the TV...
These models usually suffer from a bad color wheel. You will know that the color wheel is at fault if the sounds goes away right when the lamp shuts off. Look at the back of the set and watch for the lamp to shut down. The color wheel is not a consumer replaceable item.
Aug 15, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung ldp 46 " replaced lamp humming sound fans cleaned and working set continues to turn off every 20 min or so
Humming problem with a Samsung DLP HL-P5063W
picture displays good
Humming randomly starts, but once it starts it hums
May 31, 2009 | Samsung DLP HL-P5663W 56" TV
TV TURNS OFF AFTER 20-30 MIN
Ensure that the TV is off. It may be advisable to unplug the TV as well.
2 Using a Phillips screwdriver, remove the single screw affixing the lamp cover (the small, grill panel on the back of the set) to the chasis. There is also a grill that is held in place by tension. Just "pinch" the thumb clamp on the bottom of the grill and slide it out. This is the same procedure you would perform to change the lamp, except in this case you will not need to remove the lamp itself.
3 Inspect the spring-loaded blue safety switch to ensure it is making good contact when the panel is secured. The switch should deflect downward when the panel is replaced. If the contact with the panel is suspect, very gently bend the metal bracket on which the switch is mounted.
4 Replace the grill cover and the lamp door, and continue to enjoy your TV.
5.Check some basics first. Make sure the sleep timer on your TV hasn't been turned on, telling your set to turn off at a certain time. If your DLP TV is acting erratically, Samsung recommends turning the set off and unplugging it for 30 minutes. After 30 minutes plug it back in and turn it back on. Unplugging the set resets it, and that may fix the problem.
6 Check your power supply. Make sure your Samsung DLP is securely plugged into a working outlet. Plug the TV into a different outlet to see if the problem still exists. Make sure that a fuse hasn't blown in your house or a circuit breaker hasn't flipped.
7 Replace the lamp. If your Samsung DLP is shutting off or won't turn on, a bad lamp is the most likely cause. To replace the lamp, remove the lamp cover from the back of the TV by removing the screws with a Phillips screwdriver and slide it out and away from the TV. Remove the screws on the lamp assembly and slide it out of the TV. Disconnect the old lamp and insert a new lamp into the assembly. Slide the assembly back into place and replace the screws. Do the same for the lamp cover.
8 Check for signs of overheating. Samsung DLP TVs generate a sizable amount of heat. If the components inside the TV get to hot, the TV will shut itself off as a protective measure. Make sure your DLP is out 12 inches or so from the wall. Make sure that all of the vents on the set are clear of any obstructions. Allow the TV to cool down for 30 minutes before turning it back on.
9 Contact Samsung. If none of the above tips help, it's time to contact Samsung, as the problem is likely something that should only be fixed by a qualified service technician. More serious problems may include a bad power supply or a bad ballast. Attempting to repair those yourself will void your warranty and may cause more serious damage to your set.
The safety switch exists so the user does not accidentally remove the lamp door while the TV is on. Doing so could, theoretically, result in burn or electrocution. This spring loaded switch causes the TV to shut down when the door is opened.
Since the TV's chasis is plastic, expansion and contraction can cause the switch to lose firm contact with the lamp door. The TV's behavior could then be such that after being on for a while (getting warm) the plastic expands and the switch loses enough contact to cause the TV to shut down. The frequency with which this phenomenon occurs is not only dependent on the internal temperature of the TV, but also the ambient temperature of the room as well as the relative tension on the switch itself. The user's perception is that the TV starts up fine, but then "randomly" turns itself off after being on for a while.
If you have recently moved your TV, it is very common for random shut-downs to occur. This is because the move has shifted the flimsy plastic chasis of the TV, thereby loosening the contact between the lamp door and the switch.
Make sure your TV is off and cool when performing this procedure.
May 28, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
you have the same problem I have. The problem is fixed by changing the new light bulb. The problem appears again after 1500 hours of use. You can keep buying new light bulbs or avoid it by not buying another Samsung TV.
Sep 23, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
Jerry Greenberg
Jerry Greenberg
