Question about Polaroid FLM-3201 Television
Volume Is it possible to reset the tv to original factory setting ? Model FLM-3201
  • 44 Answers
Go to the set up menue, you should be able to reset all of the controls.
Lou Margo
loumargo@verizon.net
Posted on Mar 06, 2008
Poloraid hdtv 36 inch model FLM 3201 PICTURE
FAULTY POWER SUPPLY OR INVERTER PANEL ON BACK OF SCREEN
AVERAGE REPAIR COST £60 TO £80+
Aug 25, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
Will this tv pick up digital signals if i use an outside antenna?it says hdtv on the front of the tv.the model is FLM-3201
This tv would need a converter box. It does not appear to have a digital atsc tuner in order for you to get digital over the air channels. Searching for channels is on page 18 of the manual
http://www.hdtvsolutions.com/pdf/flm3201_ug.pdf
May 07, 2010 | Polaroid FLM-3201 Television
At my Polaroid LCD TV the sound disappears for a
Go to menu reset the sound back to factory setting,should solved this problems.Not then ur Main Tuner signal board have problems.
Mar 10, 2010 | Polaroid FLM-3201 Television
I'm trying to use a Polaroid FLM-3201 as my computer monitor. The screen resolution is poor, so I have tried to change the settings in the control panel. However, when I do so the Tscreen goes to snow and...
use manual settings for this input. i've had this issue before. when trying to watch movie from netbook, similar message occur. got to manual phase settings, played with adjustment and: ta-da! got good picture. sometimes auto mode for this input is not catching up.
Good luck,
Alex's TV,
Philadelphia, pa.
215-806-5980.
Feb 22, 2010 | Polaroid FLM-3201 Television
I lost my book and i do not know the code for my tv to work the remote
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man your manuel is availiable on this web page for free download you ca probably remove battary from remote because it came with tv and should default to factory setting for your polaroid tv
good luck ron
Dec 14, 2009 | Polaroid FLM-3201 Television
I can't get my direct tv remote to work with my Polaroid FLM-3201 tv. I've gone through all of the codes listed in Direct tv's set-up. Any ideas or suggestions?
went to direct tv online tv codes remote10765,10865,11262,11276,11314,11316,11326,
11327,11328,11341, http://2getdtv.com/directv/tv_codes.html
this web page is for direct tv remote codes hopefully
this is an updated list
http://2getdtv.com/directv/remote_codes.html
this page has programing instruction for remote
good luck ron
Nov 19, 2009 | Polaroid FLM-3201 Television
I installed a new antenna. I think I need to scan, but don't know ho. It is a Polaroid TV FLM 3201 model
Just go into the menu and go down to install and the set will do the rest. Pay attention to the on screen directions. Some Polaroids scrolled across the screen at the top and some down, but you will see what I mean once you get started.
Oct 29, 2009 | Polaroid FLM-3201 Television
Flm-3201
Sounds like the back light is out, and the unit needs servicing. You can check this by shining a flashlight close to the surface, and if some image is seen, the the back light is the cause. Else the LCD driver is gone.
Aug 03, 2008 | Polaroid FLM-3201 Television
Polaroid flm 3201 wont turn on
If you have no power light at all on the front of your tv. Check the fuse by the power coard.
If you have a red light only and have the dark power board with black heat sinks. check the fuse in the center of the power board.
if the light turns blue when you hit the power button but no picture and have the dark power board replace the 2- 1000 mfd 10 volts caps with 2- 1000 mfd 16 volt caps at 105 deg.
need more help let me know
Nov 24, 2007 | Polaroid FLM-3201 Television
Polaroid FLM-3201
Check the fuse near power supply.
Cost to replace about $35.00
Oct 11, 2007 | Polaroid FLM-3201 Television
Polaroid FLM-3201 Television Logo
70 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
