Question about Acer AL2423WR Television
Sound humming at2703 Acer
When I mute the sound, you have hum sound, when I disconnect the antenna cable the sound stop,
Help me
0 characters
1 Points
37" Philips LCD no sound.
Maybe the antenna that you are using is not picking up sound from the channels. It could also be the cable. If it makes a humming noise, it means that the speakers are getting electric current and that they SHOULD be okay. It also could be your tuner. Maybe check it all out at some tech place like best buy. Those guys can help
Aug 24, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
The humming noise from my hitachi 42hds69 television seems to have gotten a little louder. This humming sound is more prevelant on various stations. The humming sound seems to be normal/better on dark...
usually it means your screen is going bad unless it is a fan or some mechanical part thats humming if it comes from the screen itself the screen panel going you can check cables and eveything else for this a signal loss type of short but if you have allready checked all cables or recievers or connected devices for this then its a simple main panel humm means a bad screen panel sorry to say but i hope this helps..
Jun 24, 2009 | Hitachi 42HDS69 42 in. Plasma Television
My lcd tv makes a humming noise
My 37 inch vizio did the same thing. go to your menu screen on the tv and go sound. My tv has an option to turn speakers on/off. Once I turned my speakers off and the back on again everything worked great. hope I helped! if I did please let me know!
Mar 21, 2009 | Vizio VW37L 37 in. LCD HDTV
Try removing all cables going to the TV except the power cord. Power on the TV and press mute. If you have any unwanted noise, then you have a defective TV and since it is new, you should get an exchange. If there is no noise with the A/V cables removed, then you might have hooked the source (cable box/DVD Player) into the wrong inputs of the TV.
Mar 14, 2009 | LG 42LG30 42 in. LCD HDTV
In most cases it's the Cable issue. Either bad Cable Box or the Wires are not grounded properly. Disconnect the Audio Cables or the COAX cable from the Cable Box and see if the Humming noise goes away.
Jan 31, 2009 | Samsung LN32A550 32 in. LCD TV
Hum in the audio - 32'' Proscan 1080i
does the hum occur when playing a dvd or only when watching tv ? if the hum occurs only when watching tv, i would like you to disconnect the cable line from either the wall or the back of the cable box and see if this hum disappears. if the hum disappears call your cable company. you have what is called a " 60 cycle ground loop ". hope this helps.
Jan 20, 2009 | Flat Panel Televisions
More often than not, the humming sound on any electronic device is brought about by the AC side of the power supply not only of the device itself but also all other equipment it is attached to. In your particular case, it maybe introduced into the system from:
  • (coaxial) cable TV leadin;
  • connections of DVD, VCR, game consoles and others;
  • electrical noise from lamp dimmers, lights with electronic ballasts, wireless phones.
It is interesting to note, that the noise could be from other appliances plug in the same circuit as the TV, you of course could try plugging it into another outlet or branch. In some instances, you could even try filtered regulators similar to those used by desktop computers.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 13, 2008 | Proscan 32LA30Q Television
Humming Noise
I have the exact same problem with my digital lifestyles television.
Sep 02, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
No sound
maybe in your cable box
Mar 30, 2008 | Pioneer PDP-4360HD 43 in. Plasma...
Acer AL2423WR Television Logo
Top Acer Flat Panel Televisions Experts
Gareth Cockram
Gareth Cockram
Martin Murray
Jaime Hernandez
Are you an Acer Flat Panel Television Expert? Answer questions, earn points and help others
