Question about Tascam DP01 All-In-One Recording Package Microphone
Tascam dp-01 computer trouble
When i connect my tascam to the computer and listen to the songs in the wave file and no sound comes out
any ideas?
  • 44 Answers
Are you sure the sound is supposed to some through the PC speakers and that you are no supposed to use another source.. ie . self powere speakers or and amp, etc.
Jay.D Bsc Music Technology
Posted on Dec 16, 2007
Cant transfer the master from tascam to computer
I'm assuming this is a Tascam recorder you're refurring to. What model is it, and what operating system are you using on your computer. First off, don't connect the usb cable to the computer until your Tascam Recorder in in USB Mode. I have the Tascam DP-01. With it, after making the master recording, make sure the master light is off, and not flashing. In the menu under WAVE, select Export Master and press enter. If anything is running, or the master light is lit, you will get an error. After the song is saved to the FAT partition, select DISK in the menu and scroll down to USB Open/Close and press YES/Enter. You'll be asked if you are sure. press Enter/Yes again to go into USB mode. Now plug in the USB cable. Use Windows Explorer, or what ever file navigation program is on your computer. (Not Internet exploere, but windows exploere.) Your Tascam will be seen as Removable Media when viewed from your computer. I have a DP-01, and it shows on my computer as DP-01. You'll find a few folders viewable on your recorder. One of them is called WAVE. You'll find your Exported Master in this folder. Copy it to a folder on your computer. When finished, if you're using windows, then use the Safely Remove Media function in the system tray where the clock is to disconnect from the Tascam safely. Then unplug the USB cable and press NO/Exit on your Tascam recorder to exit USB mode. I hope this helps. Have a wonderful day.
Jan 08, 2015 | Tascam Audio Players & Recorders
Is there a driver for tascam dp-01 for windows7 operating system
Unfortunately no such driver is available, because tascam have discontinued that particular model.
Here is a way to get your recordings off the device
On the Tascam main menu, select "Wave." 2) On the Wave menu, select "Export Master." This saves your mastered song to the correct folder. 3) Connect the Tascam DP-01 to your computer. You will get a message telling you your USB device has malfunctioned. 4) On the Tascam menu, select "Disk." 5) On the Disk menu, select "USB OPN/CLS." Your computer should detect the DP-01 as a hard drive & be visible in "My Computer" on Windows.
Apr 03, 2011 | Computers & Internet
My computer won't recognize my DP-01 Tascam recorder.
open the usb port on your dp-01 by going to "disk" in the "menu" select "usb opn/clse" press enter twice.
if your pc is connected to ur dp-01 it should reconize it, open the files by going into my computer as you would with a memory stick or card.
Mar 25, 2009 | Tascam DP01 All-In-One Recording Package...
Tascam DP-01 master track too big to export
Here is what I did to solve this issue:
1. Open up the USB connection on your DP-01 so that you may plug into a computer:
Mar 24, 2009 | Tascam DP01 All-In-One Recording Package...
Tascam DP-02CF: How to transfer files to my computer?
You can't see the fat partition from within the DP-02. It's there, but only your PC will be able to read the contents of the fat partition when you have the USB 'opened' on the DP-02. The manual states that if your CF card is less than 5 Gb in size than you will only see/be able to select one partition. The default CF card that comes with the DP-02CF is only 1 Gb.
If you've created a backup or exported your wav files properly and everything is working ok with the CF, then you should be able to see backup or wav files showing up in the fat partition while connected to the PC. Even if nothing is backed up or exported you should still see the directory structure from your PC with the three folders, BACKUP, WAVE and UTILITY. As you are not even seeing these directories, what may have happened is that the fat partition had become corrupted or these folders had gotten erased.
I would have thought that reformatting the FAT partition would have fixed this problem however and that the DP02-CF would automatically recreate the required directories on the CF media after a reformat. The manual is unclear on this however.
So a couple of things you could try:
1. You describe opening the USB connection as 'push the USB button and then hit enter'. I was assuming you meant that you were selecting 'usb' from the menu and then pressing the 'enter' button to open the usb connection. You may wish to verify that the usb connection is being opened properly first.
2. If the connection is opening ok, and after a reformat you still aren't seeing any folders in the fat partition while connected to your PC with the usb open, you might wish to try to recreating those directories in the FAT partition yourself. While accessing the FAT partition (DP-02CF's removable drive) from the PC create the three directories exactly as named in the manual (WAVE, BACKUP, UTILITY). If that works, disconnect from the PC, try exporting a track or backing up a song again, and reconnect to the PC to see if you can see/access those files now.
Best of luck.
Jan 02, 2009 | Tascam 2488 Portastudio Multitrack...
Can't Get My Music Off My Tascam. I have a DP-01 portastudio and it has a usb connection but it's not being recognized by my computer. At first it just wasn't compatible with Vista now I have windows xp...
How to export your recorded tracks to WAV:
- Activate the Menu
- Scroll down to WAVE
- Press the right cursor key
- Go to Export Track
- Select the tracks using the Insert and cursor up and/or down keys
- Press Yes/Enter
- When the DP-01 is done repeat pressing Exit until the menu is closed.
Tascam USB mode:
- Press Menu
- Go to Disk
- Scroll down to USB OPN/CLS
- Press Yes/Enter
- Press Enter again to execute
- Press Yes/Enter again for the "Are you sure?" message
Now you will be in USB mode and you will be able to access the DP-01's hard drive and download the exported WAVE file(s).
Remember: the DP-01 will stay in USB mode until you remove the deviceusing the Safely Remove Hardware option in Vista and then press Exit onthe Tascam!
Oct 18, 2008 | Tascam DP01 All-In-One Recording Package...
Failure to read WAVE file when trying to import a track.
Wav files need to be in mono to be imported into the dp-01. Fruity Loops and a most other programs by default save wav files in stereo. You'll need to save the files again as mono wav files before attempting to import them into the dp-01.
Jul 16, 2008 | Tascam DP01 All-In-One Recording Package...
Itunes connection
yes they are lost and you would have to turn on write protection. better idea is dont use itunes invest in a better online catalog.
May 18, 2008 | Tascam DP01 All-In-One Recording Package...
I don't believe any software comes with the DP-01.  After you record your tracks, you have to "export" them to your FAT drive.  Once they are on your FAT drive, you will be able to see them using Windows Explorer.  Your Tascam shows up as a removable disk.  Simply open the drive and you will see the available folders.  The WAV folder will contain your exported .WAV files and you can drag&drop from there.
If you don't have the manual, you can find it online.  It's free!
Oct 24, 2007 | Tascam DP01 All-In-One Recording Package...
Hooking my tascam dp01 to the pc
hey i had the same problem u need u.s.b 2 or something like that because some computers have u.s.b. 1.5 or something wierd along those lines i fixed mine by plugging mine into the back of the computer in the usb port there.
Sep 25, 2007 | Tascam DP01 All-In-One Recording Package...
Tascam DP01 All-In-One Recording Package Microphone Logo
69 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
