Question about JVC AV-48WP30 48" Rear Projection Television
JVC AV-48WP30 will not give a picture
I had a convergence problem. So I replaced the convergence chip "STK's", and worked great for a day or so. I was watching the game, and then the picture went out for a second and come scrolling back on, but with both blue and red convergence way off. I was unable to adjust it as well. Then turn off and back on a couple of times. Then I get this thump out of the speakers about 10 to 15 times, with no picture. Then that stops and the blue light will flash. BTW if I completely disconnect the convergence board, I get a picture back. Does this mean the STK's went bad again?
If it is not the STK going bad again,I have done a little reading I have seen messages on this problem talking about the deflection board is bad, IC's on the CRT driver will need to be replaced. What/where is the deflection board and/or CRT driver? How much are these parts? How hard is it to replace these parts in the TV?
Thanks for your time and help.
  • 1 more comment
  • nickmind Dec 13, 2007
    First off, thanks for the quick reply. I had a hardware engineer at work install the chips for me, so no overheating there. But my question is this how can you tell if the chips are generic vs. Sanyo? Just trust the dealer? By the time I read this post, I bought some STK392-150's already (different dealer). Is there a big advantage to going with the STK392-180's over the STK392-150's?
    And I will for sure use compound this time. Again, thanks for your help.
  • jasey Dec 16, 2007
    no picture coming out thru cable connection but with dvd video picture is showing normal. what can i do to fix it
  • nickmind Dec 18, 2007
    Well replacing the IC's gave me a picture. So that problem is fixed. Now for some reason I can not change the convergence on the blue side, also green is now out of wack as well.
    So I'm testing the tv out, and I feel the red side heat sink getting very hot to the touch with one a couple mintues of use, and the blue side heat sink is still cold. Does the heatsink normally get hot pretty fast.
    I traced the pins on the blue side chip, they seem to be connected. What can my problem been?
    Thanks for your time.
    Scholar:
  • 87 Answers
Replace the convergence IC`s again using original Sanyo chips (STK 392-110 or STK 392-180). Make sure to use plenty of heat sink compound. Coat the entire back side of the chips. Also look to see if any of the low ohm resistors are burned. A shorted chip will cause the thumping sound and the set will shutdown. I am guessing that you used generic IC`s as a replacement. They are cheap and the leggs fall off when you apply too much heat during soldering. Dont wory about the CRT driver or the deflection board, they are probably fine.
Posted on Dec 12, 2007
  • 1 more comment
  • Anthony Wilson Dec 13, 2007
    The Sanyo chips have a 5 digit or letter serial number on them. The difference between the chips 110, 150, 180 are the power they handle. 110 watt 150w 180w. JVC uses 2 penny sized squirts of heat sync compound. ( not enough) to dissapate the heat very well. I have fixed many 48wp30`s for bad convergence and never had a problem with the deflection or driver boards.
  • Anthony Wilson Dec 19, 2007
    Looking from the front of the set the red chip is on the left and the blue is on the right. The green is shared between the red and blue . The red chip controls the red vertical and horizontal and green vertical. The blue chip controls the BV, BH, and green horizontal. The chips normally get hot pretty fast. If you have a cold chip it means that it is not conducting. You may have some open resistors on the board or one of your plugs not seated properly. Another posibility is that there is no voltage getting to the cold chip because of an open trace or resistor on the board. Both chips get fed power from the same supply.
3 Suggested Answers
  • 1779 Answers
SOURCE: Deflection Boards Compatible?
I just checked and the part # is SSB-2051A-M2 and is the same for both models.........Go for it !!!!
Posted on Sep 01, 2009
Testimonial: "Thanks so much for the quick reply! This was great news..."
dave1645
  • 834 Answers
SOURCE: HI, my JVC AV-48wp30 has the same symptoms as
take off the front panel and unplug the convergance board up front just behinf panel if the set now comes on replace your con amps if not you have a power supply issue more than likly the con amps are bad
Posted on Nov 20, 2009
The tv looks like it is in 3d. when i try to adjust the convergiance the plus signs on the left are bent
do not play with this tv replace the stk ic chips and the resistors around the stk chips ,cant miss em about 2 inches big with heat sinks on them.
Sep 11, 2010 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 Convergence Problem
If you know how to solder, I would suggest to just replace the STK ICs and some of the low value resistors. If you do not how to solder replacing the entire board is the way to to get the TV fix. You might still need to adjust the convergence after the board replacement.
Let me know if you need further assistance.
Jul 22, 2008 | JVC AV-48WP30 48" Rear Projection...
Jvc av-48wp30 blue to align convergence
Tv colors R,G,B don't alignment any colors.Tv have a convergence problems,it dead.Tv convergence board require changes 2 STK convergence ICS and some or all it resitors to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 11, 2010 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 , how to change convergence
First of all tools,requirement to do the work on the Convergence board to do changes the 2 STK convergence ICS and some or all it resistors.U have a soldering iron,desoldering pump or soldering wicks and solders?Don't?must buy to do desoldering and soldering?Tries Amazon.com to buy solders.Tries wesites like Tvrepairworld.com to buy the convergence kit to replaced ur self,and buy the soldering iron here it have the desoldering pump attach to the sodering iron it self.For video tutoring how to take out convergence board out of the tv and replacing the 2 STK covergence ICS and some or all it resistors.Might included in the buying of the convergence kit,not,Try You Tube type in convergence problems,will have video some body doing it.
Jun 07, 2010 | JVC AV-48WP30 48" Rear Projection...
HI, my JVC AV-48wp30 has the same symptoms as other posts here. Powers on with no screen, HV, and no CRT heater coils light up. Thumping sound in speakers, and then shuts off. Blue light flashes. ...
Nov 20, 2009 | JVC AV-48WP30 48" Rear Projection...
I had a convergence problem on my JVC AV-48WP30, and followed the instructions posted by SD Tech. I used STK-392-150 chips and I replaced 1 burned out resistor that had no bands, but was marked 1.8 ohm J...
Yes, it does not happen often but you may have installed or got a new chip that is bad--you did apply heat sink compound to the new chips?
Check all the resistors carefully when you do this and double check all the soldering you do.
Let me know if you need help.
Rate this solution as I DO THIS HERE FOR FREE.
SD TECH
Nov 09, 2009 | JVC AV-48WP30 48" Rear Projection...
Convergence problem wiht jvc av 48wp30
Bad chips...There are a ton of cheap fakes out there....Or bad resistor...
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 29, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 tv(convergence)
This is a convergence board problem. Have a tech replace convergence IC's. The part no. starts with STK. If you are good in soldering and know how to test resistors, you can do it.
Jul 16, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
291 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
