Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Mitsubishi ws65813 I have green and purple lines going through the picture and want to know what the problem could be.
  • 39 Answers
HACKER-PROBABLY BAD CONVERGENCE AMP IC CHIPS,TEST AND SEE IF YOUR CONVERGENCE FUNCTION IN YOUR MENU WILL WORK,IF NOT CHANGE THE 2 STK CHIPS INSIDE TV.IF YOUR NOT A GOOD REPAIR GEEK I,D CALL ATV GUY OUT,EST.AROUND 300.00. JOE TV
Posted on Dec 12, 2007
Polaroid tv has green and purple lines without any picture, wondering if a t con board will help with this problem
Unhook the left ribbon cable going from the panel to the Tcon board if the green and purple lines stay then its the panel if they go away try a new board
Feb 26, 2018 | Polaroid Televison & Video
Purple static lines and a jumpy picture
Your picture tube is about to go.
If it's still under warranty,take it back.
Hope this helps.
Nov 26, 2013 | Mitsubishi VS-45607 45" Rear Projection...
Green and purple horizontal lines
You will most likely need what is called a scan converter/scaler. It will convert your source signal to the desired signal for you. You can find these online.
Nov 21, 2012 | Mitsubishi Televison & Video
Blinking purple and green lines
Your bulb is going out. You have to get a replacement. If you need help finding one let me know.
Mar 02, 2011 | Mitsubishi Televison & Video
Blinking green light on mitsubishi ws65813 tv i replacec the capicators but last time a tech had to replace a fuse too. where is the fuse?
On the power supply board near the connectors for outputs. Probably a 'pico' fuse which is small and soldered in - looks like a solid colored smaller resistor, usually.
Apr 11, 2010 | Televison & Video
Projection tv flashes green and purple tints
Find your reciept then call mitsubishi . if you purchased it less than 3 years ago mitsubishi will pay to have the expensive light engine replaced.
Oct 05, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Green light flashing
The WS65813 is the V23++ series. The blinking led means the DM caps have failed you can get the V23 DM repair kit at the following link which contains the replacement capacitors and step by step instructions with pictures so you can do the repair. Heres the link its listed under the repair kits category.
http://servicemanuals.vstore.ca/
Feb 16, 2009 | Mitsubishi WS-65813 65" Rear Projection...
Ws65813
Check threads for DM repair or ctechnicians.com
Jan 04, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi DLP 62" WD-62725- Clear Picture w/ Purple Screen
Sounds like one of your colors are missing. make sure all colors are lit, Blue, Red, Green
Dec 27, 2007 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
127 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
