Question about Sewing Machines
Sewing Machine problems
I have a Janome sewing machine and the bobbin thread is very loopy on the back. What can be wrong?
Thanks,
  • abpwoman7 Jan 08, 2009
    I rethreaded the bobbin and still have the problem. I adjusted the tension and the stitches are so loose like a basting stitch and can pull it out.
  • 26 Answers
You have to wind the thread very tight into bobbin.
Posted on Dec 12, 2007
How to fix bobbin thread on computered memorycraft 9000 sewing machine ?
1)Check that your bobbin does not have a nick in it where the thread can catch and won't feed smoothly.2) make sure the upper and bobbin threads are the same.3) pull out the bobbin case and chect to see if there is a clump of lint.4) make sure the feed dogs are moving the fabric through smoothly,some fabrics can get caught on the dogs and make the bottom thread get loopy.5) check your needle,if it's bent or has a bad tip,it can mess up the stitch.
Aug 15, 2014 | Janome Memory Craft 9000 Computerized...
Janome 5900 sewing backwards!
Most likely, the bobbin thread is not in the bobbin tension. Rethread the bobbin and try again.
Loops on top of the fabric almost always mean too little tension on the bobbin thread; loops on the underside almost always mean too little tension on the top thread. Just backwards of most people's first guess. See http://www.picturetrail.com/sfx/album/view/22521551
Jan 18, 2014 | Janome Sewing Machines
Threading my machine
Don't have this machine, but I have web site for help.<merrilywequiltalong.com>
May 31, 2010 | Janome HF-107
Tension issues with the bobbn area
No, I have not had a consistent problem with this.
What looks like a bobbin issue could be a threading issue.
If a sewing machine is threaded with the presser foot down, the tension control does not capture the thread as it should. The top thread then cannot form a proper stitch with the bobbin thread.
If I forget to have the presser foot up when I thread, then I get loose stitching on top and loopy stitches on the bottom.
Mar 30, 2010 | Janome 659 Mechanical Sewing Machine
The thread from the bobbin is all loopy in the stitches
Always thread the sewing machine with the presser foot up.
This allows the thread to properly enter the tension control.
If the thread is not in the tension control as it should be, when it connects with the bobbin thread it is not tight enough to form a proper stitch.
The bobbin gets the blame because it feeds from the bottom.
Mar 10, 2010 | Janome Sewing Machines
Singer 5430C bobbins thread always loopy
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Feb 15, 2010 | Singer 5050 Mechanical Sewing Machine
Janome sewing machine has loopy bobbin threads
Try rethreading both the bobbin thread and the needle thread. Check for lint in the bobbin holder.
Oct 19, 2009 | Sewing Machines
Loose bobbin thread
There is a small screw on the side of the bobbin case, and in might help if you tighten that just a little bit.
May 11, 2009 | Janome 659 Mechanical Sewing Machine
Threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Nov 07, 2007 | Janome Mini Compact
Sewing Machines Logo
74 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
