Question about Toshiba CX35F60 35" TV
Cable TV Still frames, looking squared out, 2 seconds then okay?
Why does that happen? The TV constantly comes and goes, its almost like 30 minutes routinely that it frags out? I have called the cable company and asked that they find the problem, they tell me to mess with the cables, tighten etc., and I know they are tight. So I say, "okay" and hang up.
It seems that only when I make the call that it goes away for a period of time, few weeks...then right back to the same issue. It is almost like they know what is happening, know how to fix it but don't tell you? Can you tell me what they are doing? I don't think it is a signal, they ALWAYS say, Hmppphhh, looks like you have a good strong signal? Then, "have you checked your connections?"
Any idea what they are doing and what it is?
    Genius:
  • 1,694 Answers
In this case, the cable company is not at fault........
Your set needs careful, thorough soldering of any / all bad
connects, esp. power regulators and horiz driver....
You will need skilled, technical help....................T.
Posted on Dec 12, 2007
Video works/disappeards intermittantly.
Hi Curtis
You`ve mention Capacitor, are you referring with the TV or the PC?
Jan 19, 2014 | Vizio VP322 32 in. Plasma TV
Video Disappears Intermittantly
The TV power supply may be failing.
Oct 19, 2017 | Vizio VP322 32 in. Plasma TV
I have a 1999 model...when you turn it on the screen is a black square all but like a picture frame on the outer edge...when i hit the volume the screen comes back for a few seconds and then goes black....
Goe to the setup menu and turn off closed caption.Does it do this on all inputs. Closed caption is only on rf input as far as the tv is concered. If this is happening on input which is connected to cable box or sat reciever call your serv provider.
Mar 07, 2011 | Mitsubishi WS-65907 65" Rear Projection...
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
Samsung T.V. goes on for 30 seconds then no picture
If this is a flat panel LCD tv, this is a sure sign that the panel itself is bad. I have seen this before. Tv comes on works fine then within 5 minutes goes blank.
Aug 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
The TV cuts off frequently. The screen is blank & no sound.
It is probable you have a poor soldered connection on the power supply board, hence the erratic timing of the TV going on & off. If you are competent with a soldering iron look for dry jointed soldering on the board. If not have a service engineer take a look at it for you.
Jun 24, 2009 | Panasonic Televison & Video
Video warps on edges then cuts out to black, then fades back in
Please dont rate me if could not fix your problem. Check the tv lamp. If doest work well, replace it. Thank you..
Nov 29, 2008 | Samsung TXM3096WHF 30" TV
Lamp need replaced?
If that is what is happening, with no other light coming on, then I would try and unplug the tv from the wall for 30 min. Plug it back in and try turning it on. If this doesn't fix it, you will need to take it to a repair shop.
If the LAMP light goes red then replace the lamp.
Aug 03, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
