Question about Whirlpool MH1150XMQ Microwave Oven
Whirlpool MH6151XHT-1 - No Power - Stumped
Over the Range Microwave went dead while exhaust fan only was running. No power at all going to unit. Control board has no function working or showing signs of power. In the inside of the computer control panel there is a wiring diagram, and based on the wiring and testing criteria; the thermal fuse, capacitor, diode, fan motor, and on the transformer, the primary and filament wiring test ok. I didn't test the secondary wiring of the transformer, as it is covered with a tape protective covering.
There is a MGT THERMAL FUSE shown in the wiring diagram, but I can't find it. Could that be the issue?
The secondary switch didn't doesn't appear to make contact with the door, so I held the switch down, and still no power to the unit. This might be an auxillary problem.
Is it possible that the $175 control board is dead? How do I test it for sure?
Any other ideas?
This one has been a learning experience for me, as this isn't my cup of tea. This board has been very helpful, and I hope someone can help me.
  • tdm757 Dec 12, 2007
    In my description it says I tested the thermal fuse as ok. I meant the ceramic fuse - not thermal, but electric. The ceramic fuse has continuity.
  • 26 Answers
First change all the fuse and check whether it works or not, if it does not work than as per your finding the secondary transformer could be the issue, the secondary transformer tap down the voltage fro 230-240/110 to required control board voltage. the best thing if the unit is opened then the right problem can be found but as per your description either fuses are faulty or the secondary transformer.
Posted on Dec 12, 2007
Hi I have a Samsung SMH9187 micowave that is dead (no display, light, fan, mirowave).
Sounds like the main fuse blew. It's either near where the power cord enters the cabinet, or behind the control panel (if an over the range unit).
You may also have some type of failure in the high voltage circuit; based on your description of the symptoms.
Aug 16, 2014 | Samsung SMH9187ST Microwave Oven
Hood light & exhaust fan not working
You have no power to the unit. Breaker is out or the hot wires into the hood has come apart. The wires coming into the unit usually terminated in a junction box next to the fan housing.
Teas it for power an/or reset breaker.
Oct 21, 2013 | Whirlpool GH5184XPQ Microwave Oven
The vent fan on my over the range Whirlpool microwave (mh1150xmq-0) runs any time I use the microwave (as if I have turned the vent fan on "low"). This doesn't seem to affect cooking, but it...
You either have a shorted exhaust fan thermostat or a shorted fan relay on the control circuit board.
While we regularly repair these controllers by mail for $39.95 postpaid with a one-year guarantee, or you can order a new control circuit board (part number) from the Pros here, we strongly suggest that you or someone you know check the exhaust fan thermostat first.
It should read "open" on a continuity (ohms) test. If it reads closed (shorted) it is bad and the fan will run all the time.
Or you can simply unplug the oven's power, disconnect one lead from the thermostat, tape it over to prevent shorting, then plug the oven back in. If the fan still comes on, the problem is on the board. If it does not, the thermostat is shorted.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Oct 14, 2011 | Whirlpool MH1150XMQ Microwave Oven
Exhaust fan is running constantly, without even
It could be that the fan button is sticking or a contact has welded itself closed therefore its getting power all the time.
Mar 08, 2010 | Maytag Appliances Over-the-Range Microwave...
I have a Whirlpool model MH6151XHT-1 which has two light bulbs. The cavity light quit working in either high or low. Upon checking the lamps, one was bad. I switched the socket position of the good lamp...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
Microwave Oven Control Panel Repair Nationwide
Sep 10, 2009 | Whirlpool Microwave Ovens
We had sevseral boiling pots going underneath the over the range microwave without the exhaust fan on while also cooking in the microwave, we saw sparks in the microwave and it went dead. now nothing...
The main power fuse inside the MW may have been blown from the steam shorting out the circuitry. If so this fuse probably can be replaced. Lowes has replacement fuses.
Jun 13, 2009 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
Gh5184xp no power
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our site, we have a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
The fuse and magnetron thermostat can be checked without pulling the oven form the wall.
But if you need to check the cavity thermostat, the oven will need to be removed from the wall, and it helps if you still have the installation instructions.
Whirlpool customer service is here and you can also enter your model number on that page to download your owner's manual, installation instructions, etc..
Oct 21, 2008 | Whirlpool MH7140XF Microwave Oven
Fuse keeps blowing.
couple questions -
what else is on the circuit,
and what current does the oven need
there are whirlpool over-range models with
1200watts of microwave,
1500watts of convection power, a
60watt bulb and a
375watt fan
over 15amps -20amp circuit needed
if you inadvertantly replaced a higher current fuse with a 15amp fuse, it will blow every time.
the install guide reccommends 20amp
not a solution, something to check,
Oct 14, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool GH518XP
Sounds like it got hit with a power spike which could have burned out the low voltage components, (Control panel). How's your insurance coverage?
May 22, 2008 | Whirlpool GH5184XPQ Microwave Oven
Whirlpool Miccrowave (GH7145XFQ-1) went dead...
Does the display light up?
Are you sure it is getting power?
Check that and get back to us cause the next step is going inside
Jan 01, 2008 | Whirlpool GH7145XF Microwave Oven
Whirlpool MH1150XMQ Microwave Oven Logo
178 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
