Question about Zanussi 18 in. DCS12W Free-standing Dishwasher
Pump continues to be '****' and will not move to next cycle.....
I have exactly the same problem...
It's happened a few times before, in the past i've unplugged and left over night.... in the morning all is fixed. However, yesterday it has happened again and the magical overnight fix is not working this time....
If someone can help it would be most appreciated...
    Master:
  • 560 Answers
HI only a suggestion please check your outlet hose for possible blockage by blowing down the pipe you will need a bit of force if you cannot then there is a blockage in the pipe, the programmer wont move until the water has been expelled first I hope that helps eric
Posted on Nov 16, 2017
2 Suggested Answers
SOURCE: Sometimed error being displayed but also not completing cycles and not performing a fast spin
Hi there, I've also had this problem a few times. I've found cleaning out the filter can help solve the problem of the E20 message. Also when it doesn't spin fast it usually means the load is uneven. I found it happens with towels or bedcovers, heavier loads, if the load is uneven it will spin slowly for a good few minutes and then just stop with the clothes still dripping. I found rearranging the load more evenly usually sorts it out. I've had my machine for 18months now and usually love it. It washes and dries well, however, my dryer has stopped working again! I'd only had the machine 7 months when the dryer first stopped working another 11 months down the line and it's not working again! Hope this helps. Lelly2003
Posted on Oct 31, 2006
Kenmore Elite HE5t Washer stops in the middle of cycle with no error codes. Any idea how to fix?
sounds like the door switch either needs adjusted or totally replaced .try leaning against .next time instead of opening it
Aug 24, 2015 | Kenmore Elite HE5t Washer
Dishwasher leaks a few drops of water in lower right hind corner during wash and rinse cycle
Seems as though you have all the bases covered as a technician I hate this call as it usually does not do it while on site I assume this problem recently started well something has changed if you feel the door seal and frame seal are good and unit is level with no suds one possibility is to look at the door lower it to the full open position should not travel past the 90 degree position next time you see water reach on the under side of the door there is insulation there if it is wet then water is splashing up and over the tub, factory has told me sometimes a hard start on the wash pump will splash also make sure the screws are tight on the wash pump sump cover good luck hope I helped some.
Feb 03, 2014 | KitchenAid Dishwashers
Washer will not go to the next cycle
if you manually move it past that spot does it run?if so you have a bad timer,if it fills with water and stops check the lid switch,open and close the lid a few inches,if you don't hear a clicking sound the lid switch is broke,next time send the model number and a little more info
Mar 28, 2013 | Whirlpool Washing Machines
Washer (total care system) is making a humming noise even though I've taken all the clothes out of it. The agitator works, but there's a humming noise. I've stopped it and re-started it, but...
Hi
1 of 2 things could be the trouble.
Does the washer drain properly if you manually turn the control knob? If not then this sounds like your pump is either plugged with possible lint and can't move or has died completely. 99% chance pump is the problem and 99% chance it can be an easy fix by cleaning the pump where the Drain Line is attached, worst case scenario pump is to be replaced, but not a overall expensive fix and most can do it without a technician.
Second problem is possibly the time itself, but if the washer is going through all cycles except spin then pump is likely the culprit, cause in spin cycle the machine has to drain the water from the unit as it spins, if it cannot the washing machine basically stops and cannot complete the cycle.
One way to tell for sure if the pump is the problem. When the machine enters the spin cycle and starts making that noise. Manually turn the dial a little bit till it passes the spin cycle, if it continues to wash till it hits the final spin/drain cycle then stops again...your pump is in need of help.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 04, 2011 | Kenmore 24032\24036 Top Load Washer
My Dishwasher (Westinghouse907 series) will not advance past the prewash/rinse cycle. I have cleaned out the filters. I also turned it off for a while and when I turned it back on it worked, but has now...
Hi
Thanks for using FixYa. If the cycle doesn't complete, then the first thing that should be checked is the Timer and then the heating element. Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it. Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
May 23, 2010 | Westinghouse 24 in. MDP531 RF...
Newer dishwasher and actuaslly says in manual do not be alarmed if you cannot hear dishwasher as it is very quiet. Well mine is the exact opposite. It is so loud. Sounds like the motor is in overload....
I would suspect there is something stuck in either your wash motor or drain pump. If the noise happens throughout the whole cycle, it's likely the wash motor, but if it only happens on start up and periodically thoughtout the cycle, it's the drain pump. The drain pumps are known however to get noiser after a few months, in which case I would have the drain pump replaced.
Apr 07, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Du1100xtpq7 dish washer keep repeating wash cycle doesn't go past this just keeps washing
Hi
Thanks for using FixYa. If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 07, 2010 | Whirlpool 24 in. DU1100XTPS Built-in...
Kenmore Elite fills with water, then stops. Only continues if I manually move knob to a different spot and it happens to go back on. Never the same spot though! Why would it get stuck? Is motor going...
Doesn't sound like anything is wrong with the pump because all that does is drain the water from the tub, my guess is you have a timer issue which is keeping it from going to the nexts cycle, or it could be you lid latch switch is going bad because if its not working properly it would keep the washer from going through its spin cycle to drain the water.
May 10, 2009 | Washing Machines
Electrolux ESL4114 problem
see other problems listed ,other machines have similar problems one chap suggests that the FLOAT SWITCH is stuck or faulty causing the inlet valve to read as full so continues program...
Oct 30, 2008 | Electrolux 18 in. ESL4114 Slim-Line...
Start button not working...can't get machine to start
The micro switch is bad. I had the same problem cleaned the switch a few time (nd bought some time) but in the end I moved a switch from a cycle we did not use to the start position. Cost was nothing but my time (must have skills in soldering PCB assy). Worked fine since, almost a year now. However I have had several unrelated problems and would thing twice before putting any major money into this unit. In the 3 years I;'ve had this unit I've fixed the switch, installed a new pump assy and put in 2 thermal switches (unit appears dead when they go bad). I've done all this myself and the bills would be between $700 nad $1,000 to call service.
Oct 21, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Zanussi 18 in. DCS12W Free-standing Dishwasher Logo
52 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
