Question about Dell Inspiron 6000 Notebook
Screen went dark (almost completely)
My 3 year old Inspiron 6000 just went dark on me while I was away from it and it was hibernating. The screen won't come back on and I can just barely see a ghost of a welcome window when I rebooted. Any suggestions?
  • 2 more comments
  • Babahao Dec 12, 2007
    I tried the fn/ brightness key already and the power cord. It should work on the battery alone anyway.
    I'm thinking of trying the inverter board first. Other sites seem to think if you can see a faint image, it usually is the inverter board and not the backlight. what think ye?
  • TaraD Mar 13, 2008
    i'm having the same problem. i have switched to a new lcd and a new inverter and it has not helped. any other ideas out there?
  • awicklund811 Jan 06, 2009
    I have the exact same problem - screen is VERY dark, but if you look very closely at it, you can still see what is going on -and everything else seems to be working fine.
    have any of these solutions worked for anyone else?
  • 156 Answers
When the following symptoms, you need to replace the Dell LCD screen
No image on the screen, but the power indicator stays in
Dark display but still readable
1/2 to several seconds between the screen flashes on and off
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Image cycle on and off, as well as high power LED light
Posted on Apr 29, 2013
Same thing happened to me. I removed the battery (which was bad anyway) and the screen worked. Go figure.
Posted on Dec 16, 2007
  • 36 Answers
Sounds like your LCD went out, I would have suggested the brightness thing as well as my laptop will go to a lower setting when the power is unplugged to save battery life.
The only other thing you could do is make sure the connection is good on the video connection to the motherboard. If you can't use this system with a docking station and a monitor you could always check ebay for a replacement LCD.
Posted on Dec 12, 2007
  • Brian Godfrey
    Brian Godfrey Dec 12, 2007
    That sounds worthy of pursuing. I would check that out as well but if it were me I would dig around for a deal on a complete replacement that had both the inverter and the LCD monitor just in case you need one over the other. Worst case scenarion you can turn around and sell the other one that you may not have needed back on ebay to someone else with a similiar situation.
Same thing! I went to control panel, then display, then settings, and clicked on troubleshoot. Immediately the brightness came back and all is well. Shut down and rebooted and all is still well.
Posted on Aug 17, 2010
    Scholar:
  • 54 Answers
Check your power cord and make sure it's plugged in all the way, and if it is, check your brightness setting.
Usually it's the Fn key + an arrow key. Make sure the brightness is up all the way
  • Chad Quicke
    Chad Quicke Dec 12, 2007
    well, I was going to suggest a lot more then that..but my rating is locked.. good luck
Dell Inspiron 6000 New Hard Drive, Now no Hibernate or Standby
Try to enable hibernation from command prompt
Click on start click run type cmd then ok, black screen will appear then just type command:
powercfg /hibernate on
If there is a problem with PAE we gonna need to disable PAE
Feel free to ask for questions
Jun 05, 2010 | Computers & Internet
My friend owns a dell inspiron 1545 that is less than a year old, but whenever she goes on the internet it randomly goes into hibernation and she has to log back in. She's tried doing system restore but it...
right click on open area on the desk top. Go to properties - screen saver - power monitor - go to the hibernate tab - uncheck enable hibernation - click apply then ok.
Oct 03, 2009 | Dell Inspiron 1545 Notebook
LG REAR PROJECTION TV DARK SCREEN PROBLEM
very possible unit has bad optical engine .May not be worth repairing.Optical engine is complete unit that includes lamp,LCD panels, fans,optics and other parts.They come complete and cost about 3-6 hundred dollars ..thanks
Jul 30, 2009 | LG 62SX4D 62" Television
Dell Inspiron 6000 screen goes black / hibernates / turns off
well go to your power setting by clicking on the battery by the clock and then say power options to change those setting such as Hibernating sleep ect... you can also get to this by going to you control panel then power options hope this helps
Jul 28, 2009 | Dell INSPIRON 6000 CENTRINO...
Dark screen ,fn does not work
I would suggest connecting the laptop to an external monitor, just to make sure that it is all running correctly.
If you can see a very dim image on the screen then the backlight is out. This can be a light problem or the inverter that powers the backlight could be bad. The inverter is not real dificult to change and also is not very expensive. If it is the backlight tho, it is easier to just change out the entire screen.
Hope this helps
May 02, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron laptop monitor is gone very faint
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 14, 2009 | Dell Inspiron 6000 Notebook
Screen stays black after closing and then opening Inspiron 6000
you try pressing the power button once?  or maybe even pressing any keys.
also try adjusting your power management
vista) start. control panel. power option.  Edit plan settings.
xp) right click anywhere.  properties.  screen saver tab.  power management.
Mar 09, 2009 | Dell Inspiron 6000 Notebook
Laptop back light
the cost to replace the lcd would exceed the value of the laptop. Be cheeper to get a new one.
Jan 28, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
1,232 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
