Question about Dane-Elec TA-SD0512-D MP3 Player
I can't even turn on my zMate MP3
When ever I push the on button the lights don't even blink. I even switched the batterys out twice. How do I turn it on and play music.
Hold play/pause to turn it on.  hold for about 3 seconds, it will come on, then press once more to play
Posted on Jan 02, 2008
So my urc-3021 used to work for my durabrand television. I went away for a few months and came back and the batteries needed changing. I changed them and the remote didn't work for the tv (although the...
then 0178 is not the right code if the light blinks twice try code search turn the tv on press tv then hold setup till it blinks twice then point the remote at the tv then press the power button repeatedly till the tv turns off then press the tv button again
Aug 28, 2010 | One For All URC-3021 Remote Control
My Yp-p2 does not turn on. When I try, it blinks red.
it locked just slide the hold swith above the pwer button *facepalm*
Feb 19, 2010 | Samsung YP-P2 Digital Media Player
Power button pushed battery light blinks twice won't turn on
I have the same problem for my dell note book
This is how i solve it
Unplug your note book from any power source
then remove the battery from the Notebook for
30 minutes after 30 minutes put back the battery and reconnect your adapter to power source turn on the power
Feb 19, 2009 | Dell Inspiron 5150 Notebook
Zmate mp3 player confusing
The A-B music is the repeat button.
Press the first time and you set the start point. Press it again later in the music and you set the end point and for that time on the player just plays from start point to end point and repeat it again. To remove the repaet option just press the A-B button once again. The lock button is to lock all the control buttons so that you don't accidentally press then while in the pocket. To put the music is no secret just insert the mini-usb cable in the zMATE and the computer and it should detect it as a usb drive in the next available drive letter. (if you have a network drive letter in the next available letter it will not appear and you must change the letter in the manage computer system, of course this is for windows systems)
Dec 28, 2008 | Dane-Elec TA-SD0512-D MP3 Player
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
If at this point the LED on the Sky remote control blinks three times then all possible codes for that make of receiver have been checked. Repeat from step one, ensuring that you enter the correct manufacturer code.
At the end of the sequence, if you see the TV Guide screen, the remote control setup process is complete. If you did not see the TV Guide screen, you must now complete the following steps.
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV.
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
Oct 17, 2008 | Philips HDD065 MP3 Player
Error number 1700 canon s9000 printer
knowing printer manufacturers I doubt they even have a sensor to detect that its full at all, they probably based on something crumby like print count. here are some instructions to reset the waste ink tank, the instructions vary so try them until one does the job :
Waste Ink Tank Reset
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice, then release all buttons
5: When the indicator lights steady, press RESUME three or four times. The indicator should be orange.
6: Press Power to set data
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
1. power off Printer
2. Push and hold resume button and push power button
3. Hold Power button and release Resume button
4. Push Resume button twice ( 2x ), and now release resume button and power button
5. Green light will blinking and stop.
6. When green light on, push resume button 4 x
7. Push Power button and printer will off, if that isn't off, push power butto again until print off position.
Aug 20, 2008 | Office Equipment & Supplies
MP3 Player
Check Battery is akaline or better and fresh. Try new ones from different packs. Brand new batteries can be bad. For further steps see my post on Zmate MP3.
Jun 19, 2008 | Dane-Elec TA-SD0512-D MP3 Player
Zmate mp3 not recognised
Try a different cord, USB port, and bypass any splitters if used. Then try another USB support driver in Device manager.
Dec 28, 2007 | Dane-Elec TA-SD0512-D MP3 Player
Dane Elec ZMate MP3 Player wont play!!
Make sure if it's the player that uses SD cards, the songs can't be in the root.  They must be in a sub-folder (subdirectory), preferably one named AUDIO.
Sep 05, 2007 | Dane-Elec TA-SD0512-D MP3 Player
Going thru batteries
Jun 01, 2007 | Dane-Elec TA-SD0512-D MP3 Player
Open Questions:
Dane-Elec TA-SD0512-D MP3 Player Logo
147 people viewed this question
Top Dane-Elec Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
Stan Ford
Are you a Dane-Elec Audio Player and Recorder Expert? Answer questions, earn points and help others
