Question about Nokia 1100
Apple I tried to charge my IPhone using an Ipod charger. Now the Iphone won't charge. Could I have damaged the battery - I've only had it a week so maybe it's a bad battery? Thanks!
    Problem Solver:
  • 7 Answers
Its just for temporary.. will ok in couple of days.. :)
Posted on Dec 12, 2007
My iphone won't charge up at all i put it on
hi there.
Follow these steps:
  1. Remove any debris from the charging port on the bottom of your device.
  2. Restart your iOS device.
  3. Try a different USB cable or charger.
  4. Make sure that you have the latest version of iOS.
  5. Contact Apple Support to set up service.
If your iPhone, iPad, or iPod touch won't charge - Apple Support
Why my iPhone is not charging?
2: Change the Wall Outlet or USB Port Plugged Into. The next most common reason aniPhone won't charge is because of where it's actually plugged into. Sometimes the wall outlet itself isn't working or the light switch is turned off, so if you're using a wall charger then change the outlet.20 Feb 2016
iPhone Won't Charge? Here's Why iPhone Isn't Charging & How to Fix It
How do you clean the charging port on iPhone?
To be safe, back up your iPhone or iPad to your computer or the cloud. Power it off, and with a normal toothpick, gently remove the lint. You will be amazed how much can get stuck in the port. Connect the charger and see if it works.16 Dec 2014
Use a toothpick to clean out your iPhone - CNET
How do I charge my phone if my charger port is broken?All you need to do is shut down your device, remove the battery if possible and use something small, such as a toothpick, to 'lever up' the little tab inside the USB port on your smartphone or tablet. Do so very carefully and gently, then reinsert your battery and plug it in again.16 Jul 2016How to fix a phone that won't charge properly - AndroidPIT for: How do I charge my phone if my charger port is broken?
or try this link.
iphone won charge up Google Search
Nov 19, 2017 | Cell Phones
Ipod not charging when i connect it to the usb port. or iphone.
If an alert says that your accessory isn't supported or certified. These alerts can appear for a few reasons: Your iOS device might have a dirty or damaged charging port, your charging accessory is defective, damaged, or non Apple-certified, or your USB charger isn't designed to charge devices
If your iPhone iPad or iPod touch won charge
How to Fix an iPad iPhone or iPod Touch That Won Charge Anymore
Help My iPad Won Charge
Help My iPod Battery Won Charge
ipod do not charging when connect it to the usb port Google Search
on Dec 06, 2017 | Computers & Internet
Iphone won't charge from ac adapter
contacts on ac insertion tip slightly damaged check by having friend or simular product attempt to charge theres ? yes it works on others?thenits your female reciever entry on phone is damaged due to tip end on charger being inseted when not aligned perfectly lots of phones do it if that is the case check policy on damage w/out posting your idenity generic review ,your most likely not covered so 2 choices get old phone same exact sameis required and charge back-up battery to op phone but smart phones freak on O.S. BEING YANKED OFF NOT GOOD 2ND IS LOOSE IT OR TURN EYE WHILE BAR FLY POCKETS REPORT GONE CANT SEE WHO GET REPACEMENT WHEN IT DOES FAIL OR GET SCREWED BY PHONE CO. LIKE US BUY 2ND IPHONE 1 WEEK AFTER 1ST ONE CARRY 2ND LINE AND WAIT 6 MO. FOR CYCLE TO DROP NON USED AIR WE PAID 129 MONTH ON BOTTOM DEAL WENT TO 200 +EA. MONTH YOUR CHOICE CRAIGSLIST EBAY AUCTIONS PAWN ARE MOE HONOABLE THEN SENARIO I AIRED MY PAIN I WOULD NEVER LET THE CO. HAVE MY MORALS OVER PHONE ISSUES OR ANY MATERIAL GOODS GOOD LUCK I WISH YOU WELL
May 02, 2012 | Apple iPhone 4 Black Smartphone
Iphone won't turn on
What happens when you try to charge the device?Won't charge?Switch chargers.
Try hard resetting it and see what happens.Here's a video tutorial on how to go about it.
Hope it helps.Thanks
Feb 21, 2012 | Apple iPhone 3GS Black (16 GB)
I dont know what happend but my 4th gen ipod was working perfectly fine then i got an ipad so i was addicted and i put my ipod aside for about a week. Of course it ran out of battery so i charged it, you...
Attempt a hard reboot of the device by holding the home button and the power button at the same time. Contact AppleCare if the problem persists. Also, don't use the iPad's charger on the iPod or an iPhone. It doesn't play well with it.
Jun 02, 2011 | Apple Audio Players & Recorders
Iphone 3g proper charging
Once you purchase the iphone,dont use it yet.Instead of using it right away,kindly charge your IPhone with the wall charger for 3 hrs.Please dont use the Iphone while charging.Kindly check always if the battery is full.Once its fully charged then that's the time that you can use the iPhone. Once fully charged, let the iPhone's battery fully drain.Please keep the iPhone off for 2 hours.Fully charge your iPhone and allow the battery to rest in the fully charged state for two hours. (You may use your iPhone during this time as long as the iPhone is plugged in).Repeat the third and fourth step a maximum of three times if you feel your battery indicator is inaccurate.
Here are some tips for your everyday charging for your IPhone:
#1 - Charge your iPhone throughout the day when available. Charge EVERY night, regardless of charge level. This will keep your battery active, which is healthy for the iPhone's battery.
#2 - Use a wall charger or car charger w/ rated output 5V 1A. Computer chargers might not charge when the computer is in standby mode.
#3 - You cannot overcharge your iPhone. You don't need to disconnect the iPhone from the charger after it's done charging. Once fully charged, the iPhone will run strictly off of AC power and will not damage the battery.
#4 - Every two months, make sure you fully charge and fully drain the battery, in one cycle. This calibrates your battery indicator. If you fail to do this, your indicator will become inaccurate. Calibrating your battery does not improve battery life.
#5 - If you ever need to store your iPhone for any reason, make sure your battery is stored @ roughly 50% and in a cool environment.
#6 - Always charge your iPhone out of its case (assuming you can easily remove the case). Charging your iPhone inside your case will make the iPhone hotter, which is bad for the battery.
#7 - Charge your iPhone in a cool location. Charging your iPhone in a cool environment has a tremendous impact on your battery's lifespan. The colder the location you use to charge, the more charging cycles you can complete without your battery deteriorating. Avoid charging in direct sunlight.
#8 - Use properly rated chargers. Using chargers that are not properly rated will have a huge impact on your battery's lifespan. Make sure your car charger has the same rating as the official Apple charger.
The official Apple wall charger is rated as follows:
Input: 100 240V ~ 50/60 Hz 1.0A
Output: 5V 1A
Apr 15, 2011 | Cell Phones
How do I charge my new iphone 16GB?
Your new iPhone comes with a USB cable and a wall charger in the box. If you don't have a computer, you can plug the wall charger to any socket in your house and connect your iPhone to the wall charger using the USB cable. However, if you have a computer, you can plug the USB cable to any USB slot from your computer and connect it to your iPhone.
You can also charge your device from any iPhone dock, or even those docks attached to your home theater system.
For more iPhone / iPod touch tips, click here.
Feb 12, 2010 | Apple iPhone (16 GB) Smartphone
IPhone wont charge after plugging into the wall.
There are three solutions to your problem:
1) The battery needs to be replaced; or
2) The charger is defective (if you have a car charger you can use it to see if the phone will charge. If it will you'll need to replace the wall charger.) or
3) Your phone needs to be sent to a service facility for repair.
Feb 01, 2010 | Apple iPhone Smartphone
My iphone wont charge
It can also be the battery. Maybe you need to change it.
Aug 07, 2009 | Apple iPhone Smartphone
Ipod not charging
hi Unpopster.
these links might help you find out why.
or this one.
If an alert says that your accessory isn't supported or certified. These alerts can appear for a few reasons: Your iOS device might have a dirty or damaged charging port, your charging accessory is defective, damaged, or non Apple-certified, or your USB charger isn't designed to charge devices.
Dec 06, 2017 | Audio Players & Recorders
Nokia 1100 Logo
19 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
