Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity Front Load
Previous load didn't spin out. Tossed around but no actual spin cycle. Tried again after a 1/2 hour and then nothing. Hear a motor but no water or movement.
  • 11skeets11 Dec 30, 2007
    does not spin very fast,,cloths are very wet when finished
Mine wouldn't spin out the cloths very good,,they were real heavy and wet. I took the lines off of the pump and pulled it off,,,to my suprise,there was about $3 in change in the pump...cleaned it out and put it back together and it works great again. no idea what that had to do with the spin speed,,,,but it worked.....just an idea
Posted on Dec 31, 2007
Where is the pressure calibration switch on an affinity front load washer?
Hello garrett_lind, I appreciate your inquiry!
From my understanding you are searching for the pressure calibration switch on your Frigidaire washer due to the fact that it is not spinning on the last cycle. Some possibilities as to why your appliance is not spinning could be your timer or drain pump. I could not locate steps to access the pressure switch but for electrical components I would recommend having a professional come out to properly diagnose and repair the appliance. -Matt
Aug 12, 2014 | Frigidaire Affinity ATF7000ES Front Load...
How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin Read more: How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin | eHow.com http://www.ehow.com/how_6496482
Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly. Contact a professional to move forward accurately.
Oct 21, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF7000E Front Load Washer won't stop spinning with 1 minute on timer- it continues until I hit cancel. I don't like to babysit a machine but have to make sure it doesn
If the unit is washing properly, as far as you can tell, but it won't stop spinning, then I would have a professional look at the control panel and timer to be diagnosed because there seems to be in miscommunication.
Sep 14, 2012 | Frigidaire Affinity ATF7000E Front Load...
How to diagnose
Sounds like your motor is blown. That's going to require a repairman.
Mar 31, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Final Spin Cycle gets stuck at 1 minute
back tub bearing,,and spin surport,,defective,,,under warranty,,,call for service..onthejob
Dec 10, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
