Question about Dell Inspiron 1100 Notebook
Toshiba 4600 - replace P3 700mhz with P3 1ghz
Hi, can I simply pull out the existing CPU and replace it with the faster P3 1ghz processor which some 4600's came with (just that the serial number for the motherboard is different). The only difference in the specs is that the voltage is slightly different 1.6V (700mhz) and 1.7V (1ghz). Thanx!
  • Tracilee Dec 26, 2007
    I have an HP pavillion DV6500 and want to upgrade the processor, I have experience in soldering tiny objects and want to know if it's possible to just replace cpu with better one/? Ordering the CPU from company is that possible"?
  • 26 Answers
No you can't pull out as the CPU is surface mounted soldered on the mainboard, only manufacturer or approved repairer can take it out and put the new CPU with only the correct voltage specs.
don't try yourself otherwise you will damage the entire laptop.
Posted on Dec 12, 2007
I cant play fifa 09 on my acer aspire one 522, is it with the resolution? how can I fix this?
Your processor is the problem : It's a dual core 1GHz AMD C-Series processor C-50 and even though it might barely be able to run the game, the game was made before the processor type was released, and thus the game doesn't know what the heck it is and only sees that its a 1GHz CPU and thus considers it to slow to run the game.
Here are the system requirements:
Operating Systems: Windows XP SP2 / Windows Vista - CPU: 2.4 GHz
- RAM: 512 Megabytes of RAM (1 GB required for Windows Vista)
- DirectX 9.0c Compatible 3D accelerated 128 MB video card or equivalent (must support Shader Model 2.0 or above)
- DirectX 9.0c Compatible Sound Card
512kbit/s or greater broadband connection for online gameplay
- 6.1 GB free hard disk space for DVD format and additional space required for DirectX 9.0c installation
- 8x or faster DVD-ROM drive
May 23, 2012 | Acer Aspire One AOD150-1920 Netbook
Hello, For the purposes of installing Windows 7
To run windows 7 you need ...1 GHz CPU ( processor) or faster ..for 32 bit ..and for windows 7 x64 you need a x64 processor.1 GB RAM for windows 7 x322 GB RAM for Windows 7 x64DirectX 9 graphics device with WDDM 1.0 or higher driver and 20 GB disk space.
I would recommend you to install Windows 7 32 bit ,it will work better with your laptop.
Please click here or the link below :
http://www.cpuid.com/downloads/cpu-z/1.59-setup-en.exe
and download / Run Cpu-z and send me more details about your laptop (fujitsu siemens model #), processor (cpu model # ), graphics ..and i will provide help to solve this problem .
Dec 23, 2011 | Fujitsu Siemens Pentium III-S , 1.4 GHz...
Can I install a better CPU into my Toshiba Satellite P305D-S8834 17 1 Widescreen Notebook Computer then the AMD Turion X2 Processor RM-70 it came with?
Changing CPU is a serious change. When your unit was built the processor speed and type were written into the BIOS. When we change the CPU to a different type there is a chance that the BIOS will not recognize it and refuse to boot up. Also Windows was installed with the original CPU and a major change in hardware could mess up Windows.
I did some research and found this model comes with a 2.0-GHz AMD Turion X2 Dual-Core RM-70 CPU and 4GB of RAM. This is not the fastest CPU that can be put in a laptop but a very good one. (faster than mine)
I can guide you through the steps to replace it but my advice is stick with what you have until it breaks and buy a faster laptop. The upgrade won't gain you enough to justify the expense.
May 21, 2010 | Toshiba Satellite P305D-S8834 Notebook
I am wanting to upgrade the cpu to a faster
You dont need to know your southbridge info or anything like that, you just need to know the socket type for the processor. If they make a processor for the socket type, then you can assume it is compatible.
Jul 17, 2009 | Toshiba Satellite M45-S331 Notebook
Find maximum processor size for aopen ax34-u motherboard
u wont be able to install a cpu much faster than 1ghz without flashing the bios.....
if you do not know how to do this then plz do not attempt it as if it geos wrong or you have a power surge then the mobo will be NFG.......
Feb 24, 2009 | AOpen AX34-U Motherboard
CPU Upgrade
You pulled the processor out of your laptop ... that was a brave move ... generally laptop boards are fully integrated so there is very few options on changing the processor ... also because of the extreme heating conditions the heat sink bonding is very critical ... make sure you replace this properly or you will have overheating issues in the future ...
Mar 30, 2008 | Toshiba Tecra 8100 Pentium III, 850 MHz...
Up-date processor.
Check the manual for jumper settings on the cpu frontsidebus frequency. Also find out your cpus fsb or frontside bus speed and match it with the motherboards jumpers if possible.
How to find out details of the processor?
Pentium III 1ghz - download cpuz www.google.com cpuz download
it will tell you more details of the cpu. If you post here a image of the cpuz screen or all the details it shows you can I tell you the correct fsb speed.
Then you need to find your motherboards manual and the part about those jumpers. and set them correctly.
Feb 15, 2008 | ASUS SiS Chipset CUSI-FX Motherboard
Upgrade the processor on a Toshiba equium l40 series from a celron M
The core2 duo chips will be a different socket to your celeron cpu so can do that unfortunately. You may be able to upgrade to a faster cpu of the same socket type but will probably need a bios update for it to run at proper speed.
Unfortunately laptops arent really designed to be upgraded at all bar extra ram/hd/dvdrw.
Hope that helps?
Dec 26, 2007 | Toshiba Celeron, 2.50 GHz (P000396980)...
P4 ugrade required
Sadly you wont find any 1066Mhz FSB processors for the Socket 478. The best you can find is the 3.4Ghz with 800Mhz FSB. It might be cheaper and also better value for you to get a Socket 775 based motherboard and Core2 Duo processor. The value range E2160/2180 processors or the E4300/4400 processors have been tested to be even faster than the Socket 775 Pentium Dual 3.4Ghz and they also use less power.
An article on socket 478 for you http://www.xbitlabs.com/news/cpu/display/20040123103754.html
Dec 02, 2007 | Intel P4 Socket-478 Original CPU Cooling...
Dell Inspiron 1100 Notebook Logo
70 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
