Question about Dryers
Trouble with Maytag Legacy gas Dryer
Our Maytag gas dryer runs (and drys) for 30-45 minutes, then shuts off and won't restart for 30 minutes. We have redirected the vent so there is on 90 degree bend and 3 feet of stove pipe to the outside. We have replaced the motor, timer, and thermostat. Maytag won't even talk to us any more. What is shutting down this dryer?
  • 2 more comments
  • William Dean Dec 15, 2007
    The model number of this dryer is MDG308DAWW
  • William Dean Dec 23, 2007
    Thanks. The bathroom has been recently re-wired, and there are a couple of strange electrical things going on that puzzle us. So we are going to call in the electrician to troubleshoot.
    Deanonu
  • William Dean Jan 17, 2008
    You were right on. I bought a voltmeter and checked the voltage both static and operating. Then I checked it all over the house. The meter read 145 volts at every outlet. That explains why we were popping light bulbs every three weeks, and why the motors on the new bathroom exhaust fans had burned out. But before we could call the power company, the transformer outside blew, and they replaced it. The voltage now reads 120 volts, and the dryer works just fine. Thanks for the suggestion. I would not have considered that.
  • Anonymous Mar 12, 2014
    I want to see what the part of our is comparable maytag Dryer gas Timer
  • 290 Answers
Please provide the model number and I will see if I can figure something out.
It sounds like you have covered the common problems. Usually a motor is the cause for this problem, it gets hot and shuts down until it cools off. I have had some problems with the auto dry controls on the Maytags also.
Are you equiped to do some voltage checks if we need too? This would help in knowing where you have power when it quits.
Thanks/Mike
Posted on Dec 12, 2007
  • 1 more comment
  • Michael  Lindley
    Michael Lindley Dec 16, 2007
    When you say the dryer shuts off, I am assuming the motor is stopping and the whole machine quits running. If this is the case, and you have installed a new motor and made sure nothing is inside the blower housing causing the motor to drag, check your voltage at the wall outlet. If you have more that 125 volts or less than 115 volts, check some other outlets on the same circuit and if they are the same reading call the power company to check the transformer supplying the house. A high or low voltage will cause the motor to heat up and kick out.
    If I have misunderstood your problem and it is only the burner that is shutting off and not the motor, then you need new coils on the gas valve. There are 2 of them mounted on the valve. You replace them as a set called the "coil pack". When one starts going bad they will usually work fine until they get hot then stick and not cycle back on.
    Let me know what you find out. I have a call on a heat pump to run today and will be checking back in this evening.
    Thanks/Mike
  • Michael  Lindley
    Also, when you check the voltage to the dryer, if it has 120V with the dryer off, check it again with the dryer running to make sure it doesn't drop. If it drops when you start the dryer you may have a loose connection in the circuit and may need an electician.
    Mike
  • Michael  Lindley
    Michael Lindley Jan 17, 2008
    Glad to be of help. It is a common problem that is often overlooked. I have done it several times myself.
    Mike
Maytag ldg26cs gas commercial dryer never shuts off, runs normally and drys clothes but never stops or goes into cooldown mode.
Sounds like timer is stuck in one place and not counting down, can it be done manually? If so replace timer.
Dec 15, 2013 | Maytag MDG7600AW Gas Dryer
Maytag Legacy gas dryer shuts down
too complicated the inner machinery is not working nome its bettter to go for a newer one
Dec 16, 2007 | Dryers
Hi, I have a Maytag gas dryer MDL# LDG8200AAW and its great my wife would not trade it for one of the new ones at all. The problem that I'm having with the dryer is that it drys the clothes but it does not...
Correct, Your belief is wrong! Your wife's belief is correct, the best dryer ever made!
If this happens only when you are using it on an auto setting then it is probably an air-flow problem,a dirty exhaust system. Clean it out!
Jul 12, 2017 | Maytag Dryers
Heats for the first 3 minutes or so and then just drys cold air.. is it a thermostate problem?
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 24, 2010 | Whirlpool LER5636P Electric Dryer
I have the Maytag MCG8000AWW gas "drying center", it tumbles but does not have any heat. The burner lights when the cycle is started, and for a few minutes it does heat. Then the humidity indicator changes...
Gas Dryer not Working Gas Dryer Not Heating
If your dryer is electric2_bing.gif..
Dryer Troubleshooting2_bing.gif Electric Dryer won t Heat
heatman101
May 06, 2010 | Maytag Neptune MCG8000AW Gas Dryer
The dryer turns on, then drys for a few minutes,then shuts down
this is either a fuse ,relay or heater problem your best to call for a technician unless you can measure continuity between each of these with the power off .90 % of the time this is due to a build up of lint inside the dryer
Apr 28, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
The igniter fires the gas, it burns for a minute or less, then stops and won't restart unless the dryer is stopped and restarted? Is this a coil problem?
Sounds like a clogged vent. If you let it run for a few minutes after it shuts off, it will come back on. Your overtemp. thermostat doesn't allow it to work, because the hot air is not being sucked in. But to answer your question, not the coils for sure in my opinion. When coils fail, it won't turn on after 10 min of running or more. Not right away.
Maytag Neptune dryer repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | Maytag MDG9206 Dryer
Dryer gas heat not staing lit
It is probably electronic gas valve, or safety valve that let the gas flow and shuts off immediately. Better take it to the repair shop will save yourself $75.00 service fee.
Dec 30, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
Apr 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag gas dryer fires, then shuts down
may be the coils on the gas valve. there are 2. usually they need replacing when the ignitor glows but no flame
Nov 20, 2008 | Maytag Dryers
Dryers Logo
557 people viewed this question
Top Dryers Experts
