Question about Eclipse (AVN7000) Car DVD Player
Screen Blockage I have an Eclipse AVN 7000. About 2 weeks ago I went to listen to Sirius Satellite an updating pop up on the screen and has been there since. How do I get rid of this?
  • 4 Answers
Re: Screen Blockage
Try unplugging your sirius unit then plug it back in. Do this for the power.
Posted on Feb 27, 2008
0 characters
3 Points
I have a eclipse avn 7000, I need to know which pin on the unit is hot ground and acc? Not the wires the pins where the wires plug in
I would recommend you purchase a new harness. Connecting a wire to the individual pins and then insuring that none of the leads touch another is difficult at beat. Replacement power/speaker harnesses are only $7 to 10. A simple google search showed several vendors.
Aug 19, 2016 | Eclipse Car Video Players
How do I bypass the emergency brake on my Eclipse AVN 7000
You will have to connect the brake wire which is pink to the the ground wire.
Apr 27, 2010 | Eclipse (AVN7000) Car DVD Player
My eclipse avn 7000 won't calculate a route with the gps anymore, I recently changed the battery, help!
try this:
• After it says “CALL 800” on screen
• Press and hold MAP and AV buttons at the same time
• While holding MAP and AV buttons, Press the
MENU button 5 times continuously
• Screen will show up with 6 digit security code
• Enter Unlock Code by using touch screen
• After entering the unlock code press ENTER on
Aug 01, 2009 | Eclipse (AVN7000) Car DVD Player
Reset my AVN 6600
I was told by Eclipse you have to buy a update dvd.
Dec 08, 2008 | Eclipse AVN6600 Car DVD Player
AVN5500 - Display stuck at "Updating" when using Sirius.
yes it is the sirius unit I was told to drop all power while system is on disconect the battery while ignition is on then turn back on and wait ten min for update to complete if that does not work call sirius to have them send the update mabe they can tell you when its complete hope this helps..
Aug 07, 2008 | Eclipse AVN5500 Car DVD Player
Wiring Diagram
You can find it here; Best of Luck.
Oct 03, 2007 | Eclipse (AVN7000) Car DVD Player
Eclipse (AVN7000) Car DVD Player Logo
137 people viewed this question
Top Eclipse Car Video Players Experts
Are you an Eclipse Car Video Player Expert? Answer questions, earn points and help others
