3 possibilities for a no drain...1 the unit has an extended drain hose and the coupling between the factory hose and the extended hose is plugged.
2 the drain is plugged inside the unit at the drain outlet, 3 the drain pump has failed. not likely the pump, usually a plugged drain line, so check the drain hose first to see if it is plugged.
