Question about Toshiba MV13DM2 13 in. TV/VCR Combo
Can't program channels with universal remote
I have a GE universal remote, millions of buttons. I got it to work in TV and VCR mode seperately on the unit. Using the TV function I got the menu to display and I can move up and down on the menu, but none of the buttons will execute the ENTER function on the menu screen. This means I cannot program the TV to be in CABLE mode or AUTOSEARCH. Right now it is in antenna mode so only like 20 channels come in and I have manually enter the numbers for each of them. If anyone knows how to make this work I would greatly appreciate it.
I tried using another universal remote with less buttons and was still unsuccessful.
  • sueRN Jan 24, 2008
    I have the same problem w/ a Samsung TV, so let me know if someone knows what to do.
    Top Expert:
  • Toshiba Master
  • 76,001 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
Posted on Apr 09, 2017
SOURCE: Lost factory remote
you need the remonte control original bath this situesen you need the selection deader cod four your remont controler
Posted on Jul 12, 2007
SOURCE: can not access menu from universal remote
mmm
Posted on Jan 28, 2008
  • 395 Answers
SOURCE: mv19n2 tv vcr
AD301651 is the part number for the remote and you can get them at www.vancebaldwin.com
the manual you can download here http://tacpservice.toshiba.com/ConsumerProductSupport/Manuals/TV/mv13n2_w_mv19n2_w_ownman.pdf
Posted on Jan 31, 2008
  • 4 Answers
SOURCE: Need help to re-program Toshiba remote that came with MW20FM1
Check out Toshiba Customer Support. They e-mailed me the instructions to reset the V-Chip.
customer_support@tacp.com
Posted on Sep 14, 2008
PABLOCSA
  • 1124 Answers
SOURCE: Universal Remote Codes
Try, 0045, 0043, 0845 or 0154, 0156, 0060
Posted on Feb 03, 2009
Need the code to program my universal remote to my jvc tv the serial# to my remote is rc24922-c1122 model jc024
Do a code search method as follows.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Dec 26, 2014 | GE 24926 Glow Keys Universal Remote...
Need a code for zenith/vcr combo.
Program a GE Universal Remote Using Code Search Make sure the device for which you want to program the remote is turned on, and that the GE universal remote has good working batteries in it. Batteries that are weak may keep the universal remote from being programmed. Press and hold the Setup or Code Search button. Again, the name of the button will vary between GE universal remote models. Once the indicator light is lit, you can stop pressing the button. Press the button with the name of the device for which you want to program the GE universal remote (such as TV or DVD) and release it immediately. The indicator light should flash a time or two and then simply stay lit. Now all you have to do is point the GE universal remote at the device you selected, press the Power button and release it. The catch is that if the device does not turn off, you must wait at least two seconds and try again. The GE universal remote will attempt to program the right code for the device, cycling through all of its built-in codes. This can take up to 250 attempts. When the universal remote (finally) catches the right code and is programmed, the device will power off. Once this happens, press the Enter or Save button on the GE remote to complete the programming process. and for free
Jun 02, 2011 | Televison & Video
LACK OF CODE PORTABLE TV WITH DECK FOR UNIVERSAL REMOTE CONTROL
Hello
Three digit remote code for GE TVs are:-
000/ 003/ 004/ 009/ 022/ 031/ 044/ 052/ 054/ 055/ 087/ 092/ 103/ 107/ 125/ 164/ 181
Four digit universal remote code for GE TVs are:-
0031 0107 0164 0004 0009 0044 0054 0000 0342 0003 0125 0015 0022 0052 0087
Four digit universal remote code for GE TV/VCR Combo is
0342
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
OK.
Dec 04, 2010 | GE SpaceMaker 05GP009 Television
I can't get any channel to work with my dvd
usually has to be on channel 3 then use the tv/vcr button on your remote.if you are already using this for a vcr then you need to program the dvd on another alternate.Best results is to get a universal remote and program tv/vcr/dvd seperate.
Dec 19, 2008 | Symphonic ST419E TV
Hello I have a philips universal remote, don't know what model it is I thought all Universal remotes was one Model. Last night I tried using it for my TV to swich from TV to DVD and it just stopped...
Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
Programming with Code Search
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
http://www.remotecodelist.com/remot...ps-Magnavox_PM525S.pdf
Hope this helps you out, good luck.
Dec 01, 2008 | Philips Magnavox Learning Universal Remote
I need the code to program the philips universal remote to a sylvania tv
Nov 28, 2008 | Philips Magnavox Learning Universal Remote
I have a philips universal remote and an Rca Tv how can I program
code list is also listed
Lost remote programing directions
Nov 27, 2008 | Philips Magnavox Learning Universal Remote
Need VCR codes for Magnavox Universal remote model CL034
Nov 26, 2008 | Philips Magnavox Learning Universal Remote
Need codes for a philips universal remote code sheet
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Hope this helps :)
Jun 21, 2008 | Philips Magnavox Learning Universal Remote
Toshiba MV13DM2 13 in. TV/VCR Combo Logo
59 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
