Question about Proview PL913B 19" Flat Panel LCD Monitor
Mode not supported
On startup to dell tower windows xp shows them message staing "mode not supported"
    Problem Solver:
  • 7 Answers
This only for a temporary.. if the monitor is new its like the monitor try to get in touch with (get use) with your cpu.. :)
Posted on Dec 12, 2007
Doesn't enable virtualization
To determine whether your PC supports hardware virtualization:
Step 1. Does my PC have a CPU with support for hardware virtualization?
Download and run the Hardware-Assisted Virtualization Detection Tool
If you receive the message This computer does not have hardware-assisted virtualization, your computer does not meet the hardware requirement for Windows Virtual PC, but you can still use Windows 7 XP Mode by running this hotfix. Be aware that XP Mode will run much better if hardware-assisted virtualization can be enabled.
If you receive the message Hardware-assisted virtualization is not enabled on this computer, go on to Step 2 below.
If you receive the message This computer is configured with hardware-assisted virtualization, download and install Windows Virtual PC and Windows XP Mode.
Step 2. Does my PC BIOS support hardware virtualization, and is it turned on?
Instructions to turn on hardware virtualization in your PC BIOS are specific to OEM models. It is important that after changing your BIOS settings the PC is completely shut down at the power switch before restarting so that the new BIOS settings can take place.
Examples for some models of some computer manufacturer's BIOS settings are below:
Sample instructions for your PC
Expand all
Dell systems
Depress the F12 key when boot menu text appears at startup
Select BIOS setup and depress the Enter key
Using the mouse, expand the Virtualization Support menu item by clicking on the plus to the left of Virtualization Support and select Virtualization
Check the Enable Intel Virtualization Technology checkbox
Click Apply
Click Exit
Fully shut down (power off), wait a few seconds, and restart your computer
HP systems
Depress Esc key when prompted at startup
Depress the F10 key to Configure BIOS
Scroll to System Configuration using the arrow keys
Select Virtualization Technology and depress the Enter key
Select Enabled and depress the Enter key
Depress the F10 key to save and exit
Select Yes and depress the Enter key
Lenovo ThinkPad systems
Depress the blue ThinkVantage key when prompted at startup
Depress the F1 key to enter the BIOS setup utility
Using the arrow keys, scroll to Config and depress the Enter key
Scroll to CPU and depress the Enter key
Scroll to Intel Virtualization Technology and depress the Enter key
Depress Enter key to continue
Depress F10 key to save and exit
Acer
PCs capable of supporting Windows XP Mode have already been enabled and do not require additional configuration.
Asus
Samsung
Panasonic
Depress the F2 key when boot menu text appears at startup
Select Advanced menu in Setup Utility
Change "Intel Virtualization Technology" setting from Disable to Enable
Depress F10 to exit Setup Utility
Select Yes in confirmation menu
Depress Enter to exit confirmation menu.
Please note the instructions above may not work in all cases and consulting with your computer manufacturer may be necessary. Additionally, we expect hardware virtualization to become more available when Windows 7 is shipped, particularly in business-class PCs. For those PCs that come pre-installed with Windows XP Mode we recommend the computer manufacturer turn on hardware virtualization before shipping the PC.
Once you have confirmed your PC supports hardware virtualization
Download and install Windows Virtual PC and Windows XP Mode
hope this helps
Aug 08, 2012 | Computers & Internet
I can't find the ink level on my 4200 hp since i went to dell and windows 7. my windows xp showed the levels when i scanned.
The issue is with the driver you are using for the 4200- I suspect if you visit support.hp.com, you would find the utility for windows 7 that would have the same function as in windows XP
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Jan 21, 2011 | HP Thin Client - AMD Geode NX 1GHz - 256MB...
I get a blue screen error message ''c000021a unknown hard error'' after running CHKDSK as a result of receiving an initial blue screen error message ''The Type of file system is NTFS. The volume is...
Hi, Boot into Safe Mode by pressing F8 at bootup and choose
'Safe mode with command prompt'
At the command prompt type
C:\Windows\system32\restore\rstrui.exe
Hopefully System Restore will open so choose a Restore Point a few days ago.
Please rate my response!! Thanks, SF
Jan 28, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Windows XP on my E-Machine T5048 will not start. I get the message and it retry "start windows normally" but it keeps coming back to same message
please try hitting F8 during startup and choose emergency mode to see is it driver fault. if it is system will boot up into emergency mode. if not then most likely system is damageed
Dec 06, 2009 | E-Machines T5048 (7136) PC Desktop
Neighbor's PC stops booting when it shows the Windows XP logo on screen....no error message
Try Startup in safe mode by tapping the F8 key on startup The Windows Advanced Options Menu appears.chose safe mode....
Oct 28, 2009 | Computers & Internet
Error: Cannot Display This Video Mode
You may have to boot into safe mode and reset the video settings to a safe setting like 1024x768.
  1. To get into safe mode, continuously press F8 while the computer is booting up.
  2. Eventually you will get a Windows XP Boot Menu.
  3. Choose the option for Safe Mode.
  4. Go to Start, Control Panel and double-click Display.
  5. On the Settings tab, drag the slider bar to 1024x768.
  6. Click OK
  7. Shut down and reboot.
If the problem goes away, then you are good. Otherwise, you'll have to boot menu again (F8) and choose Enable VGA Mode.
Aug 29, 2009 | Dell OptiPlex GX620 PC Desktop
Dell Vostro will not boot up
During startup, just before the Windows splash screen appears, you should be able to hit the F8 key for a list of startup options. It looks from your post as if you know how to do this.
One of those choices should be to disable automatic restart on system failure. (or words very similar to that.) Use this choice to get into safe mode if you can, or into regualar windows.
Once there, go to the system restore feature and restore to a date when everything worked.
This error message is a message pointing to a piece of software (as opposed to hardware, as so many of these messages are).
The next best fix is to reinstall the OS from the ground up. this may be a major hassle, depending on the data you have on that hard drive.
Good luck
tony
May 18, 2009 | Dell Vostro 1700 Notebook
Dell Inspiron B130 Startup Issues
when digit the password to initiate does not initiate and it gives the following message me:
The User Profile Service service failed the logon.
User procases out cannot sees loaded
por favor la repuesta en español
Compaq Presario CQ60-215DX Note book PC
May 10, 2009 | Dell Inspiron B130 Notebook
Job Status Window Interface has stopped working.
The issue usually occurs if you are using windows xp drivers on a vista machine. It's strange that the error does not come up when printing from internet explorer 7.0.
There is a file on support.dell.com that you can run to remove any xp drivers and then run the vista installation file. that should take care of these error messages from the operating system.
you can copy and paste the following links to download and run the files :
Patch file to remove xp drivers:
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=224499
Driver for vista
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=203951
Feb 17, 2009 | Dell A960 All-In-One InkJet Printer
When plugging things into tower everythin freezes
Check inside the port to see if the contacts are not bent, try another network cable.
Also, start the computer in Safe Mode with Networking then plug in the cable.
To start in Safe Mode with Networking
restart computer
tap F8 just after BIOS splash screen (before windows)
select 'Safe Mode with Networking" from the advanced startup menu using the arrow keys.
Things may look weird when windows starts, because it is starting with minimal drivers.
If it seems to OK in safe mode with networking, there is probably some startup item that causes the issue. See this article at capitaltechmd.com on how to troubleshoot startup items.
Good Luck, hope this helps
Feb 04, 2009 | Dell Computers & Internet
Proview PL913B 19" Flat Panel LCD Monitor Logo
95 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
