Question about Lexmark Optra S 1625 Laser Printer
Poor print i have a lexmark optra s1625 that leaves a streak of toner on both ends. mostly the left side. the fuser and drum were changed but it still exibits the same dirty print. if the job is stopped by opening the door there is toner on the ends of the transfer roller. any
    Scholar:
  • 54 Answers
Try running a calibration on the printer.
Also try running clean heads function on the printer if it can do so.
Most printers have those options under maintenance.
-Chad
Posted on Dec 12, 2007
Have a Lexmark C510N laser colour printer. The print quality has become streaky and poor. Have only used genuine toners
You probably need to replace the photodeveloper cartridge.
Also check the fuser, they sometimes get sticky and pull the toner off the paper. Look for anything stuck to the fuser's rollers. Also check the print outs by rubbing them to see if the toner is stuck to the page well, if not, it's the fuser.
Both need to be changed every once in awhile,with heavy use they need to be changed more often.
Nov 27, 2012 | Lexmark C510n Laser Printer
I'm getting black streaks down the left side of the paper. There is plenty of toner left in the cartridge. We've vacuumed out the printer, cleaned the drum - nothing helps.
black streaks the toner cartridge is leaking from the left side which is easy to check pull the tone and look at the gears on the left side to see if toner is present. if these gears have toner on them the cartridge is leaking replace it. check the fuser for wear marks on the hot roller which is the top roller when these get worn through the outer coating they will create black streaks
Dec 05, 2009 | Lexmark E238 Laser Printer
Lexmark laser printer leaving a white streak 2-3
take a q-tip and clean the scanner window. this is located in a 3/16' opening on the roof of the printer cavity it will be about 8inchs long. pull the toner cartridge and feel with your fingers on the roof of the cavity this will be located above the transfer roller slightly towards the front of the printer. white lines like this mean the laser is being blocked usually by a bit of toner or other dirt of some kind
Nov 30, 2009 | Lexmark E232 Laser Printer
Lexmark t520 suddenly prints poor quality, i.e. the previous page prints softly onto the next page and the right side of the page (2" from right) is streaked with toner. Please help. TIA, Mike
this sounds like you have a fuser problem look at the fuser and see if it has toner build up on the rollers ghost printing can be caused by the toner cartridge or the fuser. this would indicate that your fuser isnt maintaining enough heat for complete fusing. is you take the rear covers off and run your print job. look to the far left side of the fuser and you will see the heat lamp lit up. this light should cycle on every 1 1/2 pages or so. any longer than that and it wont keep up with the print job
Oct 28, 2009 | Lexmark T520 Laser Printer
I have a Lexmark Optra T614 and when I print mostly black pages such as large dark graphics, I get streaky vertical lines at 3" and 5" from the left side of the portrait oriented page, and a lighter...
You need to either call a repair tech and have the printer serviced for routine maintenance or order a maintenance kit from Lexmark to do the job yourself.
Just curious, what is the page count on the printer? When was the last time the entire print cartridge was replaced?
Don
Oct 19, 2009 | Lexmark Optra T614 Laser Printer
Toner Streaks Printouts - Lexmark Optra SC 1275
Check the fuser for scratches. BE CAREFUL - - - VERY HOT ! ! !
If you need guidance for this, let me know.
Aug 12, 2009 | Office Equipment & Supplies
Printed pages look terrible...
I'm more familiar with HP printers, but it sounds like a fuser is bad. The fuser effects print quality as well. If you've replaced the toner, as you have.
Apr 24, 2009 | Sharp FO 5550 Plain Paper Laser Fax
Printer prints a line across the paper around three inch from the left hand side of the page.
Check your Toner Carts.
Is the line a certain color?
Black perhaps?
Lift the door of the toner cart.
If you see a streak on your toner drum, you will see a streak on your paperwork.
Look at your fuser as well.
Is there a problem with the big orange roller?
BEWARE! Don't touch the fuser roller its EXTREMELY HOT!
Let the printer cool down before inspecting.
Apr 24, 2008 | HP LaserJet 5500dtn Color Printer
Two dots on right side of page
if you replaced the cartridge and the streaks are still there then it's the fuser. you can try to clean the "fuser" roller with a little alcohol and your finger nail (after it's cooled down) to scratch off the toner, if it's an actual scratch on the roller you need to replace the fuser as it will pickup toner again and leave marks.
hope this helps
thanks for rating
Jan 09, 2008 | Lexmark Optra SC 1275 Laser Printer
Two black dots on right side of page
Are the marks in the same exact spot on each page? If not and you have changed the toner cartridge then most likely the fuser assembly needs to be replaced. This is a job I recommend for a professional.
Good Luck
John
Lexmark Optra S 1625 Laser Printer Logo
245 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
