Question about KitchenAid KHMS147 Microwave Oven
KHMS155L Need to replace outer door cover and handle. How do I remove them? I have the replacement parts.
  • 26 Answers
Take the entire door out using screw driver and replace parts one by one.
Posted on Dec 12, 2007
I need. To replace the handle for a kitchen aid microwave. I have the new part but it came with no instructions. I am afraid to do to break the microwave model# KHMS155L 0. Any one who knows where to...
Here's an exploded view of the door:
Item 10, the door panel, just snaps over the rest of the assembly. If you work slowly and carefully with a flat object like a putty knife, you can separate the door panel and take it off without damage. This will expose the screws (number 8) which hold the handle on. Then you just need to snap the door panel back into replace after you put on the new handle.
Good luck and thanks for using Fixya!
May 15, 2011 | KitchenAid Microwave Ovens
How to replace a Broken Door Handle
This website has the parts you may need.
http://www.partselect.com/Entry.aspx?Source=GAWS&Brand=KitchenAid&Term=kitchenaid+parts&gclid=CNu8ruSS26UCFeFw5QodGAuVyA.
Some screw in from the front, while some screw in from the back. You may have to call an appliance repair technician to put in the door.
Dec 07, 2010 | KitchenAid KHMS155L Microwave Oven
How do I get the door handle off for replacement?
if the handle is available separately; it's more than likely screwed in from the inside of door. carefully remove the inner door trim with a small putty knife; working it around. screws for handle should be visible.
Aug 31, 2010 | KitchenAid KHMS155L Microwave Oven
Hi, I'm taking you up on your offer of help replacing a microwave door handle. I have a kitchenaid khms155l and even though I remove the three screws on the side of the door, the plastic panel seems...
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 21, 2010 | Microwave Ovens
Need to change handle
The door handle can easily be replaced on most microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and/or replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. However, price and configuration of your oven also depends upon the MODEL NUMBER.
If you have any questions, please post back with your complete model number (if different than the one listed) and let me know. I hope this helps you.
Jan 29, 2010 | KitchenAid KHMS155L Microwave Oven
Slight crack in oven door just below the handle. Should door be replaced?
It may be that the handle is getting loose, and cracked the outer door panel.
If so, the outer door panel and handle would need to be replaced.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Oct 07, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a JVM 1650BB008 GE microwave oven. I am trying to replace the outer door frame and handle, which are broken. I have removed the door and have pried off the choke cover. Now I need to remove the old...
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
You have to remove the door handle screw(s) and the door handle, then look for subtle clips that may be holding the outer door screen in place.
Some models have two screws holding the door handle, but some have only one. In that case, remove the screw, then you either lift or rotate the handle to free it.
If you still need help, please write me at prototech@usa.net for the service manual link (no charge, no obligation).
Sep 27, 2009 | GE JVM1190SY/WY/AY/BY Microwave Oven
Door handle replacement
You remove door latch (nr 3 on diagram) first, then you unscrew the screw nr .8 and remove handle (nr.7).
Below the diagram:
Do not forget to rate the solution.
Thanks.
Feb 12, 2009 | KitchenAid KHMS155L Microwave Oven
Handle Replacement on a HKMS155L Microwave
I think you have solved your problem already.
I have seen your requesty only now and I am sending the diagram to replace handle.
Below the diagram:
You can find all parts and diagram for your appliance here.
Jun 09, 2008 | KitchenAid KHMS155L Microwave Oven
Broken door handle
bogus...use a Torx driver to remove the door screws...careful of the glass. Replace the handle and reassemble. You may want to take digital pictures along the way. Parts available from ge or other online parts guys.
Dec 18, 2007 | GE Advantium SCA1000H Convection /...
KitchenAid KHMS147 Microwave Oven Logo
137 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
