Ignition switches are a known issue with this era mercedes. Not too difficult to change the ignition switch. Google is good source for pics, videos and instructions on this. Be aware that the switch is about $400 from the dealer. You could get one without matching key for alot cheaper if you dont care about that. Also, you can get one without the key lock for much cheaper if you are able to remove the key lock from your existing switch.
SOURCE: wheres the volatge regulater
its located on the alternator and is very easy to replace. you get at it from under the car. 2 screws hold it in place. if your car is not charging this is probably the problem.
SOURCE: 1995 Mercedes Benz C220 will not start, and key
hello,steering lock mechanism and your key need to replaced,if you want try to remove your under dash,steering lock mechanism have a small pin(around 5 mm) which pit to steering housing,drill out the lock,then try to turn steering wheel,ty
SOURCE: does (1997) c250 td mercedes benz have a timing
mercedes uses chain
Testimonial: "Top answer - simple and quick. Thanks."
SOURCE: 1984 Mercedes-Benz 300 SD
If you are certain that the fuse is okay, next replace the Multi-Purpose Relay/Combination Relay. This relay controls all three of those devices and is most likely your culprit. I would try the junkyard first and grab two just to be on the safeside. You'll find it under the fuse box cover on the driver's side engine bay.
SOURCE: The key won't turn in
new ignition lock needed thats all ,only available from a merc garage to order
Reset your Mercedes-Benz key by placing the key in the ignition of your vehicle while the vehicle is turned off. Do not turn on the vehicle. Press a finger on the "lock" button of your key fob while the key is in the Mercedes' ignition.
Pull the key out of the ignition while continuing to hold the "lock" button down. Continue to hold the "lock" button for the duration of the key resetting process
Use another finger to push down on the "unlock" button five consecutive times. Keep holding down the "lock" button.
Release the "lock" button. This is the end of the resetting process for your Mercedes-Benz. Use your key fob to ensure it is properly working
