Question about Kenmore 74832 Gas Dryer
How do i change the ignitor in my dryer
Kenmore front load dryer model #11074832400
  • 89 Answers
First, why do you think ignitor. In all the dryers I fix only 1 dryer in 999 need the ignitor replaced.... Hit me back before midnight for more help........
Posted on Dec 15, 2007
How to check the door switch on my kenmore dryer 11074832400
access switch and tape the leads together,,, if dryer works bad switch. if not something else is problem,,( of course unplug dryer before unplugging switch)
Aug 28, 2014 | Kenmore Dryers
Why won't my kenmore 80 series dryer start
check all your power connections, if power is all there then check the motor it might need to be replaced
Aug 27, 2014 | Kenmore Dryers
Kenmore gas dryer #41793142300 electronic start doesnt heat up
if you first have heat and then like 10 to 20 minutes later no heat you could have bad gas coils,on most gas dryers there's a plastic cap you can pop off on the front panel so you can look in and see the ignitor,if at first the ignitor glows orange and the flame lights then after a few minutes the ignitor glows orange and the flame doesn't light you have bad gas coils,they are located on the top of the gas valve,easy to change.part number 5303931775 go here and look at part 71
Mar 25, 2013 | Dryers
How do i change the ignitor on kenmore model no. 110.87356100
remove the lower panel below the dryer door then the ignitor will be on the lower right side by the burner funnel,on some units the front cover is a full front and you will need to open the top and remove two screws at the top corners inside the front panel to remove the door
Nov 15, 2012 | Maytag Dryers
How to replace ignitor in kenmore dryer model 11073912100
very simple
disconnect the power
remove the pannel usualy you can get to it from the front panel but it may have to be the rear pannel
locate the ignitor
disconnect wires from ignitor
remove it usually only 1 or 2 scews holding it in
intsall is the reverse
if you need more help contact me
Nov 17, 2010 | Kenmore Dryers
Either the thermal fuse or the ignitor on my kenmore elite gas dr
Remove the lower front cover - it has spring-loaded keepers that can be gently pryed and the panel should either hinge down or pop off. The thermal fuse and ignitor are behind this panel.
Mar 28, 2009 | Kenmore Elite Oasis 7808 Gas Dryer
How do you change the ignitor on a kenmore dryer model #417.90042990?
Drop the front bottom panel and you can then access the ignitor.
092f93a.jpgas you can see it has a quick connection. Do not touch the corborundum or the new part will fail imediately.
Read more on how this dryer works HERE
Mar 01, 2009 | Kenmore 63942 Dryer
I Have a Kenmore Gas Dryer model #110.74722400 no heat
you get to it through the front does your ignitor glow if not check the thermal fuse
Dec 26, 2008 | Kenmore 63942 Dryer
No heat in kenmore 97273100 72731 front load gas cloths dryer
check the ignitor under the door panel on the left side of the burner if it gets red when you turn the dryer on.if yes than see if gas shoots out and yes than how long it stays on if in few minutes it turns off than need thermal fuse checked so let me know up to this point if it works or not .
Nov 02, 2008 | Kenmore 73952 Gas Dryer
Kenmore gas dryer wont heat, model #11074832400
check the igniter,thermal fuse,operating themastat there is a small plastic piece on the lower left hand corner pop that out and when you turn your dryer on it should be glowing red if not its the igniter
Mar 01, 2008 | Kenmore 63942 Dryer
Kenmore 74832 Gas Dryer Logo
118 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
