Back to:
Tags:
Monitors
Generic problem for all Monitors
On/off switch broke (by 3 users)
posted by cjtarr on Dec 12, 2007
the on/off switch has broken off can it be repaired
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by daha16, posted on Sep 06, 2008
my Benq monitor is blinking bower but not to display picture and systems unit is ok when ever I connect to other Monitor
pls-help me
Comment by Guest, posted on May 03, 2008
monitor has power, but the screen does not lite up.
Best Solution
posted on Dec 12, 2007
Helpful (85)
banar
Rank:Master Master
Rating: 78%, 16 votes
yes if you can find the identical switch from the electronic sparepart shop and repair yourself.
Rating Locked! (?) cjtarr has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on on/off switch broke:
I don't want to Accept this solution
Can you Help with these Monitors problems?
Belinea 10 17 15 (Grey) 17" LCD Monitor
all the wires are connected but when i go to control panel...
IBM ThinkVision L170 (Black) 17" LCD...
it flashes when i turn it on.one flash and no more.i know...
Dell P992 19 in.CRT Conventional Monitor
monitor dell p\992 1-no power and no bright...
Westinghouse LCM-19v1 Monitor
monitor was working fine until monitor was cut off from...
BenQ FP731 (Silver) 17" LCD Monitor
monitor has vga and dvi plugins,on screen display is short...
Loading problems.
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
