Question about Sony PlayStation 2 (PS2) Console
Need help!!!!!!!!! how do i set up my madden 08 game online for playstation 2 and i have a ethernet cord,network adaptor,working internet and i dont know how to set it up so i can play online
  • robbyxxx Dec 12, 2007
    wr can i put in the isp
    Scholar:
  • 54 Answers
There should be a setup disk that came with the network adapter.
Put that in, and it's a simple walk-through.
If you don't have it, then Madden 08 has an automatic connection sequence, just go online with it, and it should do it all for you.
If you have a cable connection (Cable Broadband), then its going to DHCP connection (or automatic) If it's DSL, then you may have a static IP address, and you may want to contact your ISP for further help. You would need to manually assign an IP address to your PS2.
If you have it set up correctly, and its a cable modem you've got, then you may want to reboot everything.
Unplug power to the modem and router and also make sure the PS2 is off.
Plug modem back in, then router, and turn PS2 and try connecting agian.
-Chad
Posted on Dec 12, 2007
How do i hook up my playstation 3 to the internet using a cable modem
  • Unplug the power cord and the USB cable or Ethernet cable coming from the modem.
  • Wait two minutes and then plug the power cord back in which will reset the modem.
  • Take the straight through Ethernet cable and run it from the LAN port on the back of the PLAYSTATION®3 into the ethernet port on the modem (you may need to unplug the Ethernet cable already in there. Also, make sure a USB cord is not connected to the modem as this will cause your PLAYSTATION®3 not go online).
Turn on the PLAYSTATION®3 to log into the PLAYSTATION®Network (you may need to log in manually if your settings are not set to automatically login). When you are done with your online activity with the PLAYSTATION®3, turn off the PLAYSTATION®3 (refer to the Quick Reference manual) and then follow these directions:
  • Remove the Ethernet cord going from the ethernet port on the modem to the LAN port on the PLAYSTATION®3 out.
  • Reset your modem as you did before my unplugging the power cord for two minutes and then replug the Ethernet cable/USB cord coming from the PC to gain internet access onto your PC. (Please note that this step can be skipped if you do not want to have internet access on your PC at this particular time or do not have a PC at all.)
  • When you would like to log back onto the PLAYSTATION®Network please follow the steps beginning at the top.
The modem setup should appear like this:
From there, please follow these instructions (from SCEA):
  1. Select "Network Settings" under "Settings" in the home menu, and then press the "X" button.
  2. Select "Internet Connection Settings", and then press the "X" button. When a message stating that the Internet connection will be terminated is displayed, select "Yes", and then press the "X" button.
  3. Select "Wired Connection", and then press the "X" button.
  4. Select "Easy" or "Custom" and adjust settings as necessary. Follow the on-screen instructions to adjust the required settings.
Note: You should always choose Easy before going onto to adjusting the Custom settings. In most cases, the Easy settings will work and are set automatically so you won't have to search for information that could have been gathered automatically.
Feb 25, 2011 | Sony Video Game Consoles & Games
How Can I Get My Ps2 To Go Online What Parts Are Needed
You need the Network Adapter and you have to sign up and pay money/ month
http://au.ps2.ign.com/articles/366/366021p1.html
f you are hooking it up to a DSL cable/modem,
1. Remove the sticker covering the network connector on the Network Adaptor and
plug your Ethernet cable in the connector labeled NETWORK.
2. Plug the AC power cord for the PlayStation2 system into an electrical outlet.
3. Turn on the PlayStation2 system and start the Network Adaptor Start-up Disc.
If you are hooking it up to a router:
1. Remove the sticker covering the network connector of the Network Adaptor.
2. Connect an Ethernet network cable from the NETWORK connector of the Network Adaptor to an available LAN port of the router.
3. Connect the WAN port of the router to the DSL or cable modem.
4. Connect a personal computer (not pictured) to an available LAN port of the
router. Use a web browser on the PC to set up the router to reach the
Internet.
5. Follow the specific instructions that come with the router. There is no additional installation for switches.
If you are hooking it up to a LAN:
2. Connect an Ethernet network cable from the NETWORK connector of the Network Adaptor to a wireless Ethernet bridge.
3. Connect the WAN port of the wireless router to the DSL or cable modem.
4. Connect a personal computer to the router. Use a web browser on
the PC to set up the router to reach the Internet.
For pictures, see the thread here:
http://www.funadvice.com/r/3js7klmkua
May 20, 2010 | Sony PlayStation 2 Slimline Console
Playstation 2 wont load madden 08
this has happened to me before and this was due to a disk format malfunction, you will need to take it back and get another one.
Nov 26, 2008 | Sony PlayStation 2 (PS2) Console
Madden 08
IF THOSE TWO BUTTONS DONT WORK ON OTHER GAMES EITHER THAN JUST BUY A NEW CONTROLLER.
Jun 01, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 playing online madden with the network adaptor
  1. Turn off your PS2 console.
  2. Get your CAT5 Cable (link varies based on where your router or modem is).
  3. Put one end of the cable into the port of the Network adapter (or slim PS2 and PSX) port labeled "Network".
  4. Connect the other end in a free port in your router (or on the port on your broadband modem).
  5. Turn on PS2.
  6. Turn on modem (or router).
  7. Put in online game.
  8. Go to the online section in the game.
  9. Create a network Configuration
  10. Load it
  11. Create an ID.
Jan 05, 2008 | Sony PlayStation 2 (PS2) Console
Need help!!!!!!!!!!!
A previously released Madden NFL 08 update for the PLAYSTATION 3 was causing an error code (80010009) to appear and prevent online game play.
There has been a fix published by Electronic Arts (EA) on this problem.
This has now been resolved, but if you already downloaded the update, you will need to remove it before the game will work.
Please follow the steps provided by Electronic Arts below.
If you have encountered an '80010009' error message after downloading the most recent Madden NFL 08 update, please perform the following steps listed below:
  1. Press the PS button on the controller and select QUIT.
  2. In the main screen of the XMBTM user interface, select Game.
  3. Highlight the Game Data Utility folder and press the X button.
  4. Highlight the Madden NFL 08 file and press the Triangle button.
  5. Delete the file.
  6. Restart the game.
This will allow you to launch and play Madden NFL 08.
Dec 13, 2007 | Sony PlayStation 2 (PS2) Console
PS2 online gaming with Madden 08
Erase all madden data from your memory card including network configuration and download the latest rosters and try again. The error happens when the rosters (between the two people playing) dont match and you try to connect online. Download the rosters and dont mess with them! This worked for me and i was getting a buzzing sound every time i tried to connect to a game online, i even went out and rented a another copy of the game, so definately a memory card problem.
Nov 15, 2007 | Sony PlayStation 2 (PS2) Console
Connecting online Madden 08 ps2
I experienced the same problem. I have the ps2 slim. The problem was so bad that i had the slim for about 3 years and still could not play any ea games online. About 2 months ago i finally got it to work though, allowing me to play madden ncaa and many other sports games from ea. I also have dsl broadband just like you. I do not have a router though. I just hooked my ethernet cord straight into the back on the ps2, my computer is really close by. I would reccomend a router though.
Enough of this bs though. Now solving the problem. There was actually a firewall keeping me from connecting to ea servers. Which in turn meant no ea account and no ea play online. Go onto your computer and turn your FIREWALLS OFF. This still may not work though. I done this and an unknown firewall was still blocking it. THERE WAS A FIREWALL IN MY MODEM.
CALL UP YOUR INTERNET SERVICE PEOPLE AND TELL THEM TO TAKE THE ******* THING OFF SO U CAN ******* PLAY. I ALSO FOUND THAT LIMEWIRE WOULD NOW WORK ON MY COMPUTER AS WELL.
By doing this you will open peer to peer connections with other programs and players online.
Nov 10, 2007 | Sony PlayStation 2 Slimline Console
Madden 08
Hey You Must Go to Your Controller Settings in Madden 08 and Activate Vibration. If That Doesnt Work Download and Install This application - LGS501.exe ( Search In Google) And Select Vibration Before Download. In that Application You can control everything. NOTE: IF THIS DOESNT WORK MADDEN 08 IS NOT VIBRATION SUPPORTED.
if U Need Any Help , Questions , Drivers , softwares, Games,Patches, Cracks , Serials, Win Help , Vista or XP --- JUST EMAIL ME WITH THE THING U WANT TO - arjunmanoj23@hotmail.com
Oct 28, 2007 | Logitech Rumblepad 2 Vibration Feedback...
Sony PlayStation 2 (PS2) Console Logo
79 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
