Question about Maytag Atlantis MDG7400AW Gas Dryer
Maytag atlantis dryer
When you pull to start, you see the dampness light come on, hear the motor hum, motor doesn't turn, and the light goes out once the button is release. Does anyone know the cure or cause? Thanks
  • 89 Answers
Motor is bad= not worth fixing! Sorry, Buy a kenmore or whirlpool- they are good dryers!!!
Posted on Dec 15, 2007
What will prevent my dryer from starting?The controls are working but it seems to have something keeping the tub from taking off!
Pull on the belt...make sure it isn't stretched or broken.RemRemove the belt from the motor pulley and see if the motor will spin. Make sure you have the correct voltage. A 220v dryer requires 2 legs with 110v on each. If MOTOROLA Does Not Spin Check Voltage At motor. There should be a schematic inside the dryer (usually taped near the control panel) this will tell you if the motor is 110 or 220 v. If the motor has sufficient power but won't turn it is probably bad. ( note some 220v motors may have a start capacitor on it...this gives a boost to the electricity to get the motor started...if it goes bad the motor will not start..)
Oct 12, 2016 | Maytag Atlantis MDE6400AY Electric Dryer
My Maytag Atlantis MDE7400AYW does not start when I pull the knob and I cleaned the sensor and connection and pulled the panel and checked the connection on the board the damp indicator light comes on but...
There are a few different scenarios which would cause the dryer not to start. First, make sure you door switch is functional. Second, the white thermal fuse, located on the exhaust housing may be open. Worst case scenario would be a defective timer or motor. Either of these may not be cost-effective to replace.
Mar 06, 2014 | Maytag Atlantis MDG7400AW Gas Dryer
I have a Maytag Performa dryer about 5 yrs old. It wont start anymore but makes a humming noise instead.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 15, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis dryer drum not spinning. Light works, there is a hum from the timer, belts are good, drum spins freely, thermal fuse is good. Need to know what would be wrong with the dryer
heatman101
Oct 27, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Electric dryer was running fine.had towels in there an opened door to check how wet an noticed it was really hot inside an then closed it an went to pull knob outward to start the dryer again an it...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Aug 28, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
I have a maytag atlantis dryer and it will not start. I checked the front safety switch and it is working. Light that says damp comes on but does not start
The 304473 thermal fuse has blown. It is located down on the left side of your heater. For a quick check of this you can with the dryer unplugged jump the two wires together making sure they don't touch any metal and plug back in and try to start. 5.00 part.
Jan 28, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis dryer mde7400ayw won't run
I believe this last one has it right. the timer may be bad or worse, the board could be bad.
Jan 15, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer stopped running, will not restart
When you try to restart do you hear a motor running? If you do hear that sound and the dryer does not turn your belt could be the problem. (broken)
May 26, 2008 | Maytag Atlantis MDG8400AW Gas Dryer
Maytag atlantis doesnt run
change the copasitator this tells the machine to engage the motor
Oct 24, 2007 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MDG7400AW Gas Dryer Logo
66 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
