Question about LG Studioworks 700S 17" CRT Monitor
Laptop screen problems
My screen just started going all yellow in light part of background and then the whole screen is messed up, can't tell what most of the screen is---can't even see a start button to shut down, had to hard shut down
  • 749 Answers
Resolder component on the main board especially on the CRT board. clean also using a soft brush!
send it for maintenance to a service center if you have no experience working with electronics
Posted on Dec 12, 2007
How can I change the font colour back from yellow to a darker colour?
Go to the control panel and pick personalisation, then scroll down the screen and change the settings from high contrast which is what your current screen is set to.
You can change the background and colour of the text from here,
Feb 08, 2015 | Computers & Internet
How do i change my pictures to fit my laptop screen
Please give more details on what you are trying to do.
If you want to take a picture and make it the total size of your screen as the background of your screen, then just right click on the picture and select Set as Desktop Background. If the size is not what you want then go into the display properties and select the Desktop tab and change the Position to be Stretch. Stretch will fill the whole screen with the picture. Tile will fill the whole screen with multiple little pictures. Center will put the picture in the middle of the screen.
To get to the display properties click Start/Control Panel and look for Display or Appearance and Personalization.
You can also get the display properties by Right Click on an open area of the desktop and select Properties.
Apr 28, 2012 | Computers & Internet
Hp 2400 scan scanning with yellow background
Replace lamp would be my only recommend on this as these are prone to be the issue as a whole with a yellow background.
Thanks and please do leave valueable feeback.
Dec 11, 2009 | HP ScanJet 2400 Flatbed Scanner
KONICA MINOLTA magicolor 5430DL don't recognize paper
The machine keeps track of what paper was reqested last, and asks you to change paper if the new job is different. I get the "put media" message and have to open and close the drawer if my next print job requests a different paper. So I suggest you gently open and slam the drawer a couple of times, or see if you can find the sensor switch that monitors whether the drawer is open. Also check if your paper guides in the drawer are clicked in place.
Sep 03, 2009 | Konica Minolta magicolor 5430 DL Laser...
Faint image in the background.
Hi Nate,
The same thing has happened to me before.
Well, once you drop your laptop a lot of things could go wrong. From a broken driver to a cracked screen. I believe you broke your bulb. And the cells of your laptop are kinda messed up we can say. Yes, this is fixable but will take time. I hope everything goes better!!
Good Luck
**dont forget to rate**
Jul 10, 2009 | HP Pavilion xh555 (F3929H) PC Notebook
Macbook was manually shut down during an update
while starting, hit cmd v. this will put it into verbose mode and show the background processes and where it stops, there will be your problem. Also try inserting an OS disk and hitting c during startup chime and use the disk utility to fix the permissions.
Jun 04, 2009 | Apple MacBook Mac Notebook
I dropped my laptop and the screen is messed up
You can purchase just the display piece for replacement. It is tedious to take apart the whole laptop because the display is plugged into the motherboard at the bottom, but usually cheaper than replacing the whole computer. Instructions for replacing the display piece can be found on the manufactures website in PDF form. Displays can be also be purchased from the manufacturer but it is much cheaper to buy them from a highly rated seller on Ebay.
Apr 16, 2009 | HP Pavilion dv2000t Notebook
Motorola i730, white screen, texting messed up
Its the flexible wire or the ribbon wire. It should be replaced. I suggest to go to service center. thank you....
Nov 14, 2008 | Motorola Mobility i730 Cellular Phone
Display Issue
Toshiba makes a great laptop but the display video or lcd seem to go bad very quickly I have replaced the lcd in many to solve this problem but be aware a few also had bad video cards (unlikley in your case as the external video is fine) it would seem as the lcd panel has gone bad on yours. the average replacment is around $100.00 to $300.00 depending on where you purchase from.
Oct 24, 2008 | Toshiba Satellite M115-S1061 Notebook
Akai PT4298HD displays yellow tint in lower left
OK YOU CANT 'BURN' A REAR PROJECTION BUT THE CONVERGANCE CAN BE GOING OUT BUT I WOULD GUESS THE SIGNAL TELLING THE PROCESSOR - OR THE PROCESSOR ITS SELF- IS PROBLY GOING OUT WHICH MEANS A BOARD NEEDS REPLACING I DONT KNOW WHICH ONE I WOULD GET A PRO TO CHECK IT AND TELL YOU WHICH ONE IT IS THEN ORDER IT ONLINE AND REPLACE IT YOURSELF
Nov 15, 2007 | Akai PT4298HD Rear Projection Television
LG Studioworks 700S 17" CRT Monitor Logo
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
