Question about RCA P52937 52" Rear Projection Television
RCA 52937SG Blurry picture
I have an RCA 52937SG rear projection and the tv is blurry. I have been told that there may be a simple adjustment but can not figure it out.
On my rca there is a setting in menu called converage or something along that line looks like this #with blue red n white they all need to line up on the number sign this might help + there are other solutions
Posted on Dec 12, 2007
RCA 52" projection tv convergence problems,can i fix it?i try auto convergence? the model is P52920BL and is a 1998 i try the green centering blue & red convergence in the setup of the tv,and it goes back...
My RCA 52 rear projection TV has the letters getting blurry on top and bottom, Picture is OK but visually losing my eyesight staring at blurry numbers and letters.
Is this a bulb or simple fix ??
Mar 28, 2009 | RCA P52920BL 52" Rear Projection...
Rca projection tv is blurry
Hi, you need a tv tech, G2 focus block and pincushion circuit are what your describing, these are both related to the high voltage circuit but are 2 different circuits, definitely not a layperson repair, do yourself a favor and call a tech on this one, good luck, video-tek
Feb 03, 2009 | RCA P52926 52" Rear Projection Television
Find a large rifle and put it out of its misery. Bowing is either from a problem in the pincushion correction circuit or the convergence circuit. Blurry picture or poor color rendition is most likely bad CRTs ( picture tubes)
michtech
Feb 03, 2009 | RCA D52W19 52" Rear Projection Television
Sony rear projestion TV has blurry picture.
sounds as if your convergence needs to be set. either through the menu on the tv or remote you need to get to the convergence set screen and you need to line up the crosshairs. this usually happens when the tv is moved or bumped.
Dec 31, 2008 | Televison & Video
The picture is blurry. does anyone have a solution to this or has anyone had a similar problem.
I have a blurry screen and the top of it the picture is curved a bit. I was told to adjust the focus knob but I don't know where that is in the back of the TV. I took off the back and couldn't find it. I also tried to adjust the manual convergence and the red would not adjust only the blue would align. Any suggestions.
Nov 05, 2008 | Samsung HCM422W 42" Rear Projection...
RCA r56wh78 rear projection screen is blurry
if you have little knowledge about electronics, you have to open the back of your tv and adjust the focus adjustment located at the back of the flyback transformer the large black colored like hard plastic... and if it is still not working replace the CRT socket....
Aug 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52" HDTV DLP tv
suspect the optical engine as the culprit. they can gather dust contamination internally and cause a "faded or washed out pic"
Apr 09, 2008 | RCA Scenium D40W20 40" Rear Projection...
Blurry picture
you can try to clean the mirror and lenses. or try to adjust the focus for each CRT(picture tube). also could be a convergence alignment issue. check the main menu for convergence alignment feature.
Apr 07, 2008 | RCA P46924 46" Rear Projection Television
Rca d61w20 dominate red & blue screen also very blurry picture
Red and blue present, but no green = bad green CRT is
best guess.Remove lower front panel = adjust screen and focus
controls for best pix..................T.
Oct 30, 2007 | RCA P52926 52" Rear Projection Television
Blurry picture and arched at bottom
We have a Proscan 50" Projection TV. A T.V. repairman told us it was the HV (Horizontal Vertical) Splitter causing this problem and tried to find the part for us. The part for our TV was too hard to find though and we ended up not having ours fixed. Our T.V. is 8 years old though, and Proscan is discontinued. Maybe you'll have better luck finding an H.V. Splitter for your TV. Of course, you'd need a professional to install it for you. Good luck.
Sep 20, 2007 | RCA P60921 60" Rear Projection Television
RCA P52937 52" Rear Projection Television Logo
148 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
