Question about Frigidaire 24 in. FDB635RF Built-in Dishwasher
Dishwasher continuously fills....even when switched off.
Hi, this is an updated posting following from a previous thread. I have one of these dishwashers and it seems to contiuously fill, the water never stops flowing into the main chamber of the washer. Everything works fine except this, it flooded our kitchen because my wife had no idea the water was still entering the chamber once the dry cycle had started.
Is this something that only a repair guy can fix?
  • 3 more comments
  • Lee Godwin
    Lee Godwin Dec 12, 2007
    I'll give it a try and let you know, thanks!
  • Lee Godwin
    Lee Godwin Dec 13, 2007
    I tried putting the washer into the 'fill' part of the cycle, when I opened the door and saw that the water was still filling the chamber I pulled the float up and the water was still filling the chamber.
    Any other suggestions? The previous answer was a great 'good to know' tip but the problem is still there.
  • Lee Godwin
    Lee Godwin Dec 14, 2007
    No click, I can hear the very faint click of the switch but the louder click isn't happening. I'm guessing that the switch has died? If this is the case is this something I could change or do I need a pro to come and install, I am technically minded but don't want to get into something I know nothing about if it's comlicated.
  • Lee Godwin
    Lee Godwin Dec 15, 2007
    Okay I tried that so I you must be right about that solenoid, is that the small switch that the float controls or the part that the water pipe is actually connected to (it tricky to see anything)? My next question is where on earth do I buy dishwasher parts from? It's going to be very trick because there is barely any room to get my hands under there to do anything.
  • d90guy Mar 06, 2008
    I have the same issue - I have been tracing the issue on this and I narrowed it to either the high water cut-off switch or the water inlet valve solenoid. I hear the click when I raise the water inlet so I am ssuming from this post that that menas it is OK. I will try the solenoid next but I will have to find the part number as that is not listed in the Factory Parts Catalog. I will try to get if from the valve once I remove but if anyone has the number, let me know. Funny that I had the same water solenoid issue on my clothes washer just last month.
    Sergeant:
  • 239 Answers
Sounds like there maybe something stuck underneath the float, The float is the round coffee cup like thing in the bottom of the dishwasher That happend to me and something was just stuck not letting the float rise. I sure hope this help you out I just seen you thread and thought I would try to help you out Hope it does
Posted on Dec 12, 2007
  • bear001 Dec 13, 2007
    Did you hear the click when you lifted the swicth if you did hear a click it means it is working. But if you did not hear it means that the swicth is bad and should be replaced. Another thing I was wondering you can open your door and it still works, That should not happen either it should shut down as soon as you open the door, Let me know how and if you hear that and we can go from there. It may also me the door swicth let me know sorry that did not help you. I am trying for you and can help some other way.,
  • bear001 Dec 14, 2007
    Hello there is a main inlet that comes in where the water connects In the underside or the cabinet, You wll see wires going to that switch Make sure the power is off to the washer and double check it so you don't get a shock.. Make sure all connections where the wires come into the water inlet are all tight and plugged in, The parts are cheap and easy to install if you need to purchase them. It should be in there because everything else is working fine, witch would lead me to believe that the inlet selenoid jMay have failed. Anyone with a little common sense like it seems you have can replace it, Its pretty easy to do. I you just look at the screws and clamps that should be pretty simple if thats your problem. If you have any more help let me know. Happy Holidays bear001
Dishwasher won't fill with water
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Kenmore Dishwashers
Dishwasher comes on but it won't fill.
Hi
Daniel
Aug 21, 2011 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
Dishwasher not filling up with water
Hi
Daniel
Aug 15, 2011 | Viking 24 in. Professional Series VUD040...
Water is not filling up.
Hi
Daniel
Aug 01, 2011 | Whirlpool Dishwashers
Unit won't fill with water
Hi
Daniel
Aug 01, 2011 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher will not fill have changed the inlet valve but still not filling.
Hi
Daniel
Jul 20, 2011 | Bosch Dishwashers
Dishwasher is not working will not fill with water
Hi
Daniel
Jul 20, 2011 | Neff 24 in. S5543X2 Built-in Dishwasher
Bosch dishwasher does not fill with water
Hi
Daniel
Jul 19, 2011 | Bosch Dishwashers
Dishwasher wont let water come in
Hi
Daniel
Jun 19, 2011 | Dishwashers
Will not fill and will not run even when filled by hand.Is it the circuit board?All fuses and switches are good.
Hi
When the Dishwasher is not filling in, you’ll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don’t get any value on the multimeter hen you'll need to replace the water inlet valve assembly.
Please post back for any further assistance.
Daniel
Aug 26, 2010 | Hobart Dishwashers
Frigidaire 24 in. FDB635RF Built-in Dishwasher Logo
164 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
