Our water supply to the dishwasher got air in it after plumbing work was done. Now the dish washer will not fill. Could it have an air lock, if so how do I purge it.
It is a Kenmore Elite Model, Year Purchased 2006
Thank you!
Not likely an air lock. When plumbing work is done the pipes ge shook up and then particles plug up the screens on these and washer and faucets. I would make sure the over flow float is properly working and then check the screen on the fill valve. Could be a coincidence and the valve failed but that is my last choice in this case. Eric
Was this helpful?
Yes
No
Popular Solutions for Kenmore 24 in. 15689 Built-in
My problem is the same as Ivkds67 on Sept 14, 2009. I've pushed the "lock on" button and...
(More)
My problem is the same as Ivkds67 on Sept 14, 2009. I've pushed the "lock on" button and held it in for 4 seconds or more numerous times but I still can't get the light to turn off so I can start the dishwasher. HELP, please!
I need to unlock the unit. The lock light is on and I can not unlock it. It is a Kenmore Ultra...
(More)
I need to unlock the unit. The lock light is on and I can not unlock it. It is a Kenmore Ultra Wash 4 Dishwasher
Our dishwasher (Kenmore Ultra Wash Quiet Guard 3) stopped mid-cycle... it blew a fuse. I flipped the...
(More)
Our dishwasher (Kenmore Ultra Wash Quiet Guard 3) stopped mid-cycle... it blew a fuse. I flipped the breaker, but now I cannot get it to turn on at all. Is there a combination of buttons I am supposed to hold down to 'reset' it?
Comes on won't fill. if you shut it off. 2 minutes Appears (drain) light on and drain pump will...
(More)
Comes on won't fill. if you shut it off. 2 minutes Appears (drain) light on and drain pump will Drain washer (if you add water to Bottom of Dishwasher)
