Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
How to charge thru a pc
I lost my charger and i need to have my phone charge. can i charge in the PC thru the USB cable ?
    Problem Solver:
  • 7 Answers
Yes but make sure that you switch your phone off 1st.. :)
Posted on Dec 12, 2007
I lost the charger, and i can not find, one do you know where i can find a charger?
"Charging the Player
To charge the player, simply connect it to a powered USB port, or external AC adapter. If you choose to use a third party adapter, please ensure that it is 5V and between 350 and 500mA. "
i'm assuming you need a mini usb or micro usb cable? many phones charge using these...you can buy one at tons of stores. just make sure you get the right one. you can charge from your pc (with usb port) or a wall outlet, provided you purchase the correct charger.
(from )
Oct 16, 2013 | Mach Speed T2800 MP3 Player
I have connected cell thru usb.HOW I WILL COME TO KNOW MY NOKIA5310 IS CHARGING. it doesnt show sign of charging
Many cell phones will not charge through a PC because of cable configuration, voltage issues or lack of software. Cable configuration and voltage is usually the bigger issue.
Ask you cell provider what you can do with your model of phone to charge it from a computer. You may need a special USB cable that matches the proper connectors for you phone.
Regards
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/don_e04c7d10037aa2ce
Apr 06, 2011 | Computers & Internet
EasyShare M853 Digital Camera: I lost my charger cum usb cable of kodak digital c...
go to kodak center os showroom and look for univerasl charger to charge your battery and for the usb you can buy card reader to interface you camera to your pc
May 16, 2010 | Kodak EasyShare M853 Digital Camera
My pc is not reading my lg kf600 phone only charging battery,connected to pc thru usb cable.
You need to install the phone pc suite for the phone to communicate with the pc.
If your phone came with a CD, insert the CD to install the pc suite
Dec 03, 2009 | Cell Phones
How can i charge w230 phone via pc?
If you have the Usb data cable for your phone,Just download and install the Motorola usb drivers from here once it is installed just plug in the phone.
Jun 07, 2009 | Motorola Mobility W230 Phone US with...
L7 unable to charge
All cellphone run on Lithium Ion batteries. These batteries, by nature(physics) have a max charged voltage of 3.4 to 4VDC. So, of your charger, or USB cable, has less than about 5 VDC, then either charger is defective, USB cable(if charging from PC USB port) is not a FULL USB(has data leads only wire, 5V power wire not carried through, PC does not supply 5V power to USB because it is turned off by a PC setting option, or a non-powering USB Hub or other device is in series with PC and Phone.
Are you sure you have identified the GND wire correctly? Measurements must all be made with one lead of your VoltMeter referenced to GND. Another consideration, some Windows Mobile phones will not charge off the USB cable unless the latest version of WM ActiveSync or Mobile Device software is loaded and running on the PC. These WM phones also will not charge from just any AC USB generic charger. Charger has to be for that particular phone, or phone manufacture, to be 'recognized' before provideing charge.
The
Feb 20, 2009 | Motorola Mobility V710
USB cable won't charge
Could be a borker charger port. Thats what I have.
Dec 07, 2008 | Samsung SCH-u740 Cellular Phone
Will not charge or turn on using USB cable.
Two things.
HTC phones will not charge from the USB port unless you have ActiveSync on an XP or Mobile Device Manager on a Vista PC loaded.
Second, if the phone has been stored for a very long time, 1 year if initially charged, 1/2 year if not, the the battery self discharges to a point the USB port PC Sync software doesn't know the phone is connected. You must jump start a charge on the battery by either and HTC AC charger, a generic AC/USB charger will not work, or you can apply a +5 VDC voltage to the power terminal, marked + and - on the battery case, on the two outside terminals I believe. This 5VDC must be current limited for safety. The Red and Black lead inside a standard USB cable will supply current limited +5 volts at 100MA. Chop off a standard USB cable, their cheap and break out expose the Red and Black leads. While connected to the PC USB port, hold the Red lead to the + battery terminal and the Black to the (-), or other outside terminal, of about 30 seconds to a minute.
Now when you plug the phone to the PC with a good USB, the Amber light on the phone to indicate Charging, may not come on for a while, 5 minutes or so, but it will eventually. If it does not, jump the battery again for a longer period of time.
An AC charger for the 3125 are fairly inexpensive. $7 or so, on ebay with shipping. This may be the way to go. Consider getting one with a new battery. They are sold this way sometimes and sometimes for little more that the charger alone.
Oct 19, 2008 | AT&T Cingular 3125 Smartphone
Lost Charger for Toshiba 803T
dont know any., however.,you can still charge ur phone using pc/portable via usb.,u just need to install the phones driver.
Apr 17, 2008 | Toshiba 803T Cellular Phone
H500 WON'T CHARGE
Motorola devices use proprietary USB cables on their chargers. There is a resister on the cable that has no purpose other than to let the phone/headset know it is a "Motorola Authorized" charger, which is a complete load of hogwash. A normal USB cable, hooked to any generic PC, will not charge them (says unauthorized charger on phones) UNLESS the Motorola driver is loaded on the PC, which magically makes the PC a Motorola Authorized USB charger.
Bottom line: use the Motorola USB charger that came with it, and then write a nice love note to Motorola saying how much you like their product's "feature".
Nov 01, 2007 | Motorola Mobility H500 Wireless Headset
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
79 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
