Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA D52W20 gets no power no light nothing.i opened it getting power on caps nothing more
    Genius:
  • 1,030 Answers
On a d52w20 if no light comes on then processor is not getting power... Cap which caps.u could have standby or simple power issues.
Posted on Dec 13, 2007
My JVC model. my JVC TV LT 42 EM 59 will not come on .I get no blinking blue light no power no nothing I get nothing I've tried to reset it in nothing
With no power it will not reset---if total dead unit you would have to first follow the power cord into the set to the line fuse it goes almost directly to---check the fuse first and examine the power supply board for damage or puffed up filter caps.
Dec 20, 2012 | Televison & Video
WONT COME ON, NO RED LIGHT, NOTHING!
Open set if able and follow power cord to the fuse it goes almost directly to.
If open look on power board where cord goes for puffy caps that look like these:
Dec 17, 2012 | Emerson Televison & Video
Mitsubishi wd-52327 no power, lights, nothing. Power board? What/how to test? Is it even worth fixing?
follow the power into the set and to the power supply, a lot of these had puffed up caps on the power board kill the whole set-----
You will not find it a real easy set to get into or open up
Aug 27, 2012 | Mitsubishi WD-52327 52" Rear Projection...
My RCA p60752eb does not come on its makes a crackling sound, but does nothing else
u may have a bad capacitor on power supply 2200uf 25v, just look at the power supply this cap is big u can not miss it
Aug 25, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Gemstar 15" monitor/GM 171-B powers up but nothing on screen
You may have either the DC filter caps problem or the back light inverter board has failed, worst case will be bad lamps assembly. So check for 12vdc on the inverter board, bad caps with leaking/bulging top, bad solder joints.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 29, 2010 | MPC Computers MPC F1760I 17" FLAT PANEL...
TV wont turn on at all. I have read alot of forum posts about the capacitors. I took off back of TV and nothing appears to be out of order with capacitors or anything in power supply. I am not gettting...
I had the same problem. The power supply had a bad capacitor on the 5.3V output. The value of the cap is 2200uF / 10V. The top of the cap was swelled. With the cap changed the TV now turns on again. I hope this helps.
Jan 03, 2010 | Samsung LN32A330 32 in. LCD TV
Acer AL1715 power issues
I have an ACER AL 1706 monitor that would not power up completely. After pushing the power button, only the yellow light would stay on indication a power up fault. After careful inspection of the power boards caps, there was visible swelling of the 47mF and 22mF radial caps on the top part of the caps where the tiny cannisters 4 edges are folded down flat. I replaced these caps( 6 on my board) because there is reaaly no way to actually test them and bought new ones from Radio Shack. Now my Acer monitor came back to life with no other problems. I recommened using replacement caps with same microfarad values, but if the voltage rating is not exact, it is o.k. to get the next higher voltage rated caps available and should work fine.
May 01, 2009 | Acer AL1715 17" LCD Monitor
D52W20 RCA
There is a common problem with these with a bad solder connection on the underside of the sweep board. If you can undo all the leads and turn it over you should see it. When you have the board out check for vented capacitors near the front of the board. If you find one change the other caps around it ( four all together ).
Apr 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Dv4000 no power
See if there are shorted caps.
Mar 10, 2009 | HP Pavilion dv4000 Notebook
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
87 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
