Question about ASUS P4BGL-MX 845GL (AS04P4BGL-MX) Motherboard
Color problem i have a blue shadou on my tv what can be the problem
    Problem Solver:
  • 18 Answers
So you mean you connect the TV into your computer, is it onboard display or you have the graphics card connected.
If you have the graphics card connected to your TV, check the settings of the graphics card installed in your computer. Just manually browse the software provided by the card, surely there is a portion there that tells on how to connect properly TV or even adusting it say for errors such as colors.
Posted on Dec 12, 2007
Sony Trinitron's colors have turned green yellow
Only yellow color denotes the absence of Blue color. Check it. Check its video output card for any loose solder terminals at the blue color output section circuits.
Jan 12, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Hi,,i only see two colors on my tv screen,blue and white,,waht should i do..please help me
there are three primary colors from your TV's chroma circuit, red green and blue..
you'll notice it when you open your back cover of your television set, the wire colored red, green and blue.. you better leave it to the expert technician to prevent severe damage
Sep 15, 2011 | Sharp 27F543 TV
I have a toshiba tp50h50 rear projection tv and their is a blue shadow behind the words and makes the words a little blurry
Sounds like you need to do a color convergence. If you still have the owner's manual, it will give great detail on how to do this. The convergence menu is accessed from the video menu on the tv.
The tv has three color picture tubes, red, blue and green. The convergence alignment adjust each tube so that color from each tube overlaps each over to create a white image on the screen. Most tv's only allow you to adjust the blue and red colors.
Convergence should be performed each time the tv is moved and at least once annually.
May 16, 2011 | Televison & Video
Not able to get red tones on TV
the problem is at the crt base .there r three red,blue n green o/put.verify if there is dry in the soldering n check the red cathode voltage it must b around 150 .if not then check the resistor that feeds the red o/put.it could b 12 to 15k. all crt have 3 driver color red blue n green,whenever one driver not working the color changes.that wat happened to ur tv now i do not know wat model u have.the drivers may b transistors or now its ic that r being used like tda 6103q.best of luck
Jan 03, 2010 | Toshiba 27AF45 27" TV
Movie has no red color only green and yellow
Remove & re-seat the component video cables at both the TV and the DVD player.
If the problem continues, disconnect BOTH ends of the BLUE cable and the RED cable. Connect the BLUE cable to the RED jack at both the DVD and TV, and connect the RED cable to the BLUE jack ob both the TV and DVD. If the RED color comes back and the BLUE is missing, then replace the RED cable (the red cable is broken and will not pass the signal that it is connected to).
If all works, reconnect the colored cables to the corresponding colored jacks at both the TV and DVD player.
If the RED color still won't display, isolate the trouble to either the DVD player or TV by connecting the DVD to another TV w/ component jacks. If the RED is still missing, it is a problem inside the DVD player - if the RED displays, it is a problem with the TV.
Sep 30, 2009 | Sony DVP-NS501P Progressive-Scan DVD/CD...
RCA TV lost Color
It sounds like your grandson found the "monochrome" setting in the menu on your remote. It may be in the "picture settings", "set-up" or "advanced" setting.
Sep 10, 2009 | RCA 32F531T 32" TV
NO Blue Colors on any station/program
If you are using component video cablesm make sure the blue is connected from tv to source.
Oct 27, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Blue and yellow color
Blue should converge on top of "yellow".Bad connection(s)
on blue convergence IC.Replace both IC's for durable repair.
Check pico fuses.Reset convergence alignment.
Oct 17, 2007 | Samsung HCL552W 55" Rear Projection...
ASUS P4BGL-MX 845GL (AS04P4BGL-MX) Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
