SONY TA-1066 Hi I need a service manual for the above, as it's "lost" one channel... hope you can help. Thanks
  • t3ster Dec 12, 2007
    Should have mentioned: this is a "vintage", solid-state unit, made in the '70's. I would like to get it going as my interest is in that era. Even a schematic would help. At present, I'm manually tracing the circuitry.
    Cheers
  • t3ster Feb 28, 2008
    Eventually, I found a dry joint.
I had the same problem twice and each time it was failed transistor in the powerstage.It is possible that the cooling is not efficient enough when playing at high sound levels! Good luck, Radio amateur ON4CLY
Posted on May 31, 2010
I have just bought a used Sony Integrated amplifier TA- F210 and it didn't come with the owner's manual so I don't know the RMS wattage to enable me connect speakers with the appropriate wattage. Could...
Hi, I brought a Sony TA-F-210 new back in 1990 $ 650 NZ , and has been a very .. very good amp. Earthquake ruined it !! I still have the owners manuel and it says for UK and other countrys DIN, 1 kHz, 8 ohms . 70w + 70w . or . 20Hz-20kHz THD 0.05%, 8 ohms . 50w + 50w Hope this helps. Have been running big old 3 way 8 ohm 50w speakers for all its life and it grunts.. or did !! Nobody belived me I was running only 50w speakers !! I dont know what I will replace it with.. You will enjoy. Might look for another one ! Wayne.. NZ CHCH
Nov 26, 2010 | Audio Players & Recorders
AMD 780G Chipset + DDR21066 Kit. Are they a match made in heaven?
You can populate half of your DIMM slots with DDR2 1066 RAM modules with this board. There is a limitation of the AMD AM2+ systems that puts a single-channel limit on the memory (hence the empty slots when using 1066).
Jul 11, 2009 | Gigabyte Computers & Internet
AUDIO AMPLIFIER'S ONE CHANNEL DEAD
Hi there.
Check for shorted speaker wires on left channel. If not, disconnect speaker wires and check to see if headphone jack works. If left works, you may have a blown speaker. If left still doesn't work, left power amp blown.
Thanks
Paul
Jul 06, 2009 | Sony Audio Players & Recorders
Sony TA-AV421 Amp
im needing help connecting my audissey aps 5+2 energy floor speakers . im confused on the 2 channels
Jul 30, 2008 | Sony TA-N9000ES 5-Channel Amplifier
Sony Stereo System
Your in luck there is a user guide online that has all you need to know.Here is the link
Sony TA-N9000ES Flash light when turn on.
an amp of this size generates alot of heat internally when in use as these use mosfet ICs and can get very hot.
your problem is most definately dry solder joints and possibly quite a few at that.
i've repaired quite a few sony surround receivers with similar problems and have all been down to dry solder joints.
hope this helps.
Jul 26, 2008 | Sony TA-N9000ES 5-Channel Amplifier
Sony TA-VE100
First of all check for loose connections. Also see if the left front audio output is working or not.
Jul 17, 2008 | Electronics - Others
738 people viewed this question
 Grubhead
Grubhead
