Question about Whirlpool 24 in. DU1055XTPS Stainless Steel Built-in Dishwasher
Dishes don't come clean. Water spots on stainless and film on glass. Tried powder & liquid detergent and max. amt. of water softener. Increased water temp. as recommended in manual. Any suggestions?
  • 14 Answers
Find filters down inside dishwasher. You'll need a screwdriver. :) Clean filters. They may become clogged again, which indicates a worse problem somewhere else. Not familiar with this model, sorry couldn't be of more help!
Posted on Dec 29, 2007
  • 126 Answers
Cut back on the amount of soap and make sure you are not overloading bottom rack remember water has to get up through lower rack to do its job correctly
Posted on Dec 12, 2007
Frigidaire d. w. grit and white film on glasses
Good Morning Friend,
I see that you are receiving grit and a white film on your glasses, in your Frigidaire dishwasher, model# FDB1050REC. Here are some common solutions that you can begin with.
-Check your water hardness. Hard water can cause lime deposit buildup on the interior of the dishwasher. Dishes and glasses may also get spots and film for a number of reasons. To remove buildup, spots and film, clean using the following instructions:
1. Load clean dishes and glasses in a normal manner. Do not load any metal utensils or silverware.
2. Do not add detergent.
3. Select the NORMAL WASH cycle. Close and latch door. Press START/CANCEL pad.
4. Allow your dishwasher to run until it starts the second water fill (approximately 10 minutes).
5. Unlatch and open the door, and pour 2 cups of white vinegar into the bottom of dishwasher.
6. Close and latch the door and allow the cycle to finish.
For extremely hard water, it may be necessary to install a water softener.
-Your water temperature may be low. Avoid extremely low or high temperatures.
-Avoid overloading and improper loading.
-Make sure you are using fresh detergent. Old detergent is ineffective.
-Make sure your rinse aid dispenser is filled.
-Check to see that the proper amount of detergent is being used for cycle selected.
-Your home water pressure may be too low-it should be 20 to 120 pounds per square inch (psi).
If none of these suggestions helps, I would suggest contacting either the manufacturer or a local authorized technician. Hope this helps.
-Best Regards-
WP
Feb 16, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Keep getting a white film on all my dishes, not cleaning properly.
Check the temperature of the water. Should be 120 deg. Also are you using powder or liquid? Liquid dissolved a lot quicker that powder. So liquid is actually better to use. Try running the hot water at the sink until it gets hot before running the dishwasher. Also you may want to try mixing half cascade liquid and half lemon shine.
Nov 14, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Dishwasher leaves white film on plastic dishes and stainless steel . Salt is full and rinse aid is full.
If your dishes or plastic dishes appear with a white filmy or spotted following a complete wash cycle, adjusting the amount or type of detergent you?re using and adjusting your hot water heater?s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you?ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
If the film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature.
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn?t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don?t use extra-hot settings such as ?Power Scrub,? and use the ?Energy Saver? dry cycle.
2) Adjust the detergent amount.
3) Don?t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
A common cause of poor washing results is improper loading?dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home?s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20?120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn?t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals?the more grains per gallon you have, the more detergent you?ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn?t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn?t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn?t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren?t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
Sep 03, 2010 | Miele Dishwashers
Film on glasses
If your dishes or glassware appear filmy or spotted following a complete wash cycle, adjusting the amount or type of detergent you’re using and adjusting your hot water heater’s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you’ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn’t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don’t use extra-hot settings such as “Power Scrub,” and use the “Energy Saver” dry cycle.
3) Don’t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
A common cause of poor washing results is improper loading—dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home’s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20–120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn’t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals—the more grains per gallon you have, the more detergent you’ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn’t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn’t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn’t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren’t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
May 07, 2010 | Whirlpool 24 in. DU1148XTP Built-in...
White film on all dishes and silverware
If your dishes or glassware appear with a white film or a white powdery residue or spotted following a complete wash cycle, adjusting the amount or type of detergent you?re using and adjusting your hot water heater?s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Please rate the solution if you feel I've helped you
Apr 27, 2010 | Kenmore 24 in. 16019 Built-in Dishwasher
Dishes, glasses & silverware have white film, look unclean!
May 11, 2009 | GE 24 in. Profile PDW9280JSS Built-in...
White film on glasses after a run.
Apr 18, 2009 | Thermador DWU244 Dishwasher
White film inside the dishwasher and on dishes
Usa a liquid detergent and rinse agent. Make sure your water is above 120 degrees. If you are a hard water area, use a detergent containing a water softener.
Mar 25, 2009 | Siemens 24 in. SL34A006UC Built-in...
Dishwasher does not clean dishes and leaves spots on everything!!
You need 2 things. Slightly hotter water and a rinse agent. If you don't heat dry your dishes, crack the door 3 or 4 inches after it's done, to let the steam out.
Mar 04, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
New dishwasher leaving powder residue on dishes.
the problem is hard water and there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishwasher and leaves your dishes spot free. after the first load i was amazed that the white film was gone and my dishes were sparkling. you can get it at www.dishwasherfilter.com.
Sep 06, 2006 | Kenmore 13869 / 13864 / 13862 Dishwasher
Whirlpool 24 in. DU1055XTPS Stainless Steel Built-in Dishwasher Logo
160 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
