Intel Motherboard Logo
Posted on Dec 12, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
OS is not loading
In my pc OS is not loading. error massage is "Not providing file in thi CD rom contact hardware supporter" if we change any CD the problem is same
Anonymous
Level 3:
President:
  • Master 4,402 Answers
  • Posted on Dec 12, 2007
Anonymous
Master
Level 3:
President:
Answers
4402
Questions
0
Helped
1710765
Points
8129
What OS are you trying to load?
1helpful
3answers
My DVD rom drive is not working I cannot "see" it on the system I have this error message "windowns cannot load the device driver for this hardware. the driver can be corrupted or m missing error code 29...
Check in device manager. To do this. 1st right click my computer, 2nd Click properties, 3rd click hardware, 4th click Device manager, 5th check that the computer is seeing the DVD/CD-ROM drives by double clicking the DVD/CD-ROM drives words or click the + symbol next to DVD/CD-ROM drives, the drop down menu will list your device if it’s there. If a device is listed double click the device. If it says it’s working properly click driver in the top bar and uninstall, then re-boot, the system will re-load the driver on re-booting. If the driver was corrupt it will re-install it correctly.
If the system cannot find the driver on re-booting it's missing from the systems file, go to the Support Fujitsu site and download and install the driver. Its free all you have to do is put the laptop details in the appropriate boxes and all the drivers for that laptop will be listed.
From your description of the error message it’s no doubt a corrupt or missing driver.
Hope this helps.
I am trying to install windows service pack 1. I keep getting an error code: 0x00F0826. Can you tell me what this means and how to fix it? I am running windows vista basic. 32-bit. Thanks.
if there error appeared while windows copying files then disc OS or the DVD ROM might be faulty. Try to test first the ODD if it is faulty. Use the drivers and utilities cd from dell to test the DVD ROM. If DVD ROM reads fine the drivers disc then try the OS disc to a different computer if it can load vista files. if not the OS disc has the problem. If no issues with OS disc and DVD Rom then it might be the HDD.
I disabled video card now my monitor is black. i can see the boot screen. i can hear my desktop when it loads. i tried safemode(it never loads in safemode)...last known workig....i still cant see anything.
Kindly repair or reinstall your Operating system. It has a file that has been corrupted. To avoid the damage become big try to repair it or reinstall the OS without reformatting or erasing the files save in your hard disk.
Kindly follow the steps below:
To repair/Reinstall your operating:
1. Insert your CD installer into your DVD/CD Rom then reboot your computer/Laptop.
2. Press F8 or F12 to enable boot sequence and display it in order to select the boot. Then select the DVD/CD Rom boot. Or Press Del to enter CMOS and set the boot configuration sequence and select the DVD/CD Rom as your priority to boot the system.
3. *** soon as message will display "Press any key to boot CD" then press any key to boot CD. Then wait for the CD to load all its components.
4. After loading all its components kindly follow the instructions givien by the installation wizard. Note that if you where ask by the installation wizard to press r to repair or enter kindly select enter then let the system detect the existing installation of OS in your system then it detects then press enter then kindly select "Repair" to repair the detected OS or Select "Don't make changes and make it intact" then enter to reinstall the OS without erasing the files save in your hard drive.
5. Kindly follow the instructions given by the installation wizard to finished the installation or repair of your system OS.
6. If you don't want to repair/reinstall by your self then you can contact a technician expert in computer to fix it for you.
If you need more assistance kindly reply to this post.
thank you
geo_jonas
2helpful
2answers
Error message on driver install
Isn't this joystick about 10 years old? If so, the CD provided could be overwriting important OS files with older versions. If you can't update the drivers via control panel, I would call/email them for updated software or a fix.
[email protected]
INF file textsetup.sif is missing
his behavior may occur if any one of the following conditions is true:
  • Your Windows XP CD-ROM is scratched, smudged, or dirty. Clean the Windows XP CD-ROM with a soft cloth, insert it in the CD-ROM drive, and then click OK.
  • Your CD-ROM drive is not working correctly or the CD-ROM might be vibrating too much for the laser to accurately read the data. For more information about this problem, see your hardware documentation or contact the CD-ROM manufacturer.
  • If you are using multiple CD-ROM drives, your computer may be trying to locate files on the wrong drive. If your hardware has a feature to disable CD-ROM drives that are not being used, disable the CD-ROM drives that you are not using.
  • Your computer is over-clocked. Because over-clocking is very memory-intensive, decoding errors may occur when you extract files from your Windows XP CD-ROM.
  • Try to use the default clock timings for your motherboard and processor. For more information about how to do this, see your hardware documentation or contact the motherboard manufacturer.
  • Your computer has damaged or mismatched random access memory (RAM) or cache memory. For example, you might be using a combination of extended data out (EDO) and non-EDO RAM, or different RAM speeds.
    Decoding errors may occur even if Windows appears to be running correctly. These errors occur because of the additional stress that is put on your computer when Windows tries to extract files and to access the hard disk.
    To determine how to make your computer cache memory unavailable while you are running the Setup program, see your hardware documentation or contact your hardware manufacturer.
  • Ultra direct memory access (DMA) is turned on in your computer's CMOS settings, and the data is moving too quickly.
  • Change from DMA mode to Processor Input/Output (PIO) mode to lower your data transfer rate. If this does not resolve the problem, lower your PIO mode settings. The higher your PIO mode settings are, the faster your data transfer is.
  • You are using a third-party memory manager.
  • There is a virus on your computer.
If you continue to receive this error message, copy the i386 folder from the CD-ROM drive to your local hard disk, and then try to run the Setup program from your hard disk.
2answers
Error loading operating system
Here you go! SYMPTOMS loadTOCNode(1, 'symptoms'); When you restart your computer after the file-copy portion of Windows XP Setup, you may receive the following error message: Error loading operating system
CAUSE loadTOCNode(1, 'cause'); This issue may occur if your computer BIOS does not correctly manage or support the capacity of the hard disk on which you are installing Windows XP. uparrow.gif RESOLUTION loadTOCNode(1, 'resolution'); Warning This article contains steps that may involve changing your BIOS or complementary metal oxide semiconductor (CMOS) settings or that may require you to make physical changes to your computer hardware. Incorrect changes to the BIOS of your computer may create serious problems. Microsoft cannot guarantee that problems that result from changes to your BIOS can be resolved. Change your BIOS settings at your own risk. If you need help with any of these steps, contact your hardware manufacturer and note that making either hardware or BIOS changes to your computer may invalidate your warranty. If you do not want to make hardware changes to your computer, you can take your computer to a repair center.
To resolve this issue, use one of the following methods: • Make sure that you are using the latest BIOS revision for your computer. Contact the computer manufacturer to inquire about how to obtain and install the latest BIOS update that is available for the computer. • If you are using an IBM computer with an AWARD BIOS version 4.5x, visit the following IBM Web site: http://www.pc.ibm.com/ww/hdd/hddredirect.html (http://www.pc.ibm.com/ww/hdd/hddredirect.html)Microsoft provides third-party contact information to help you find technical support. This contact information may change without notice. Microsoft does not guarantee the accuracy of this third-party contact information.
Stop Error: c0000221
This issue may occur if any of the following conditions exist: • A damaged file exists in the folder in which Windows is installed, and this file is not overwritten during Setup. For example, if you receive the error message that references the User32.dll file, the User32.dll file may be damaged. • One or more of the random access memory (RAM) modules that are installed in your computer is faulty, or the RAM configuration is incompatible
RESOLUTION loadTOCNode(1, 'resolution'); To resolve this behavior, use one of the following methods. Method 1: Extract a New Copy of the User32.dll File from the Windows XP CD loadTOCNode(2, 'resolution'); Extract a new copy of the User32.dll file from the Windows XP CD to the drive:\Windows\System32 folder on your hard disk, where drive is the drive on which Windows is installed: 1. Insert a Microsoft Windows Millennium Edition (Me) or Microsoft Windows 98 Startup disk into your computer, and then restart the computer.
NOTE: For additional information about what to do if you do not have a Windows Millennium Edition or Windows 98 Startup disk, click the following article numbers to view the articles in the Microsoft Knowledge Base: 186300 (http://support.microsoft.com/kb/186300/EN-US/) How to Create a Windows 98 Startup Disk from MS-DOS 267287 (http://support.microsoft.com/kb/267287/EN-US/) How to Create a Startup Disk in Windows Me 2. When the Windows Startup menu appears, use the ARROW keys to select Start Computer with CD-ROM Support, and then press ENTER. 3. Make a note of the drive letter of your CD-ROM drive. 4. Rename the User32.dll file to User32.old. To do so, type the following lines at the command prompt, pressing ENTER after each line, where Drive is the drive on which Windows is installed: Drive:
cd windows\system32
ren user32.dll user32.old 5. Insert the Windows XP CD into your CD-ROM or DVD-ROM drive. 6. Extract a new copy of the User32.dll file from the Windows XP CD to the Windows\System32 folder on your hard disk. To do so, type the following lines at a command prompt, pressing ENTER after each line, where CDROMDrive is the drive letter of the CD-ROM or DVD-ROM drive that contains the Windows XP CD-ROM, and Drive is the drive on which Windows is installed: a:
extract CDROMDrive:\i386\user32.dl_ Drive:\windows\system32\user32.dllFor example, if your CD-ROM is drive E and Windows is installed on drive C, type extract e:\i386\user32.dl_ c:\windows\system32\user32.dll, and then press ENTER. 7. Remove the Windows 98 or Windows Millennium Edition startup disk from your computer, and then restart the computer.
Method 2: Remove or Replace the Faulty RAM loadTOCNode(2, 'resolution'); Remove the memory modules that are installed in your computer, leaving enough RAM for the computer to start and run Windows. Restart the computer, and then run Setup again.
For additional information about Windows XP RAM requirements, click the following article number to view the article in the Microsoft Knowledge Base: 314865 (http://support.microsoft.com/kb/314865/EN-US/) System Requirements for Windows XP Operating Systems If the issue is not resolved, remove a different memory module. To identify the specific memory module that is not working correctly, you may have to restart your computer more than one time.
For information about how to add and remove RAM to the computer, contact the manufacturer of the computer, or view the documentation that is included with your computer.
Method 3: Install Windows to a Different Folder loadTOCNode(2, 'resolution'); NOTE: Before you install Windows to a different folder, first try the troubleshooting procedures in the following article in the Microsoft Knowledge Base: 310064 (http://support.microsoft.com/kb/310064/EN-US/) HOW TO: Troubleshoot Windows XP Setup Problems During Installation When You Upgrade from Windows 98 or Windows Me If the issue is not resolved by using the troubleshooting procedures in 310064, install Windows to a different folder. For more information about how to do this, see the "Installing to a New Folder" section of the following article in the Microsoft Knowledge Base: 316941 (http://support.microsoft.com/kb/316941/EN-US/) HOW TO: Install Windows XP MORE INFORMATION loadTOCNode(1, 'moreinformation'); For additional information about how to troubleshoot "STOP: C0000221 error messages", click the article number below to view the article in the Microsoft Knowledge Base: 314474 (http://support.microsoft.com/kb/314474/EN-US/) "STOP: C0000221 Unknown Hard Error" or "STOP: C0000221 STATUS_IMAGE_ CHECKSUM_MISMATCH" Error Message Occurs For additional information about upgrading to Windows XP, click the article number below to view the article in the Microsoft Knowledge Base: 316639 (http://support.microsoft.com/kb/316639/EN-US/) HOW TO: Prepare to Upgrade Windows 98 or Windows Millennium Edition to Windows XP For additional information about how to troubleshoot startup problems in Windows XP, click the article number below to view the article in the Microsoft Knowledge Base: 308041 (http://support.microsoft.com/kb/308041/EN-US/) Resources for Troubleshooting Startup Problems in Windows XP For additional information about Windows XP Setup, click the article numbers below to view the articles in the Microsoft Knowledge Base: 306824 (http://support.microsoft.com/kb/306824/EN-US/) Release Notes for Windows XP Setup Contained in the Home.txt File 286463 (http://support.microsoft.com/kb/286463/EN-US/) Release Notes for Windows XP Setup Contained in the Pro.txt File 286647 (http://support.microsoft.com/kb/286647/EN-US/) Windows XP Read1st.txt File Contents For information about how to contact your hardware manufacturer, click the appropriate article number in the following list to view the article in the Microsoft Knowledge Base: 65416 (http://support.microsoft.com/kb/65416/EN-US/) Hardware and Software Third-Party Vendor Contact List, A-K
60781 (http://support.microsoft.com/kb/60781/EN-US/) Hardware and Software Third-Party Vendor Contact List, L-P
60782 (http://support.microsoft.com/kb/60782/EN-US/) Hardware and Software Third-Party Vendor Contact List, Q-ZMicrosoft provides third-party contact information to help you find technical support. This contact information may change without notice. Microsoft does not guarantee the accuracy of this third-party contact information. Let me know if u got help and rate me as fixya please!!!
Problem loading win XP-SP2
Don;t know if this is the cause of u're errors, but it might be do to the motherboard chipset drivers (the lack of them in u're windows version). If so, u have to make a copy of u're windows cd with all u're motherboard drivers included, and try to install with that cd. The same problem appears to all new laptops that do not offer XP support and only Vista support . In order to do the new XP cd, u\ll need a little program that u'l find on internet..... (for example: n-lite)
5helpful
3answers
Pioneer dvd-rw dvr-k17a
Hi, the error code that you have on the CD/DVD drive is a known issue from Microsoft. The error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)".
Since you are using a Toshiba laptop; you can click on this link http://tinyurl.com/toshibadvd and click on the repair tool on the resolution. This is applicable on both Windows Xp and Vista and will delete the upper/lowerfilters on the registry.
In case that the error code still exist you need to manually delete the upper/lowerfilters under the registry by clicking on this link http://support.microsoft.com/kb/929461/en-us . You need to go the "Run" screen then type in "regedit" and click OK or hit the enter key.
This will surely fix the error code that you have on the CD/DVD drive.
Thanks
2answers
Dvd cd-rom
Which OS you are used.if You used windows 98 then boot up your pc with bootable windows 98 cd,it loads cd rom driver automatically.
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
